Закл. подменюта на километража на Е36 (Instrument Cluster)
Регистриран на: 10.02.2008
Мнение от kdl » 22 Авг 2009, 14:09
Kак се отключва функцията на Instrument Cluster-a, която показва моментната скорост (с видео).
Няма значение дали колата има бордови компютър или не (тази на видеото няма).
Натиска се на 15то да напише L off и след това се отива на 8мо меню и се пали колата.
Video 1 - Настройки
Video 2 - В движение
Колата е 318ti 1995
Ето едно упътване със всички подменюта на Instrument Cluster-a. Свалено от този сайт
This works on all instrument clusters 1992-1999 E36 - 4 door/coupe/convertible/M3.
Step 1. Press and hold the mileage reset button.
Step 2. Put key into ignition switch and turn to KLR (Ignition switch position #1)
Your LCD display will show something like this "tESt 01"
Step 3. Once "tESt 01" is shown, let go of reset button and the IC(Instrument Cluster) will go through some test cycles. Numbers will be shown and here's what they mean:
1st display: BMW PART NUMBER (6 digits)
2nd display: CODE NUMBER (5 digits) Internal Coding Plug #
3rd display: K NUMBER (4 digits)
4th display: CHASSIS NUMBER (5 digits) this is part of your VIN
5th display: SOFTWARE VERSION (3 digits)
6th display: REVISION INDEX (2 digits) Hardware #
After all 6 displays are finished, an analog gauge test will be performed.
The self-test is canceled by switching the ignition off or to KL-15 (ignition switch position 2)
IC (instrument cluster) tests 1-15
1995 - 1998 (99) 318ti
1996 - 2000? Z3
1997 - 1999 E36 4dr/coupe/convertible/M3
NOTE:
*Test functions 1-4 are unlocked tests and can be called up at any time for display.
*Test functions 5-14 are locked and require unlocking the test mode before they can be displayed.
*Test functions 2-14 can be selected at any time when the cluster is unlocked, even when vehicle is moving.
*Test function 15 is the lock/unlock function.
Step 1: Press and hold the mileage reset button.
Step 2: Put key into ignition switch and turn to KLR (Ignition switch
position #1)
Step 3: You will need to unlock the test function first so when the LCD Display shows "tESt 01," press the reset button till you get to "tESt 15."
Once you're on test 15 press, and hold the reset button for a few seconds until it displays "off." Now you can cycle through the test features. Here they are as they follow:
Test 1: Instrument self test
Test 2: Engine Data - This display is an "engine factor" value that is stored in the coding plug. The instrument cluster processor uses this factor in addition to the "TD" signal from the DME control module to process and display tachometer RPM based on the engine installed. For EXAMPLE:
*ENGINE FACTOR 2 = 4 CYLINDER
*ENGINE FACTOR 3 = 6 CYLINDER
*ENGINE FACTOR 4 = 8 CYLINDER
Test 3: SI elapsed distance - the total mileage in kilometer since the last reset. Which service is due at the next inspection (OIL SERVICE or INSPECTION)
Test 4: SI elapsed days - no value for US vehicles. Relates to Euro annual inspections.
Test 5: SI evaluation factor - for engine speed and temp. thresholds being passed.
Display: n = 0 or 1. Engine speed (over-rev)
t = 0 or 1. Engine temp.
NOTE: "n0" means that you hit the maximum threshold for engine speed and "t1" means you overheated the engine. I found out from my instructor that this test 5 is false due to software related problems.
Test 6: Fuel Level and coolant temp. - Display of hexadecimal codes in relation to gauge position.
Fuel gauge ----> Hex value
A (empty)---------> 0d
End of reserve---> 37
B-------------------> 54
C-------------------> 90
D------------------> c4
E (full)-----------> f0
Engine temp. ----- Hex Value
A----------------------> ce
B----------------------> 6d
C----------------------> 5c
D (center)----------> 4f-23
E-----------------------> 1e
F-----------------------> 18
Test 7: Engine speed (Digital Tach)- display of current engine speed
Test 8: Road speed - display of current road speed in km/h
Test 9 Distance reading - this allows the total stored mileage to be updated if one of the storage components has to be replaced. This test step will be used if the manipulation dot is illuminated in the cluster display. This display will show the component with the lower mileage. For example:
Display of 012654 l indicates that the mileage in the internal EEPROM is lower than the mileage stored in the coding plug.
Display of 000325 E indicates that the mileage in external coding plug is lower then the total mileage stored in the internal EEPROM.
Pressing the reset button for 4 seconds will over write the lower mileage with the higher mileage and cancel the manipulation dot. The SI data will also be transferred at the same time.
Test 10: Status bits (input signals) - the status of digital inputs to the cluster are displayed as 0 or 1.
Display: 0 = input low, 1 = input high.
_ _ _ _ _ _ <--- Mileage display...6 digits left to right
1st - belt contact, seat belt fastened = 0
2nd - ignition lock contact, key inserted = 0
3rd - door contact, door open = 0
4th - clock button pressed = 0
5th - SI reset = 0, for reset = 0
6th - EGS transmission failure = 0
Test 11: Status Bits (output signals) - the status of digital outputs is displayed.
Display: 0 = output inactive, 1 = output active
1st - Gong output
2nd - Brake warning lamp
3rd - Low fuel warning lamp
4th - EGA lamp
5th - seat belt lamp
6th - manipulation dot
Test 12: not used
Test 13: Country code of cluster - the display indicates the country version of the cluster. This cannot be changed in the workshop. Display: USA 02
Test 14: Software Reset - The reset must be carried out if any faults are present that are not plausible before any components are replaced. After the reset, the system will exit the TEST mode and the lock will be reactived.
Eто го:
На 15ти просто се задържа докато пише L off и готово :)
tESt01 не е слято. Цифрите са в десния край.
vld написа:Момчета гледам, че спорите и невярвате на думите на liloff, та да вметна малко яснота как става "номера" :)
1. Сядате в колата и вкарвате ключа в стартера - освобождавате заключването на волана и връщате ключа на нула(това за да не се налага да пускате бутона за дневния километраж ако случайно се окаже, че ви е заключен волана).
2.Натискате бутона за дневния километраж.
3.Давате ключа на първи контакт.
4.Щом започне теста почвате да натискате бутона за дневния километраж на дисплея се появява отброяване 01 - 02.........14.15
така като стигнете на 14 натискате бутона и го задържате натиснат, на дисплея се появява L on 15 продължавате да държите докато не се промени на
L off 15, щом се промени (това става за около 4-5 секунди) вече можете да избирате различните тестове.
Ако искате да ви показва километрите с които карате отивате на 08 с последователно натискане на бутона на дневния километраж.
на дисплея се появява 000 08 - това е карате и гледате какво е отклонението на стрелката, като внимавате да не отплеснете прекалено много, че така стават инцидентите ;)
И да става на коли от 1995г. нагоре, на по-стари не съм пробвал, че нямам под ръка :mhihi:
Старши ентусиаст
Регистриран на: 10.08.2005
Кара: F11 535d, E84 2.3d
Мнение от vld » 22 Авг 2009, 16:45
Дискусии за това кое как и защо в тази тема:
http://bmwpower-bg.net/forums/viewtopic.php?t=162826
Тази е заключена за да е по спретнато ;)
