бмв-то умря :(
44 мнения
• Страница 3 от 3 • 1, 2, 3
- ivantchoG
- Регистриран на: 23.06.2004
- Местоположение: Перник
- Кара: 1985 BMW E30 M10B18
Сони не е писал числа...sonny написа:... мериш налягането на бензина, ако не идва изобщо или е слабо...
.Fuel pressure checks (fuel injection engines)
Fuel system pressure (relative to intake manifold pressure)
3-Series (E30)
316i with M40/B16 engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 ± 0.06 bars
318i with M10/B18 engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.5 to 3.0 bars
318i with M40/B18 engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 ± 0.06 bars
320i with M20/B20 engine (L-Jetronic) . . . . . . . . . . . . . . . . . . . . . . 2.5 to 3.0 bars
320i with M20/B20 engine (Motronic) . . . . . . . . . . . . . . . . . . . . . . . 2.5 ± 0.05 bars
325i with M20/B25 engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 ± 0.05 bars
5-Series (E28/”old-shape”)
All models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.5 to 3.0 bars
5-Series (E34/”new-shape”)
518i with M40/B18 engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 ± 0.06 bars
All other models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.5 to 3.0 bars
Fuel system hold pressure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.1 bars
Fuel pump maximum pressure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.3 to 6.9 bars
Fuel pump hold pressure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5 bars
Transfer pump pressure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.28 to 0.35 bars
Как се пробва - т.3
Трябва да си бая силен в пръстите да спреш 7атм
".....Ние, можещите, водени от незнаещите, вършим невъзможното за кефа на неблагодарните. И сме направили толкова много, с толкова малко, за толкова кратко време, че сме се квалифицирали да правим всичко от нищо....." К.Иречек, 13.12.1881
Бате Сашо - Пази имената!
- ///Явор
- Летящия холандец
- Регистриран на: 10.01.2003
- ivantchoG
5,5 е pump hold, не system
Ако има с 5б на инжекторите, не са слезли така от конвейера
- ///Явор
- Летящия холандец
mnh написа:Закачаме манометър-а след бензиновия филтър и там при въртене на стартер трябва да покаже около 3амтосфери така ли?
За момента помпата не покачва наляганетече си лекичко от помпата,даже май неможе да се говори за налягане
При какви условия тази помпа губи свойството да натиска горивото? ебаси
износване на помпата, блокиране от боклук, понижено напрежение. Напрежението може да спадне, както от слаб акумулатор, така и от лоши връзки, нагорели релета и прочие, затова ти бях писал да вземеш кабел директно от акумулатора
- ///Явор
- Летящия холандец
напрежението до крайната букса е около 14волта при въртене на стартер.sonny написа:mnh написа:Закачаме манометър-а след бензиновия филтър и там при въртене на стартер трябва да покаже около 3амтосфери така ли?
Лично си мисля,че е от износване на помпата...но това не ме топли пак си трябва нова помпа..
- ivantchoG
На маркуча след филтъра - "Fuel pump maximum pressure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.3 to 6.9 bars"
14V мериш между двете клеми на помпата или между едната и купето? И минуса може да е проблем
Филтъра също може да е запушен
филтъра е пропусклив .ivantchoG написа:На маркуча след филтъра - "Fuel pump maximum pressure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.3 to 6.9 bars"
14V мериш между двете клеми на помпата или между едната и купето? И минуса може да е проблем.
Филтъра също може да е запушен.
Между двете клеми на помпата меря.т.е. на буксата.
7бара почти,на маркуча след филтъра
Явно играта е в налягането.
Интересно пробвах друга помпичка пак от М40 потопяема но НЕ стана
после се замислих,че колата от която я взех е на газ и кой знае помпата колко е била в час и тя
Сложих нова/даде втора ръка/ помпичка от М40Б18 врът и запали.. работи си добре...
На новата помпа налягането не съм го мерил,но предполагам е достатъчно.
Благодаря на всички!
- dancenation
- Регистриран на: 24.03.2007
- Местоположение: Бургас
- Кара: E30 324TD '88
- Мечтае да кара: Custom made e30 with шукариии батко
- Детайли за колата: E30 1987 10'th october grey mettalic 203/7 4 door Diesel 324 td (turbo-diesel)Mechanical Fuel Pump,Xenon lights,
- terziev
- Регистриран на: 11.07.2007
- Кара: mega10B18
44 мнения
