помощ за кикер зх 750.1
Модератор: Icco
2 мнения
Ако нвкой знае дали мога да захрана 2 броя с12л5 да каже с него и каква му е цената в бг плс Благодаря ви!!!
спецификация на усилвателя
ZX Series Class D Mono Amplifier
ZX750.1
RMS Power @ 2ohm stereo: 750W
Frequency Response: 20Hz-200Hz
S/N Ratio: >95dB
Input Sensitivity: 125mV-5V Low Level / 250mV-10V High Level
Active Crossover: 24 dB/oct, variable 50Hz - 200Hz, Low pass only
KICKEQ Boost: Variable 0 to +18dB boost @ 40Hz
12dB/octave Subsonic Filter defeatable @ 25Hz
Dimensions: 9-5/8" x 2-1/8" x 14-11/16" (WHL)
Спецификация на субуферите с12 л5
Power Handling RMS: 600
Power Handling PEAK: 1200
Impedence: 2 ohms, 4 ohms
Sensitivy (DB 1w/1m): 87.1
Frequency Response (Hz): 20-100
Mounting Depth (In, Cm): 6-3/8, 16.1
Mounting Cutout Sqaure (In, Cm): 11,27.9
Min/Max Recommended Sealed Box Vol (CU FT, LITRES): .88-2.0 cu ft,24.9-56.6 litres
Min/Max Recommended Vented Box Vol (CU.FT, LITRES): 1.75-3.25cu ft, 49.6-92.1litre
ZX750.1
S/N Ratio: >95dB
2 мнения
