E46 Brake Force индикация на стоповете
- Gqbriel
- Регистриран на: 14.06.2010
- Кара: комби
- Детайли за колата: N52B25
Re: E46 Brake Force индикация на стоповете
Най-накрая намерих отговорите на revtor - който има страхотна тема в bimmerforums за NCS
Generated with NCS Dummy version 0.5.0.5 — copyright © 2011 revtor software
Output : Module Functions
Chassis : E46
Module : LSZ.C32
FUNCTION KEYWORD OPTIONS
PARAMETER KEYWORD
BFD_ST3_ON
nicht_aktiv E46
aktiv
BFD_STUFE_2_VERZOEG
wert_01 E46
wert_02
BFD_MINDEST_GESCHW
wert_01 E46
wert_02
BFD_ON
nicht_aktiv !(US+MAERZ03)
aktiv US+MAERZ03
PIN5_10_BFD
nicht_aktiv !COMP
aktiv COMP
PIN38_20_BFD
nicht_aktiv !(LIM,COUP,CABR)
aktiv LIM,COUP,CABR
PIN49_37_BFD
nicht_aktiv !LIM
aktiv LIM
PIN29_30_BFD
nicht_aktiv !TOUR
aktiv TOUR
BFD_STUFE_2_MAX_EIN
wert_01 E46
wert_02
BFD_BLINK_AUSZEIT
wert_01
wert_02 E46
BFD_BLINK_EINZEIT
wert_01
wert_02 E46
BEI_NSL_KEIN_BFD
nicht_aktiv US
aktiv !US
BFD3_ASC_TIMER
wert_01 E46
wert_02
BFD3_ASC_AKTIV
nicht_aktiv E46
aktiv
All parameters that do not have an order option are irrelevant. It means that functionality was never enabled/used in the E46 (at least not to get the OEM behavior). So that leaves us with:
PARAMETER KEYWORD
BFD_ON
aktiv US+MAERZ03
PIN5_10_BFD
nicht_aktiv !COMP
aktiv COMP
PIN38_20_BFD
aktiv LIM,COUP,CABR
PIN49_37_BFD
nicht_aktiv !LIM
aktiv LIM
PIN29_30_BFD
nicht_aktiv !TOUR
aktiv TOUR
BEI_NSL_KEIN_BFD
nicht_aktiv US
aktiv !US
To me it seems you have to set function "BFD_ON" to "aktiv" and set "PIN5_10_BFD", "PIN38_20_BFD", "PIN49_37_BFD" and "PIN29_30_BFD" to the right parameters depending on you model (COMP = compact, LIM = sedan, COUP = coupé, CABR = convertible, TOUR = touring). Anyway, these should be set correctly already. The last function, "BEI_NSL_KEIN_BFD", is not that important. When set to "aktiv" the brake force display is disabled when the rear fog lights are on.
If these settings don't get brake force display working, I'm afraid I can't help you any further... The coding of the light control module should be correct but something else is missing then. I'm not sure what controls the brake force display, but it is probably not the light control module itself. My guess is the ABS/DSC module. If that's correct and if that module does not support the brake force display functionality, having a correctly coded light control module is obviously not going to work...
Зачетох се и в другите теми:
Колега с CI35 не може да активира 3-те премигвания само от CI36 or CI37 става
Chassis : E46
Module : LSZ.C32
PARAMETER KEYWORD
BFD_ST3_ON
nicht_aktiv E46
aktiv
BFD_STUFE_2_VERZOEG
wert_01 E46
wert_02
BFD_MINDEST_GESCHW
wert_01 E46
wert_02
BFD_ON
aktiv US+MAERZ03
PIN5_10_BFD
nicht_aktiv !COMP
aktiv COMP
PIN38_20_BFD
aktiv LIM,COUP,CABR
PIN49_37_BFD
nicht_aktiv !LIM
aktiv LIM
PIN29_30_BFD
nicht_aktiv !TOUR
aktiv TOUR
BFD_STUFE_2_MAX_EIN
wert_01 E46
wert_02
BFD_BLINK_AUSZEIT
wert_01
wert_02 E46
BFD_BLINK_EINZEIT
wert_01
wert_02 E46
BEI_NSL_KEIN_BFD
nicht_aktiv US
aktiv !US
BFD3_ASC_TIMER
wert_01 E46
wert_02
BFD3_ASC_AKTIV
nicht_aktiv E46
aktiv
PARAMETER KEYWORD
BFD_ON
aktiv US+MAERZ03
PIN5_10_BFD
nicht_aktiv !COMP
aktiv COMP
PIN38_20_BFD
aktiv LIM,COUP,CABR
PIN49_37_BFD
nicht_aktiv !LIM
aktiv LIM
PIN29_30_BFD
nicht_aktiv !TOUR
aktiv TOUR
BEI_NSL_KEIN_BFD
nicht_aktiv US
aktiv !US
- Gqbriel
- Кара: комби
Toва е за компакт,но е 2004 год производство.
Hier mal die Werte aus dem LSZ meines e46 Compact
BFD_SW1_STUFE3
nicht_aktiv ->aktiv
BFD_SW2_STUFE2
aktiv ->nicht aktiv
BFD_ABS_STUFE3
nicht_aktiv ->aktiv
BFD_SW2_STUFE3
nicht_aktiv ->aktiv
BFD_MINDEST_GESCHW
wert_01->02
BFD_STUFE_2_VERZOEG
wert_01->02
BFD_SW1_STUFE2
aktiv ->nicht aktiv
BFD_ABS_STUFE2
aktiv ->nicht_aktiv
PIN49_37_BFD
nicht_aktiv ->aktiv
PIN38_20_BFD
nicht_aktiv ->aktiv
BLST1_BLST3
nicht_aktiv ->aktiv
BFD_BLINK_EINZEIT
wert_01 ->wert_02
BFD_BLINK_AUSZEIT
wert_01 ->wert_02
BEI_NSL_KEIN_BFD
aktiv
BFD_SW1_STUFE3
nicht_aktiv ->aktiv
BFD_SW2_STUFE2
aktiv ->nicht aktiv
BFD_ABS_STUFE3
nicht_aktiv ->aktiv
BFD_SW2_STUFE3
nicht_aktiv ->aktiv
BFD_MINDEST_GESCHW
wert_01->02
BFD_STUFE_2_VERZOEG
wert_01->02
BFD_SW1_STUFE2
aktiv ->nicht aktiv
BFD_ABS_STUFE2
aktiv ->nicht_aktiv
PIN49_37_BFD
nicht_aktiv ->aktiv
PIN38_20_BFD
nicht_aktiv ->aktiv
BLST1_BLST3
nicht_aktiv ->aktiv
BFD_BLINK_EINZEIT
wert_01 ->wert_02
BFD_BLINK_AUSZEIT
wert_01 ->wert_02
BEI_NSL_KEIN_BFD
aktiv
След доста опити с различни настройки, модули и светлини стигнах до смятам напълно универсални настройки за всички. Публикувам всички настройки, за LSZ от CI32 до CI37. Според вашата версия на модула може да нямате някои от настройките.
Активиране на Brake Force Display (BFDY) при три настройки на стоп светлините.
1. Нормално спиране - светят ЛЯВ, ДЕСЕН и СРЕДЕН стоп
2. Силно спиране, без задействане на ABS - светят ЛЯВ, ДЕСЕН и СРЕДЕН стоп + ЛЯВ и ДЕСЕН габарит за мъгла(за тези които нямат трябва да си инсталират крушка и на десния)
3. Спиране със задействане на ABS - мигат ЛЯВ, ДЕСЕН и СРЕДЕН стоп.
BFD_SW1_STUFE2 -> aktiv
BFD_SW2_STUFE2 -> nicht_aktiv
BFD_ABS_STUFE2 -> aktiv
BFD_SW1_STUFE3 -> nicht_aktiv
BFD_SW2_STUFE3 -> aktiv
BFD_ABS_STUFE3 -> aktiv
BFD_MINDEST_GESCHW -> wert_02
BFD_STUFE2_TIMER -> wert_02
BFD_STUFE3_TIMER -> wert_02
BFD_STUFE_2_VERZOEG -> wert_02
BFD_STUFE_2_MAX_EIN -> wert_02
BLST1_BLST3 -> aktiv
ST3_SCHWEL -> nicht_aktiv
PIN5_10_BFD -> aktiv
PIN29_30_BFD -> aktiv
PIN38_20_BFD -> aktiv
PIN38_BFD -> aktiv
PIN49_37_BFD -> aktiv
PIN49_BFD -> aktiv
PIN_20_ALS_SL_LI_3_ANSTEU -> aktiv
PWM_ANSTEUERUNG_SL3_LI_HI -> wert_02
NSL_ALS_STANDLICHT -> aktiv
PIN38_BFD -> aktiv
PIN49_BFD -> aktiv
- ilia1984
- Регистриран на: 11.04.2012
- Кара: BMW E60
- Мечтае да кара: BMW
stilko написа:След доста опити с различни настройки, модули и светлини стигнах до смятам напълно универсални настройки за всички.
Колега имаш ли наблюдения след коя версия на LSZ могат да се пускат "Force индикация на стоповете" както и след коя версия се пуска фабричният ксенон
- Gqbriel
- Кара: комби
ilia1984 написа:stilko написа:След доста опити с различни настройки, модули и светлини стигнах до смятам напълно универсални настройки за всички.
А каква да е разликата,с пускане или не на фабричния ксенон ако фабрично си с такъв но е disabled?
- oci
- Регистриран на: 18.07.2008
- Кара: '12 BMW F10
- Мечтае да кара: самолет
За фабричния ксенон мисля, че дори и най-ниската версия на ЛЦМ-а го подържа поне аз съм пускал на лайт от кола 98 година и няма проблем, но за Brake Force Display, колегата stilko го е написал от лайт с версия на софта 32 нагоре.
- ilia1984
- Кара: BMW E60
oci написа:За фабричния ксенон мисля, че дори и най-ниската версия на ЛЦМ-а го подържа поне аз съм пускал на лайт от кола 98 година и няма проблем, но за Brake Force Display, колегата stilko го е написал от лайт с версия на софта 32 нагоре.
Мерси oci за отговора питам за ксенона защото фабричните LED стопове не работят със всички версии на лайт модула....мислех че и със ксенон-а е така
oci написа:ilia1984 написа:stilko написа:След доста опити с различни настройки, модули и светлини стигнах до смятам напълно универсални настройки за всички.
Точно така е и най-старият LSZ модул има опция за ксенон.
П.С. Не каза какво стана с файла, който ти направих.
- oci
- Кара: '12 BMW F10
stilko написа:oci написа:ilia1984 написа:stilko написа:След доста опити с различни настройки, модули и светлини стигнах до смятам напълно универсални настройки за всички.
Другата седмица ще го пробвам, че колегата е от Смолян и тогава ще идва и веднага ще ти пиша, но мисля, че щом си го направил няма да има проблеми.
- ico_77777
- Регистриран на: 27.07.2012
- Местоположение: Русе
- Кара: BMW е46
- Мечтае да кара: BMW е90
някой от гр.Русе който да активира" Brake Force" индикация на стоповете.
ico_77777 написа:някой от гр.Русе който да активира" Brake Force" индикация на стоповете.
Ако някой колега не ти свърши работа ми пиши другата седмица ще съм в Русе.
Gqbriel написа:.....
От това написаното излиза, за да включа BFD-то, то трябва да сменя само "BFD_ON" на "aktiv".
Всичко останали опции отгоре, където си ги дал от темата на revtor са ми нагласени както е описано - като за европейско комби.
Единствено тази опция - BEI_NSL_KEIN_BFD я нямам в кодировката на моя лайт модул, но до колкото виждам не е толкова важна.
Някой успял ли е да активира BFD-то само с промяна на "BFD_ON" от "nicht_aktiv" на "aktiv"?
Моята версия на модула е 31 ако това има значение. Предполагам, че има, защото се намирам точно на границата между новите и старите версии. Не знам точно 31-ва версия дали се води нова или стара.
Трябва да си богат, за да караш BMW!
Трябва да си много богат, за да караш старо BMW!
- dido0o```
- Регистриран на: 3.05.2011
- Кара: F10 530d 245
JTD написа:От това написаното излиза, за да включа BFD-то, то трябва да сменя само "BFD_ON" на "aktiv".
Навсякъде където съм чел за тази индикация пише, че се активира на лайт модули от 32-ра версия нагоре. И все пак ако успееш пиши, защото и аз съм с 31
- Gqbriel
- Кара: комби
JTD написа:Gqbriel написа:.....
Аз пуснах BFD на моята,но нещо 3-я стоп не тръгва да присветка
,но при рязко натискане на спирачките в последствие спиране .Toва се получи на една М3:
https://www.facebook.com/photo.php?v=10200393702818746&set=o.195127853851568&type=2&theater
Това при мен:
https://www.facebook.com/photo.php?v=10200378520439196&set=o.195127853851568&type=2&theater
Стоповете значително усилват интензитета си.
Нещо обаче,дори с помоща на stilko не тръва смотания 3-ти стоп.Явно бъркам нещо някъде
Gqbriel написа:JTD написа:Gqbriel написа:.....
Аз пуснах BFD на моята,но нещо 3-я стоп не тръгва да присветка,но при рязко натискане на спирачките в последствие спиране .
Това при мен:
Не се отваря нищо от линковете. При теб CI31 ли беше или CI32?
