Бушонче....
			2 мнения
Бушонче....
Да ми кажете кой номер е бушона на клаксона, че от студа става някъв конденз и като завивам надясно ми се включва свирката М№ Помага при задръстванията ама
мерси
мерси
The Ultimate Driving Machine
		... на дълго и широко
Fuses description
by Gustavo Melo
01 Jan 2000
Fuse Rating Description
1 7.5 Headlight, left high beam
2 7.5 Headlight, right high beam
3 15 Aux. cooling fan, low speed
4 15 Turn signals
emergency flasher
Active Check control
Digital Clock
5 30 Windshield wiper and washer
6 7.5 Stop lights
Cruise control
Active check control
ABS
Interior lights
7 15 Horn
8 30 Rear defogger
9 15 Fuel delivery
Idle speed
10 7.5 Seat belt warning system
Service interval indicator
Tachometer/fuel economy gauge
Instrument gauges and indicators
Brake warning system
Back-up lights
OBC
Starter
Fuel delivery
Idle speed
Stop lights and cruise control
11 7.5 Fuel pump
12 7.5 Radio power
Speedometer/instrument indicators
OBC
Multifunction Clock
13 7.5 Left Low Beam
14 7.5 Right Low Beam
15 Not Used
16 15 Heated Seats
17 30 Sunroof
Power Windows
18 30 Aux. cooling fan, high speed
19 7.5 Aux. cooling fan
Interior lights
Power mirrors
20 30 Heater/Air conditioner
Auxiliary Radiator cooling fan
21 7.5 Glovebox light
Flashlight
Ignition Key/Seat Belt warning
Interior Lights
Radio Memory
Trunk Light
Active Check Control
Service Interval Indicator
OBC
Fuel deliveryTachometer/Fuel Economy Gauge
Digital Clock
Multi Function Clock
22 7.5 Active Check Control
Front Parking Lights
Taillights
Front Side Marker Lights
23 7.5 Instrument Panel Lights
Taillights
Rear Side Marker/License Plate Lights
Rear Defogger
Multi-Function Clock
OBC
24 15 Turn Signals
Emergency Flasher
25 Not Used
26 Not Used
27 30 Interior Lights
Central Locking
OBC
Radio Amplifier
28 30 Lighter
Power Antenna
29 7.5 Left Fog Light
30 7.5 Right Fog Light
...първите цифри са ти номерата на бушоните, вторите - номинала, следва обяснението!
			by Gustavo Melo
01 Jan 2000
4 15 Turn signals
emergency flasher
Digital Clock
6 7.5 Stop lights
Cruise control
ABS
Interior lights
7 15 Horn
8 30 Rear defogger
9 15 Fuel delivery
Idle speed
Back-up lights
OBC
Starter
Fuel delivery
Idle speed
11 7.5 Fuel pump
12 7.5 Radio power
OBC
Multifunction Clock
15 Not Used
16 15 Heated Seats
17 30 Sunroof
Power Windows
Interior lights
Power mirrors
Flashlight
Interior Lights
Radio Memory
Trunk Light
OBC
Digital Clock
Taillights
Taillights
Rear Defogger
OBC
24 15 Turn Signals
Emergency Flasher
25 Not Used
26 Not Used
Central Locking
OBC
Radio Amplifier
28 30 Lighter
Power Antenna
>[//////]< ReaD
			2 мнения
