Въпрос за Е46?
Регистриран на: 14.09.2006
Местоположение: София, ул. Гурко 16
Мнение от Louis » 21 Мар 2007, 0:33
logout написа:Мен пък ми се струва, че всичките сте в грешка. М54 е Double VANOS и се слага в Е46 от 2001г. нататък...
и М54 дъбъл ванус ли има вече :shock: :mhihi:
триногата
Регистриран на: 10.01.2007
Местоположение: BMW Drink Team Bulgaria
Мнение от Andronoff » 21 Мар 2007, 0:34
The BMW M52 is a Straight 6 piston engine. Displacement ranges from 2000ccm to 3200ccm. It is a DOHC 24-valve engine, originally introduced with VANOS Variable Valve Timing. It replaced the BMW M50 engine in 1994 and was replaced in 2001 with the BMW M54 engine. The engine used Nikasil lined aluminium cylinders rather than a cast iron cylinder block, resulting in lighter engines. The early M52 includes VANOS variable valve timing on the intake.
A Technical Update or M52TU version in 1999 added Double-VANOS and other modifications.
Applications:
* 1994-1999 E36 320i
* 1995-1999 E39 520i
M52TUB20
Applications:
* E36 Z3 2.0i
* 1997-2002 E46 320i/320Ci
* 1998-2003 E39 520i
M52B22
2.2 L
Applications:
* 2000-2001 E46 3-Series (M52T)
M52B24
2.4 L. For Thai market only.
Applications:
* 1995-1999 E36 3-Series
* 2000-2002 E39 5-Series (M52TU)
M52B25
A 2.5 L (2494 cc) version introduced in 1995. It produces 125 kW (170 hp). Bore is 84 mm and stroke is 75 mm.
Applications:
* 1995-2000 E36 323i/323ti
* 1995-1999 E39 523i
M52TUB25
Applications:
* 1997-2001 E46 323i/323Ci/323ti (M52T)
* 1998-2001 E39 523i (M52TU)
* 1998-2001 E36 Z3 (M52TU)
M52B28
A 2.8 L (2793 cc) version also debuted in 1994. It has square 84 mm bore and stroke and produces 193 hp (142 kW).
Applications:
* 1995-2000 E36 328i
* 1995-1999 E39 528i
* 1995-1999 E38 728i/728iL
* 1997-1999 E36 Z3 2.8
M52TUB28
Applications:
* 1997-2001 E46 328i/328Ci (M52T)
* 1997-2001 E36 Z3 2.8 (M52B28/Z3)
* 1998-2001 E39 528i (M52TU)
* 1998-2001 E38 728i (M52TU)
The BMW M54 is a modern straight-6 engine, debuting in the year 2000. It is an evolution of the BMW M52. The engine has Double VANOS variable valve timing to adjust timing of both intake and exhaust valves
Applications:
* 2001-2003 E46 320i/320Ci
* 2001-2003 E39 520i
* 2001-2002 E36 Z3 2.2i
* 2003-2005 E85 Z4 2.2i
* 2003-2005 E60/E61 520i
Сбогом, Сами! Сбогом, Писта!
Никога няма да бъдете забравени!
Предишна
