E46 DIY или направи си сам...
- 3C
- Регистриран на: 20.04.2002
- Местоположение: USA & BG
- Кара: BMW/ Mercedes
- Мечтае да кара: Porsche
- gazzzar
кавалер-монтьор
- Регистриран на: 11.12.2003
- Кара: леки BMW-та :):):)
- Мечтае да кара: Ferrari F12 Berlinetta
Темата е много полезна и може да бъде от полза на много хора, затова я правя ВАЖНА
ВСЕКИ ИСТИНСКИ BMW ЕНТУСИАСТ РАНО ИЛИ КЪСНО СИ КУПУВА Е30 ///M3....
"The main thing is to be yourself. Many times its through a mistake that you learn. And the main thing is to make sure you learn through your mistakes and get better.”
Ayrton Senna
Ayrton Senna
- gazzzar
кавалер-монтьор
Easter Eggs I’ve collected from the board… in no certain order…
1. When the temperature drops below 37 F degrees, the car beeps to let you know to watch out for icy roads. Also, the rear defroster comes on.
2. You can read the odometer with the car off; all you have to do is press the needle on the left.
3. When car is off, hit the volume knob on the radio the radio turns on (it only works with 02 decks)
4. There is a "secret" compartment underneath my car's armrest and a Coin box in center console.
5. There is a trunk release right above the hood release (not on all cars)
6. There is an exterior trunk release above the license plate and under the ledge.
7. There is flashlight in the glove box.
8. There are amber lights that shine on the center console.
9. You can change radio station on the steering wheel by holding up/down button longer to scan to next station rather than preset ones.
Interior lights can be turn off when you open/close door or shut the engine down.
10. The two knobs on the center control panel are to reset the short trip mileage and the other one is for changing the time on the clock and changing the time from army time (24 hour time) to normal time. And you could also switch the temperature display both on the dash and on the climate control between Fahrenheit and Celsius.
11. You may be able to auto-roll down of windows from the remote control. Another way is to put the key in the door handle and turn to the unlock position and hold it there. This will also open and close the moon roof or put a convertible top down.
12. If you push the unlock button on the remote once it will unlock the driver door, for ‘02s if you push the unlock button on the remote twice it will unlock all the doors…then once all that is done.... push and hold the unlock button on the remote the windows will start to roll down... then the sunroof will open too.
13. If you hit the 'counter reset button' with the ignition in position 2 (or very quickly when you start your car), then it will show you when you are due to change your brake fluid!
14. There is also a first aid kit under the passengers seat.
15. There is a compartment by your leg when you are in the drivers seat. The compartment is on your left if in a LHD, and on your right if in RHD (located next to your knee).
16. The safety strip along each window and sunroof that detects obstructions and retracts them. (Along with a timer that prevents the motors from burning out if in use too long).
17. The OEM side mirrors are designed with slats and ridges to reduce wind noise.
18. The airbag system is 2 stage deployable depending on if the seat belts are latched. If there is no passenger, that front airbag wont even go off to save repair costs. (Along with the explosive seatbelt tensioners).
19. The radio, sunroof, and other "ignition" triggered accessories are available for a period of time after the car is turned off until a door is opened.
20. The fact that the car goes into "sleep" mode after 16 minutes of inactivity to reduce battery drain and eliminate dead batteries from "left on" accessories (lights, etc).
21. The suspension is designed to limit body dive under hard braking, instead the entire chassis dives evenly for stability.
22. The A/C compressor has a variable displacement thrust plate to eliminate the shock load of compressor cycling and use varies depending on need and load.
23. Flashing the high beams after ignition is turned off will leave the headlamps on for a preset amount of time for security while parking the vehicle.
24. The Keyless Entry system utilizes antennae in the rear window, change key codes every time, will deactivate keys if a key is pressed too many times without response from the car, the key recharges while in the ignition switch, and they store all sorts of presets, from seat positions to IHKA control settings.
25. The radio remembers the settings separate for each input. (E.g., CD input can have the bass/treble/balance/fade settings different from the F.M. radio)
26. Left Side Mirror will tilt in reverse (check to make sure your mirror selection switch is in center or left position to use this feature)
Door locks that engage when you go 8 Miles per hour (Dealer need to turn this feature on).
27. As some of you may know, the BMW On-Board Computer (OBC) holds more functions than is documented, including a very nice instrument panel test. I managed to get a lot of this information from the web, but it was far from complete. Subsequently I asked my dealer for the missing info, but they could not provide the complete list either. Following is a list for the items I could find, they work in my car (E46 323i). I gather most of them also work in the E36 models. Who can tell what the missing entries represent (especially functions
9.1, 9.2 and 9.3 which are very mysterious)?
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
28. Put your turn signal either on the left or right position, with no key in the ignition, close the door and walk away. What you will see is the front blinker, and rear turn signal stay lit. From what I read, it's supposed to be a feature to for people to see your car when it's parked at night in those really tight streets in Europe. This way no one accidentally drives into your car.
29. If you look on your roof, there will be two flaps on each side that are plastic and body colors. You can remove them and there is a little hole in each one that accepts the BMW Roof Rack.
30. Hold down the PTY button (this works, to my knowledge, on cars w/nav) and you will turn on AUTOPTY--it'll display the type of music station if the data is present. I think this works for RDS too.... that way, you don't have to keep pressing it when you switch to radio or change stations etc.
31. Change the Speed Sensitive Volume Ratio - E46 Business CD Head Unit:
Turn the radio off then on again. Don’t touch any button except the 'm' button - the button you use to tune the radio frequency manually. Press and hold the 'm' button for TEN seconds or until the display changes. It will then show the serial number of the unit. Normally when you press 'm', the display will reflect that by replacing 'ST' (stereo tuning) with 'm'. When holding the 'm' button for this procedure, the display should not do this - you will continue to see 'ST' for the ten seconds. Now if the display has changed, you are in a configure mode on the radio. If you press the '>' or '<' button you change modes. The mode you want will display as "GAL (1-6)". This mode allows you to adjust the speed-sensitive volume control. Use the radio preset buttons 1-6 to set the amount of volume change you want at speed. Setting 1 is the smallest change, 6 is the highest. I use 1 with the windows closed, and 5 when it's a nice enough day to drive with the windows open, which makes for a lot of ambient noise at speed. The car is so quiet with the windows closed that setting 1 is fine. Then turn the radio OFF to save the settings. Turn it back on; go for a drive to test it. The other semi-useful test mode will tell you the signal strength of any given station from 0 to 15 (highest). Use the preset buttons to change stations in the mode. This capability is probably used in the automatic tuning function in the radio.
32. The multiple 'auto heater/AC combinations at start-up' memory options are nifty.
33. If you want to leave your windows down but have the alarm set, but not have to worry about the motion detector go off, you can arm you alarm by hitting the lock button, and then wait a second and hit the button again. You'll see the clown nose light up for a second, which means the motion detector is deactivated
34. If you flicker your high beams when the car is off, your xenons go on for 30 seconds to give u a lighted path to walk
35. If you have auto wipers, the headlights go on when the wipers activate, if on auto.
36. Where the spare tire is, next to the portable jack there is a wheel chock!!
37. In Euro delivery cars, there is a warning triangle in a blue plastic case that bolts to the left rear of the trunk and a first aid kit under the passenger seat.
38. Apparently "there's a cheat code in the software running the BMW M3's sequential manual gearbox (SMG). Press the right buttons in the right order and the car will launch you from a stop after revving the engine to 5,000 rpm". "But there is a catch. In Europe, where the feature isn't so hush-hush, doing more than 15 launches voids the car's warranty. Federal laws prohibit such stipulations here, so BMW has turned down the which. US-spec cars are programmed to wind to only 2,500 rpm. That's why you have to ask your dealer to install the European software. Most will happily oblige"
"For lucky drivers of this hot car, here's how: Switch of the stability system and select shift program six. Switch the engine to sport mode. With the hand shifter in drive, hold it in the downshift position and press the has pedal. The engine will rev to the preprogrammed rpm and hold. Now release the shifter. The car will launch forward violently and the engine's revs will climb quickly, so be prepared to up shift"
39. When you have your wipers on fast and medium (don’t know what you call it) Anyways if you come to a stop it'll go to intermittent
40. Want to know your odometer reading but no key... no problem. Just press the computer toggle button at the end of the turn signal lever. The computer read-out lights up with the odometer reading.
41. Everyone knows that the screwdriver in the tool kit is reversible.
42. When windshield wipers are going, and the a/c is on, regardless of the temp, warm air is coming out of the windshield defrost vent.
43. Holding down the DSC button to completely turn it off.
информацията е взета от www.e46fanatics.com
1.1 4nnn K-number
1.6 Not used
3 SI Data
9 Battery
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
16 Not used
17 Not used
18 Not used
20 Not used
00 End of test
Ayrton Senna
Ayrton Senna
http://forum.e46fanatics.com/forumdisplay.php?f=27
тук има доста DIY само че повечко
сърч функцията в действие
http://www.openbmw.org/downloads/
Този сайт има доста интересни работи свързани с разглобяването на BMW/.pdf файлове/
- gazzzar
кавалер-монтьор
Ayrton Senna
Ayrton Senna
- ForzaBMW
- Регистриран на: 27.04.2005
- Кара: е61
- Мечтае да кара: алпина
ANGEL EYES
INSTALLATION INSTRUCTIONS
BMW E46 CCFL Angel Eyes Installation Instructions with Headlights Removed (Non-Xenon Only)
http://www.maxspeed-motorsports.com/bmw ... tions.html
BMW E46 CCFL Angel Eyes Instructions Installation without removing Headlights from Car. (Non-Xenon Only)
http://www.maxspeed-motorsports.com/bmw ... ions2.html
BMW E46 CCFL Angel Eyes Installation Instructions with Headlights Removed (Xenon Only)
http://www.maxspeed-motorsports.com/bmw ... ions3.html
BMW E46 Aero Form Carbon Fiber Intake Installation Instructions.
http://www.maxspeed-motorsports.com/e46 ... ation.html
- ForzaBMW
- Кара: е61
E46 CD Changer Installation
(with navigation system and fold down seats)
I picked up my BMW CD changer from Steven Diamond ($375 + $15 shipping). It is part # 82-11-1-469-404 (Alpine, I-Bus). The changer comes with a cartridge, manuals (none for the E46) and 4 M4 screws. Steve also threw in 2 L-brackets (part # 65-12-8-370-925) free of charge, since he knew I was installing it in a navigation-equipped car (already have sidemount brackets).
These instructions are specific to (my) Y2K 323i Sedan with folding rearseat and navigation system.
I used a small 1/4" drive ratchet wrench with 6mm and 8mm sockets. A wide flatblade screwdriver is helpful to pry off the trunk liner rivets. Try to prepare your cd changer for installation in advance (also see BMW instructions).
Some of this differ from Dave Heckendorf's instructions (his is '99, mine is '00).
Using his instructions, modify these steps as follows:
1. Similar. You only need to remove two of the rivets fastening the left-rear trunk liner. Remove the LR tailight panel and unplug it. Remove the rivet by the tailight and the one in the upper middle of the trim panel. Now lift the panel up and swivel it out of the way.
The reason I didn't remove the third rivet is because it is nearly inaccessible (under the rearseat upright side cushion, accessible once you fold down the seat).
The rivet fasteners may be difficult to deal with. I snapped the head off one of them.
You're now looking at the existing bracket, the nav cdrom drive, etc. Now remove the storage tray above the cdrom drive. Remove 4 (8mm hex head) screws and set them aside. You'll need these later to mount the cd changer.
2. skip.
3. skip.
4. skip.
5. Do prepare your CD changer. Helps if you do this step ahead of time, before starting installation.
Note the cd changer L-brackets are mounted long leg of the L alongside the changer, and the short leg of the L sticking outwards. Use the 4 screws supplied with your cd changer (M4 screw with 6mm hex head) The short leg of the L are your mounting points onto the existing changer bracket.
6. Find the large bundle of harness behind the bracket along the fender inner wall. Unbundle them and you'll find the cd changer harness. Plug the harness in. Now for the AR types, bundle the harness back together with the wrapping material, and stick them back where you found them. Slide the cd changer into the bracket from the front (may have to apply some force and spread the bracket a bit). Bolt the changer in with those 4 screws you removed earlier.
7. Test your changer before putting everything back together!
8. Reassemble everything and you're done.
As you can see, it is very easy. Takes less than an hour from start to finish.
2. skip.
3. skip.
4. skip.
- Stoyan7777
- Регистриран на: 5.08.2006
- Местоположение: Детройт, София
Ето един документ саморъчно направен,
ако някой иска да си инсталира Angel Eyes.
Дано ви е от помощ
http://rapidshare.com/files/4324426/Final_AA_Project.doc.html
Дано ви е от помощ
Относно волана има доста въпрос та
ето няколко отговора:
Как да инсталираme multifunctional steerin wheel,
ако преди това сме нямали такъв:
http://www.jdmotorwerkes.com/BMW%20Retr ... 3543en.pdf
Gauge rings поставяне...
http://www.bmwpower-bg.net/forums/viewtopic.php?t=13277
Благодарностите към naskoksan
With the engine running and radio on, turn off the radio.
Turn the radio back on and then (just before the radio display turns on) hold in on the "m" key for about 5 second or so until it goes into maintenance mode.
After holding "m" button to enter Maintenance Mode, it changes the LED screen to show the radio's serial number. "SN=xxxxxxxx"
Use the "+" or "-" buttons for scrolling
Press "+" to next function reads "GI 06", using the <|m|> arrows to scroll to, "HI 020101", "SIM 501100", "SIP 505020" and then back to "GI 06". No adjustment via any controls.
Press "+" to "GAL" use the arrow keys <|m|> to set the "GAL" setting from 1 (min) to 6 (max) or use 1-6 preset keys. Default is 3.
Press "+" and the radio station frequency is displayed along with two radio frequency signal strength meters that display the signal strength from 0-15. 15 is max signal strength.
Press "+" shows "DSP 0 V 00". No adjustment via any controls.
Press "+" shows a blank screen. Using the <|m|> arrows or 1-6 keys brings up different test patterns to test the display.
Press "+" displays "AREA USA". Using preset key 1 to scroll through, "AREA CANADA", "AREA OC+RDS", "AREA JAPAN", "NO AREA", AREA EUROPE", and back to "AREA USA".
Press "+" shows "VIEW 1". Using 1-4 keys to display "VIEW 1", "VIEW 2", "VIEW 3", "VIEW 4". Looks like brightness control for the display.
Press "+" shows "AF MAN" which is adjustable with the arrow keys <|m|> to turn "AF OFF" or to "AF MAN".
Press "+" returns back to serial number screen.
To get out of this maintenance mode, turn off the radio.
