e92 M3 в Американската Le Mans серия 2009....
34 мнения
• Страница 1 от 3 • 1, 2, 3
- bmw_bulgar
- Регистриран на: 15.11.2006
- Кара: ВАЗ 2105
- Мечтае да кара: Ferrari F40 LM
485кс, 500NM, 1150кг
за още снимки тук:
http://www.m3post.com/forums/showthread.php?t=112448
"BMW is re-entering the ALMS (American Le Mans Series racing) with this race-prepped e92 M3 coupe
It comes complete with large rear spoiler, wider wheel fenders, a stripped interior and an upgraded 485 horsepower engine.
Race team owner Bobby Rahal was on hand to help announce BMW's return to ALMS racing, which will take place for the 2009 racing season. Rahal has previously campaigned BMW racing cars in ALMS.
Quote:
"We are very pleased to be returning to the American Le Mans Series with our latest generation BMW M3" states Tom Purves, Chairman and CEO, BMW of North America.
"Sports car racing has been part of BMW of North America's history practically from day one. Just two weeks after the company was incorporated in March 1975, a BMW CSL won the Twelve Hours of Sebring. We are confident that the fourth generation M3 will continue the legacy of its two predecessors which combined to win six manufacturer's championships over nine seasons in US sports car racing. As it has been in the past we believe the ALMS is the ideal venue to showcase the potential of the newest BMW M3."
BMW North America withdrew from the ALMS at the end of 2006, and the marque's return coincides with the ALMS' 10th season.
BMW won the first race in series history when J.J. Lehto, Tom Kristensen and Jorg Muller drove a BMW V12 LMR to victory lane in the 1999 12 Hours of Sebring. That same year, BMW became the first ALMS team to win the overall championship at the 24 Hours of Le Mans. BMW has 15 ALMS wins, with nine in GT2 class and six in LMP1."
за още снимки тук:
- DirtySouth
- Регистриран на: 11.12.2007
- [FF]GODFLESH
- Регистриран на: 24.10.2002
Жалко че Ханс Щук отиде да работи за Фолксваген...
- ///Ivan
- Регистриран на: 15.10.2007
- Кара: E36 328i Turbo
- Мечтае да кара: BMW F10 M5
- acho.rs
- Регистриран на: 9.02.2007
- Местоположение: Sofiq
А , ами че то М3 ГТР пак беше V8 , 445 коня и 1140 кг . Само че това бе преди 7 години ... Нещо тия 40 коня ми се струват слаб напредък или пък правилата там ги ограничават
Иначе колата е супер красив ДЗВЕР
...Абе спокойно . Сега като гледам Порше 911 ГТ3 РСРС и то е 485 коня само че е 1225 кила и само 435 НМ ... обема е 3.8 а варианта на колата е от 2007 година . Така , че нашата машина си е вървежна
Последна промяна acho.rs на 07 Фев 2008, 13:52, променена общо 1 път
- err0r
- Мечтае за Z3 M Coupe
- Регистриран на: 9.02.2003
- Местоположение: Сoфия
- Кара: '99 530dА Touring
- bavareca_86
- Ох, на баба!
- Регистриран на: 6.02.2007
- Местоположение: Берлин
- Кара: селскостопанска машина
- Мечтае да кара: 4етириосен самосвал
много е добра на визия само 4е както каза колегата тия 40 кон4ета малеят
- Жената^на^шефа
- Регистриран на: 10.08.2007
- Пол: Жена
Re: ..
Ебаси ма*ката...
http://jalopnik.com/354225/chicago-auto ... with-video
Technical Specifications BMW M3 Race Version.
Weight: 2,535 lbs./1150 kg
Tank capacity: 29 gallons/110 Liters
Chassis/body: Unitary construction steel body with welded safety cell made of extremely rigid precision steel tubing; safety fuel tank in CRP sandwich tray; pneumatic four-stamp jack system
Aerodynamics: Front fenders, rear apron, hood, roof, trunk lid, rear wing, front wings, and flared rear wheel arches in CRP
Transmission: Carbon fiber clutch with hydraulic central slave cylinder;
6-speed sequential racing transmission with straight-cut, unsynchronized gears;
additional oil/air cooler; quick shift system with ignition cut-out controlled by shifting force; mechanical limited slip differential with additional oil/air cooler
Front axle: Based on production version, with increased wheel caster angle, enlarged track width and enhanced wheel camber; five-way adjustable shock absorbers; tubular stabilizer bar
Rear axle: Based on production version, with enlarged track width and enhanced wheel camber; five-way adjustable shock absorbers, tubular stabilizer bar
Front brake system: Six-piston aluminum brake calipers, inner-vented grey-cast iron brake disks 15.0 in./380mm in diameter
Rear brake system: Four-piston aluminum brake calipers, grey-cast iron brake disk, 13.1 in./332mm in diameter
Steering: Rack and pinion steering with electro-hydraulic power
Wheels: Aluminum wheels, 18 inches
BMW P65 Engine.
Type: Eight cylinder, V-configuration
Capacity: 3999 cc
Bore x stroke: 92 x 75.2 mm/3.62 x 2.96 in.
Max. output: approx. 485 bhp
Max. torque: approx. 368 lb-ft/500 Nm
Cylinder block: Aluminum cylinder block construction with bed plate lower section
Crankshaft: Steel crankshaft
Pistons: Forged skirt pistons
Conrods: High-performance steel
Cylinder head: Aluminum DOHC (Double Over Head
Camshaft); four valves per cylinder
Valve train: Four overhead chain-driven camshafts, valve actuation via rocker arms
Intake system: Eight throttle valves, made of CRP with load-charge optimized ram tubes
Exhaust system: Headers, mufflers
Fuel system: Single cylinder multi-point injection
Lubrication: Dry sump lubrication
Cooling: Water/air cooler and oil/water heat exchanger
Electrics/Electronics.
Engine management: BMW Motorsport ECU 408 with two high-performance micro-processors; Individual cylinder injection and ignition;
BMW Motorsport Lambda Controller
Pit speed limiter, Quick Shift function;
Engine data memory system
Energy management: Electric energy management and monitoring with BMW Motorsport POWER400 control unit,
networking of all sensors and actuators through bus system
Wiring harness: Weight optimized
Ignition coil: Eight high-performance pencil coils with integrated ignition drivers
Spark plugs: High-performance spark plugs
Cockpit: Free programmable LCD Display with integrated shift indicators
Steering wheel: Quick release multi-function steering wheel w/ integrated display unit
BMW P65 Engine.
Capacity: 3999 cc
Последна промяна Жената^на^шефа на 10 Фев 2008, 23:21, променена общо 2 пъти
...It`s no Angel,Just Powerkata!...
- Gottlos
- Регистриран на: 19.01.2006
- Местоположение: За сега в Сливен,скоро и в други градове!
grnka написа:а бе вие си говорите за коне ще речеш че имате всички от по 500 коня под капака...това че е едва 1150 кила не ви ли говори нищо??астрата Ф е около1200 и повече килограми и с 150 коня върви да си ебе майката...
Ами прав е колегата,какво се захласвате по тая кола.Коне моне,килограми милограми...глупусти.БМВ че и за състезания някакви... пък и интериора за нищо не става.Няма подлакътник,то и седалки май нямаше много?!
Е те това истинска кола!!
Gottlos написа:grnka написа:а бе вие си говорите за коне ще речеш че имате всички от по 500 коня под капака...това че е едва 1150 кила не ви ли говори нищо??астрата Ф е около1200 и повече килограми и с 150 коня върви да си ебе майката...
Е те това истинска кола!!![]()
чета и не вярвам на ушите си
това е мнение в основния форум на бмв клуб българия
на каде върви тоя свят боже боже
пп: по темата колата е найстина уникална и ако не се лъжа точно поради ограниченията наложени от организацията са и тези коне
Последна промяна genezis на 07 Фев 2008, 20:54, променена общо 1 път
- DanielzZz
- Регистриран на: 29.12.2005
- Кара: М4
34 мнения
