Препоръка/Идея или както прецените
Модератор: I.Voykov
6 мнения
- bgtroll
- Регистриран на: 25.03.2004
- Местоположение: София , Люлин
Защо не прецените да сложите някой от следните добавки, предполагам може и да са полезни:
[2.0.7] Abnormal posts widening fix
MOD Name: Abnormal posts widening fix
Author: -=ET=-
MOD Description: This MOD fix the abnormal posts widening when a large image is included in a message.
[2.0.11] Limit Image Width
MOD Name: Limit Image Width
Author: Vic D'Elfant
MOD Description: This MOD will scale each image in a post so it does not exceed the maximum image width set by you. Smaller images will retain their original size.
When clicking such a scaled down image it will open at its original size in a separate popup window.
The image dimensions will be cached in order to avoid unnecessary delays when loading a page and checking the image dimensions
You can see the MOD in action at: http://www.pythago.nl/~phpbb/viewforum.php?f=1
[2.0.10] Fast Avatar Resize Mod
MOD Name: Fast Avatar Resize Mod
Author: etncrew
MOD Description:
* Changes the width of all remotely linked avatars to the max width set in de ACP. So big avatars will be smaller (and small avatars will be bigger).
* The height of the avatars increases (or decreases) with the same percentage as the width, to remain the aspect ratio. This causes no problem for square or wide avatars, but avatars which are more then two time higher then their width might stretch your board vertically.
* The reason I didn't simply use JavaScript to check the images widths and heights, is that JavaScript slows down your board dramaticly. This mod doesn't slow down your board at all.
[url=http://www.phpbb.com/phpBB/viewtopic.php?t=243046] [2.0.11] Resize Posted Images Based on Max Width
[/url]
MOD Name: Resize Posted Images Based on Max Width
Author: spooky2280
MOD Description: This MOD resizes images within posts to make it so they don't break your layout. Images resized are made clickable and openable in a popup in full-size. You can specify a different max width for each of your themes. Images that do not exceed the max width are left as is. See the MOD in action: http://christianfecteau.com/rmw
Author: -=ET=-
Author: etncrew
MOD Description:
[/url]
Author: spooky2280
- TechSupport
- Регистриран на: 17.01.2002
Благодаря! Ще проверим споменатите от теб опции
support@bmwpower-bg.net
Свобода за Кирил Мантовски, Виктор Лазаров, Светозар Колев, Любомир Мегов и Велин Неделчев - български РС-специалисти, незаконно задържани и осъдени в Дубай!
- bgtroll
- gazzzar
кавалер-монтьор
- Регистриран на: 11.12.2003
- Кара: леки BMW-та :):):)
- Мечтае да кара: Ferrari F12 Berlinetta
naskoksan написа::yes:
и аз му писах на тоя
да махне билборда
и не само ти............
ВСЕКИ ИСТИНСКИ BMW ЕНТУСИАСТ РАНО ИЛИ КЪСНО СИ КУПУВА Е30 ///M3....
"The main thing is to be yourself. Many times its through a mistake that you learn. And the main thing is to make sure you learn through your mistakes and get better.”
Ayrton Senna
Ayrton Senna
- I.Voykov
- по-добре 2л пепси от 1.6л хонда
- Регистриран на: 8.03.2002
- Кара: каквото намери в гаража
А аз му го изтрих
http://WWW.BMWBG.CLUB
Are you ///M enough ...?
6 мнения
Назад към Новини, предложения, проблеми & коментари за сайта и форума
