325 генерация - превод
Модератор: bum_bum
3 мнения
- gotcha
- Регистриран на: 5.12.2007
- Местоположение: тухла в южните райони
- Кара: Diamantschwarz coupe
Колеги все повече ми наболява проблема за смяна на генерацията (мойта вече е пътник
) та реших да се разрова и по чуждите форуми. Намерих поста на един пич, който си е сложил къстъм генерация на 325 (Е36) обаче не мога да си ги преведа на 100% подробности и т.н.
Ако има някой навит да свърши тази работа, може и на други колеги да е от полза
Ето поста:
here's what i suggest!!! on my 93 325is i converted the dual setup to a single FULL 2 1/2" setup.
the muffler shop cut out the factory cat setup right where the two downpipes x together for the o2 sensor. it goes from there 2 1/2" to a single 3" resonator...........went with the 3" so it wouldn't hurt performance. after the resonator it goes back to 2 1/2" to a single/single out 2 1/2" flowmaster 40 series muffler. then to a single in dual out angled cut tip. he also cut the 02 sensor bung off of the factory setup and welded it on to the new setup.
i got pictures and if someone can host them on here i will show them.
1. cost---$230 out the dorr for everything!!!! can you say hell ya!!!!
2. sound---words can't describe......ok ya they can "unfriggen-believeable" sounds soooo much healthier. at idle it has a nice little girgle. at cruising there really isn't that anyoying drone sound at all. at wide open the thing just opens up and says "R-O-A-R!"
3. performance---i got an auto so all you fello slush box owners know how slow it is until about 20mph. i goined so much torque down low definitely noticable. and on the top end it pulls sooo much harder to red line!
i need to get some video action so you all can hear how good it looks and how retarded-awesome it sounds!!
this is by far the most noticable gain i have experinced besides the chip!
i would say everyone should do this mod it is welllll worth it!!!
nick
П.П. Мойта кочинка е 320, но имам мераци и аз да слагам 2.5 мотор, така че не мисля, че ще му е зле на моя и с тази генерация...
Ето поста:
nick
- S-stail
- Регистриран на: 27.12.2004
- Местоположение: Плевен
- Кара: м42б20 турбо
- Детайли за колата: hx35/40 twin scroll
- gotcha
S-stail написа:Тука една 320 мина на генерация от 325 и определено
живна малко
Това звучи добре
Да питам също така колко фи е стоковата генерация на б20 и колко х2 е стоковата на б25?
3 мнения
