Останаха ли надежни двигатели, или ще чакаме електричките?
Кой двигател на BMW от 2014-та до днес според вас е надежден?
- N20
3
3%
- N55
6
6%
- B48
4
4%
- B58
22
21%
- N47
2
2%
- N57 30d
18
17%
- N57 35d
1
1%
- N57 40d
2
2%
- B47
4
4%
- B57 30d
7
7%
- B57 40d
1
1%
- друг
7
7%
- няма такъв
17
16%
- електрическите
10
10%
Общо гласове : 104
Регистриран на: 7.04.2004
Местоположение: CA
Re: Останаха ли надежни двигатели, или ще чакаме електричкит
Мнение от steeN » 14 Фев 2021, 17:23
Mini написа:Аз затова сипвам Shell V-power, защото в него няма етанол.
В Канада може и да няма, но в щатите и Бг има.
Регистриран на: 24.07.2002
Мнение от Mini » 14 Фев 2021, 21:57
На Costco и CT 91 октана в Канада също няма етанол. В Щатите имат някакъв закон, който ги задължава да добавят.
Старши Алкохолик
Регистриран на: 13.03.2006
Кара: E60 LCI 535d
Мечтае да кара: E24 635CSi
Мнение от zAcK » 14 Фев 2021, 22:32
:conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf: :conf:
Пичове, какво ви стана? Боли ме уя за горивата на краварите :mhihi: Дайте по темата, а? :mhihi: :mhihi: :mhihi:
Регистриран на: 15.08.2015
Местоположение: expedia.com
Кара: RX350 awd / E450 all terrain
Мнение от peshehodetz » 14 Фев 2021, 22:45
acho.rs написа:
Ако гледаш 540и с Б58 няма какво да го мислиш - при проверена история, вероятността да се разпадне е малка.
Само че много малка част от клиентите ги интересува историята - купуват се морги ама НА джанти :kuku: После се започва - олеле, малеле. За 530д/540и извън серийните екстри (един вагон) имаше само 1+1 задължителни неща - адаптив +дайнамик драйв. Тези системи коренно подобряват колата. Без тях разликата е огромна.
Тези две неща освен по ВИН има ли друг начин да се разбере дали колата ги има, особено когато става въпрос за оглед и тест драйв.
keep walking
Регистриран на: 12.09.2015
Мнение от madafaka_donkele » 14 Фев 2021, 23:52
peshehodetz написа:
acho.rs написа:
E нали имаш бутони и режими + че с една диагностика би трябвало да излязат активните модули.
Регистриран на: 29.10.2008
Местоположение: СССР,Москва,Лубянка 2
Кара: Е30-М40В18;Е36-М44В19;E91-N43B20A
Мечтае да кара: Е30 М3 Sport Evolution
Мнение от momo-1st » 15 Фев 2021, 2:09
DLVasilev написа:Я помежду другото да питам това устройство с клапана на водния радиатор фабрично ли е според вас?
https://www.mobile.bg/pcgi/mobile.cgi?a ... ink=iyp9kz
Да, това са жалузи на вакуум, като стопли и тогава отварят, зимата е голям рахат, загрява доста бръзичко и иде парното. Аз дори мислех, че няма Е34 без тях, пък ти питаш дали са фабрично :?: :shock: :wave:
bum_bum написа:Върти се, суче се и пак към соца се избива :mhihi: :mhihi: :mhihi:
Забравете го вече тоя гнил строй.
Наслаждавайте се на придобивките на демокрацията- Е шейсе на 15 години, виски на промоция от Кауфланд, пура за 2,40 в панелката с ипотека до 2060-та.
Регистриран на: 9.02.2007
Местоположение: Sofiq
Мнение от acho.rs » 15 Фев 2021, 21:20
madafaka_donkele написа:
peshehodetz написа:
acho.rs написа:
Не е баш така - на G30 имаш бутон "адаптив" но на Ф10 няма. Ако не си карал колата, при градско шофиране е трудно да се хване, освен ако няма павета и веднага след това възможност за агресивно шофиране.
Почти всички продавачи водят регулируемите амортисьори "адаптивно окачване" но разликата е голяма. Ако има софтуер за тест при пробмото шофиране, дайнамика може да се хване на един много забавен тест, на който колата става Пимп Май Райд като в "Still DRE"
Мнение от madafaka_donkele » 15 Фев 2021, 21:22
Така?
Старши Алкохолик
Кара: E60 LCI 535d
Мнение от zAcK » 15 Фев 2021, 22:00
Не. :bchug: И двете нямат нищо общо с това на gif-чето.
Dynamic drive е на мястото на задната стабилизираща щанга и помага колата да не се накланя в завой.
Adaptive поне при по-старите беше електромеханични амортисьори за седаните :bchug:
На колите с adaptive drive преди имаше букса на ботуша на амортисьора.
Ако не знаете какво са, по-добре си проверете по VIN. Става за 2 секунди :bchug:
Tестът на dymanic е различен от това на gif-a. Колата се накланя наляво и надясно.
Представи си, все едно я натискаш от единия край, след това от другия. В завой dynamic drive прави обратното :bchug:
Регистриран на: 15.03.2010
Кара: G20
Мечтае да кара: RS Cosworth
Детайли за колата: LCI2
B48B20А
Мнение от streetz » 15 Фев 2021, 22:39
Регистриран на: 21.11.2003
Кара: си Е65-цата.
Мнение от ///M Power » 16 Фев 2021, 0:20
zAcK написа:Dynamic drive е на мястото на задната стабилизираща щанга и помага колата да не се накланя в завой.
И двете щанги са хидравлични :winky:
- Mario Andretti
Регистриран на: 9.08.2012
Мнение от Vlado_L » 16 Фев 2021, 0:34
След две-три години масово ще се предлага подмяна на традиционния двигател с вътрешно горене с електрически на по-стари коли. Днес по Дискавъри даваха една фирма която предлага такива модули за WW и Порше. Изхвърлят двигателя с вътрешно горене и на негово място слагат модул в който е ел. двигателя + всички модули за управление.
master of the force
Регистриран на: 11.08.2003
Местоположение: planet torque
Мнение от alx » 16 Фев 2021, 2:20
Vlado_L написа:След две-три години масово ще се предлага подмяна на традиционния двигател с вътрешно горене с електрически на по-стари коли
това посмъртно няма как да стане в някакви количества за които си струва да се говори... като ги знам колко са различни като замисъл/ дизайн и реализация- масово просто няма да се случи.
алекс
трабант 601с
разни други возила
големия брат на Монтоя
Регистриран на: 20.05.2002
Мнение от BMW_POWER » 16 Фев 2021, 6:31
alx написа:
Може за "по-стари, но не по-стари от...". Тук е лесно. Един (рядко два) двигател, едно купе, и това навсякъде е еднакво. Защо да не изкарат допълнителни пари?
p.s. Аз на Коско не сипвам. Никой друг до сега не е успял да ми вкара 65л в 57л резервоар. И това при условие, че си отидох на ход и светеща резерва.
Регистриран на: 20.10.2010
Детайли за колата: :)
GC: ...SRT
Мнение от Nickelback » 16 Фев 2021, 10:36
Vlado_L написа:След две-три години масово ще се предлага подмяна на традиционния двигател с вътрешно горене с електрически на по-стари коли. Днес по Дискавъри даваха една фирма която предлага такива модули за WW и Порше. Изхвърлят двигателя с вътрешно горене и на негово място слагат модул в който е ел. двигателя + всички модули за управление.
Забравяш батерията, която не само, че трябва да е обезопасена надеждно, но и няма как да fit-не практично във всяко едно купе предвид специфичен форм фактор, да речем. Полагането и обезопасяването на силовата част също е предизвикателство. Да, може би, би станало за някакви колички с по 100 ел. коня и 100км пробег, но хич няма да е масово, функционално и конкурентно на това, което предлага съвремието.
Sent from my ONEPLUS A5000 using Tapatalk
Лето две и седемнаесто.
