Е38-стъпково моторче
7-ма серия ('95 - '01)
Регистриран на: 3.12.2008
Мнение от rodmanblg » 08 Фев 2012, 14:05
интересува ме от кои други модели става съпковото моторче за 730иа 95-та година.
Re: Е38-стъпково моторче
Мнение от cod-cdbp » 08 Фев 2012, 16:44
Toва достатъчно ли е като информация :mhihi: :mhihi: :mhihi:
E31 840Ci Coupe, M62, AUTO (EF83) : Mass air flow sensor/ASC
E31 840i Coupe, M60, AUTO (EF63) : Mass air flow sensor/ASC
E32 740i Sedan, M60, AUTO (GD43) : Mass air flow sensor
E32 740iL Sedan, M60, AUTO (GD83) : Mass air flow sensor
E34 530i Sedan, M60, AUTO (HE23) : Mass air flow sensor
E34 530i Sedan, M60, MANUAL (HE13) : Mass air flow sensor
E34 530i Touring, M60, AUTO (HK23) : Mass air flow sensor
E34 540i Sedan, M60, AUTO (HE63) : Mass air flow sensor
E34 540i Sedan, M60, MANUAL (HE53) : Mass air flow sensor
E38 740i Sedan, M60, AUTO (GF63) : Mass air flow sensor
E38 740iL Sedan, M60, AUTO (GJ63) : Mass air flow sensor
E38 740i Sedan, M62, AUTO (GG83) : Mass air flow sensor/ASC
E38 740i Sedan, M62, AUTO (GF83) : Mass air flow sensor/ASC
E38 740i Sedan, M60, AUTO (GF63) : Mass air flow sensor/ASC
E38 740iL Sedan, M62, AUTO (GJ83) : Mass air flow sensor/ASC
E38 740iL Sedan, M62, AUTO (GH83) : Mass air flow sensor/ASC
E38 740iL Sedan, M60, AUTO (GJ63) : Mass air flow sensor/ASC
E39 540i Sedan, M62, AUTO (DN63) : Mass air flow sensor/ASC
E39 540i Sedan, M62, AUTO (DE63) : Mass air flow sensor/ASC
E39 540i Sedan, M62, MANUAL (DN53) : Mass air flow sensor/ASC
E39 540i Sedan, M62, MANUAL (DE53) : Mass air flow sensor/ASC
E39 540iP Sedan, M62, AUTO (DN83) : Mass air flow sensor/ASC
E39 540iP Sedan, M62, AUTO (DE83) : Mass air flow sensor/ASC
E39 M5 Sedan, S62, MANUAL (DE93) : Idle regul.valve/fuel tank vent valve
E46 M3 Convertible, S54 (BR93) : Idle regul.valve/additional air line
E46 M3 Coupe, S54 (BL93) : Idle regul.valve/additional air line
E52 Z8 Roadster, S62 (EJ13) : Idle regul.valve/fuel tank vent valve
E85 Z4 M3.2 Roadster, S54 (BT93) : Idle regul.valve/additional air line
E86 Z4 M3.2 Coupe, S54 (DU93) : Idle regul.valve/additional air line
Z3 Z3 M Coupe, S54 (CN93) : Idle regul.valve/additional air line
Z3 Z3 M Roadster, S54 (CL93) : Idle regul.valve/additional air line
А като личен съвет - смени гарнитурите на колектора, ама ВСИЧКИ възможни, и почисти стъпковото моторче с разредител, както и смени неговия О-пръстен (като го разглобиш самото моторче, ще разбереш за кой пръстен иде реч). Също е полезно да му обслужиш и четките 8)
Регистриран на: 11.06.2006
Местоположение: София бате центъра на....
Кара: ше 30,38,39 вече само Гранд Чероки
Мечтае да кара: Грейдер на Ибиза
Мнение от RORO » 08 Фев 2012, 16:53
Само леко да коригирам колегата не с разредител а със кореселин плакнеш докато спре да пуска черно!
Мнение от cod-cdbp » 08 Фев 2012, 19:56
RORO написа:Само леко да коригирам колегата не с разредител а със кореселин плакнеш докато спре да пуска черно!
A кореселина също е разредител :mhihi: :mhihi: :mhihi: :mhihi:
Мнение от rodmanblg » 10 Фев 2012, 16:33
Днес ходих да го чистят с ултразвук. Падна доста мърсотия от него.
Регистриран на: 14.12.2010
Кара: Е 38 740i 1999г.
Мечтае да кара: Lockheed SR-71 Blackbird
Мнение от asennikolov » 12 Фев 2012, 22:53
rodmanblg написа:Днес ходих да го чистят с ултразвук. Падна доста мърсотия от него.
И какво стана в крайна сметка? Помогна ли ултразвуковата процедура и реши ли проблема?
Мнение от rodmanblg » 20 Фев 2012, 16:24
На пръв поглед помогна ултразвука но се оказа че имам за смяна гарнитурите на всмукателни тръби.... утре чакам да я запалим да видим какво ще стане.
Мнение от RORO » 20 Фев 2012, 17:13
А клапана картерни гаЗове прегледахте ли го?Като спука мембраната пак няма стабилни ниски обороти.
Мнение от rodmanblg » 12 Мар 2012, 17:09
Оправихме изцяло проблема със смяната на гарнитурите + почистване на стъпковото моторче.
Мнение от cod-cdbp » 12 Мар 2012, 17:14
rodmanblg написа:Оправихме изцяло проблема със смяната на гарнитурите + почистване на стъпковото моторче.
Браво един път да прочета за добре направена интервенция като по книгите :clap: :clap: :clap:
Регистриран на: 15.06.2008
Местоположение: beyond the Milky Way
Кара: SR1 NORMANDY
Мечтае да кара: 320 turbo DRM
Мнение от ddinobot » 26 Май 2012, 10:43
Колеги и аз имам проблем с това моторче, като цяло колата ми не поддържа ниските обороти и много често гасне, почистих стъпковото моторче с ВД 40 и изтече доста мръсотия, но проблема не се реши, явно трябва да сменям и аз гарнитури. За тези ли става въпрос (мотора е м62) http://c1552172.r72.cf0.rackcdn.com/59509_x800.jpg , http://c1552172.r72.cf0.rackcdn.com/53170_x600.jpg , ето схемата http://ww2.justanswer.com/uploads/Lrmin ... _valve.jpg , както и този гумен пръстен на стъпковото моторче (N 13 на схемата - http://www.realoem.com/bmw/showparts.do ... g=13&fg=15) . Кажете ако има още някоя друга гарнитура за смяна :)
...the perfect race car crosses the finish line in first place and then falls to pieces
40354
Мнение от RORO » 27 Май 2012, 18:20
Не знам дали си прочел цялата тема но, с риск да се повторя:Провери си клапана на картерните газове първо :idea: пък тогава влизай в тези....хиляда гарнитурки!
Кара: SR1 NORMANDY
Мнение от ddinobot » 27 Май 2012, 23:57
Това ли е въпросния клапан http://www.realoem.com/bmw/showphoto.do?id=11617501563 ?
40354
Мнение от RORO » 28 Май 2012, 9:14
Не ти работи линка.
Кара: SR1 NORMANDY
Мнение от ddinobot » 28 Май 2012, 10:04
http://forums.bimmerforums.com/forum/sh ... ?t=1521825 , аз си мислех че е ето тая джаджа
40354
Назад към Е38
