Непонятни за мен грешки
4 мнения
- Skorostrelko
- Регистриран на: 9.05.2007
- Кара: BMW E61 525d
Здравейте колеги,
Днес реших да направя диагностика (с Carly) на колата (Е61 525d 177к.с. 2004г.), защото не съм го правил отдавна и като видях броя на грешките (23) се стресирах. Най-лошото, е че само 1-2 от тях са ми ясни от какво са, но за другите нямам идея (тоест хващам някаква логика, но не съм сигурен в себе си
). Ще бъда благодарен, ако някой ми разясни някои от грешките. Ето и списъка:
1 - Intelligent Battery Sensor (DIBS1) Code: 004477
2 - Fuel filter Code: 004587
3 - Satellite center / Mitte:Resistance squib ZK 2 too big Code: 009AFF
4 - Instrument cluster / Kombiinstrument debuginfo combi Code: 00A557
5 - Central info display / Zentrales Display Communication: Can Low Code: 00E5C4
6 - Light / Licht disturbed communication with StepperMoterBox lef Code: 009CBC
7 - Air conditioning / Klimaanlage Embassy (KCAN: power management battery voltage 3BE) Code: 00E714
8 - K-CAN Physical bus error Code: 00E704
9 - CAS K CAN line fault Code: 00D904
10 - Error CAS supply Code: 00A0B2
11 - Power Module Coding (control unit uncoded) Code: 00A6A6
12 - Air suspension / Luftfederung K-CAN low Transceiver Code: 00D704
13 - Automatisches Front Steering Sensor supply motor position and position Code: 006136
14 - Veh Ref. Speed. Or direction uncertain or unavailable Code: 006139
15 - Supply voltage cl. 30 (<7.5 volts) Code: 00613A
16 - Redundancy comparison driver steering angle above Code: 006140
17 - uninitialized motor position angle Code: 00614A
18 - Embassy (steering wheel angle above, ID = 0C8) initialization Code: 00CE93
19 - Embassy (DSC control interventions, id = 11E) of DSC F-CAN Code: 00CE98
20 - Embassy (steering wheel angle above, ID = 0C8) of SSL F-CAN Code: 00CE99
21 - Embassy (Radtoleranzabgleich, ID = 374) of DSC PT-CAN Code: 00CE9A
22 - Embassy (DSC status, id = 19E) of DSC PT-CAN Code: 00CE9C
23 - Car Body Module RW CONTROL ERROR OFF Code: 00A443
От целия този списък ми е ясна първата грешка, защото съм откачил датчика за умното зареждане на акумулатора (прецакан е и трябва да взема нов). Без него зарежда постоянно с 14,7V. Втората грешка вероятно е от запушен горивен филтър (от много "хубава" нафта) и ще го сменя тези дни. Отностно грешките от 13 до 22 силно се надявам да се дължат на това, че не съм правил реглаж след преминаването от зимни на летни гуми. Както казах и по-горе се надявам някои да ми каже нещо повече за въпросните грешки, защото тук има доста хора с много добри познание. Благодаря предварително!
- vld
- Старши ентусиаст
- Регистриран на: 10.08.2005
- Кара: F11 535d, E84 2.3d
Re: Непонятни за мен грешки
Най вероятно всичките ти грешки са свързани с проблеми с напрежението.
За да е по ясно прочети колата с ИСТА, с това карли нищо не става....
- Skorostrelko
Днес прочетох колата с друга програма и резултата съм го прикачил. Има малко по-подробно инфо от карлито и доколкото разбрах май почти всички грешки идват от плюсовата клема на акумулатора, където е пиропатрона. По-късно или утре ще разкача всичко и почистя. Дано се оправят нещата...
- Denis yusein
- Регистриран на: 24.07.2018
- Местоположение: Бургас
- Кара: X1 Restyl,Suzuki Vitara,ATV-китайче
- Мечтае да кара: Повече в гората и на сняг.
- Детайли за колата: Вече има и 118d N47 в колекцията
Ако имаш проблем с пиропатрона в Бургас има едно момче което го шунтира и ти решава проблема
4 мнения
