BMW Z4 Coupe Motorsport
8 мнения
Technical Data BMW Z4 M Coupé Motorsport Version
Length: 4415 mm
Width: 1880 mm
Wheelbase: 2493 mm
Front & Rear Overhang: 865 mm/774mm
Rear Wing Width: 1504 mm
Front & Rear Ground Clearance: 80 mm/90 mm
Front & Rear Tyres: Michelin 27/65-18, 28/71-18
Front Brake: Grey cast iron disc dia. 380 mm / 6 pot fixed calliper
Rear Brake: Grey cast iron disc dia. 320 mm / 4 pot fixed calliper
Drive Line: sequential 6-speed gearbox, sintered clutch
Engine Layout: six cylinder in line
Cylinder Capacity: 3246 cc
Bore x Stroke: 87 x 91 mm
Compression Ratio: 12,5:1
Max. Power: approx. 400 PS at 8200 rpm
Max. Torque: approx. 400 Nm at approx. 5750 rpm
Max. Revolutions per minute: 8400 rpm
Cylinder block: one-piece construction
Crankshaft: forged steel part
Piston: forged slipper skirt piston
Con-rod: Steel
Cylinder head: Aluminium, four valves per cylinder
Valve train: Two chain driven overhead camshafts with variable valve timing
Intake System: Six single throttle valves, Carbon fibre Air box with resonance induction optimised inlet pipes
Exhaust System: Multiple pipe manifold with silencer and catalytic converter
Lubricating System: Wet Sump Lubrication
Cooling System: Water / Air cooler
Flywheel: Steel
Fuel System: Inlet-Pipe Injection, one Injector per Cylinder, 5 bar injection pressure
Fuel: 5-star lead-free petrol, ROZ min=98
Fuel Tank Volume: 120 litres
Minimum Weight: 1200 kg in Nürburgring Specification
какво повече да кажа освен
250 000 Евра
Length: 4415 mm
Width: 1880 mm
Wheelbase: 2493 mm
Con-rod: Steel
Flywheel: Steel
250 000 Евра
- Bavarishe
- Регистриран на: 9.08.2004
- Местоположение: СофиА
- Кара: `Е34 ТДС-ъ 95
- Мечтае да кара: `Е34`E32 `E38 `E31
Днес разглеждах една зетка и ми се видя говедо,а тфа си цел кит с тая предница
ТДС - Турбо Див Селянин
- SlipKnoT
- devildriver
- Регистриран на: 21.04.2002
- Кара: E30
- Мечтае да кара: McLaren F1
- ///M Power
- Регистриран на: 21.11.2003
- Кара: си Е65-цата.
SlipKnoT написа:Това къде ще се "пуска" ?
предполагам това е отговора:Minimum Weight: 1200 kg in Nürburgring Specification
- Mario Andretti
- Mario Andretti
- krika
- ...и то хидравличен :)
- Регистриран на: 1.12.2003
- Кара: джата
- Мечтае да кара: на Ринга
- Детайли за колата: Двете 2и2ки
Доста е подла
Die Neue Klasse ---> http://www.youtube.com/watch?v=dU7hAq7vmwA ---- http://www.formula1.bg ----
Адската машина! Това street legal ли ще е ?
Забелязахте ли,че всички нови тунинги са с крила отзад? 320Si и тази Z3ka...
Последна промяна MaXimal на 02 Мар 2006, 15:22, променена общо 1 път
- MadVanio
ПсихопатVANIO
- Регистриран на: 16.06.2002
- Местоположение: СОФИЯ
- Кара: BMW - DARK SIDE OF THE FORCE
- Мечтае да кара: BMW E24
8 мнения
