малиииииии.... какъв хулуган
9 мнения
- RAFF
- Регистриран на: 19.07.2002
- Местоположение: гр.Бургас
GENERAL
Production time 1988 Base in BMW 3-series (E30)
Layout Front engine, Rear drive Tires Pirelli P700
front 235/45-ZR17
rear 265/40-ZR17
Length ??? Width ???
Height ??? Weight 1380 kg / 3036 lbs
Engine M5(M88) Inline 6 DOHC 24 val Wheelbase 2570 mm / 101.2 in
Displacement 3500 cc / 213.7 cu in Gearbox Getrag 5sp manual
Brakes Vented Discs w/ABS Price 63 300 DM
PERFORMANCE
Top speed 273 kph / 170 mph 0-100 kph / 0-62 mph 5.7 sec
1/4 mile / 400m 13.5 sec 0-200 kph / 0-124 mph 20.9 sec
Power 246 kw / 330 bhp @ 6800 rpm Torque 355 nm / 262 ft lbs @ 4500 rpm
More Info Based on the M3 and equipped with the 24-valve 3.5 litre engine from the M5, the Hartge H35-24 is a real street rod and from the moment you turn the key in the ignition you know that some serious performance is about to be delivered. The 93.4mm bore and 84mm stroke engine, produces 330 bhp at 6800 rpm with 355 nm of torque available at 4500 rpm. Again the engine has received the attention of the Hartge engineers with camshaft reprofiling and modifications to the Bosch Motronic injection system. Compression ratio is 10.7:1 Modifications include the company's own wild camshafts with longer lift and duration. The cylinder head is gasflowed with modified combustion chambers. It uses a thermo-static viscous drive cooling fan, seven bearing forged crankshaft with 12 balance weights and vibration damper. Bilstein sports suspension is again utilised on this car, lowering the already lowered M3 by a further Getrag 5-speed sports transmission with dog leg first gear is the standard item and well able to cope with the extra power. Like the H35, final drive ratio is 2.93:1. 25mm brakes have been beefed up by the addition of 301mm ventilated discs at the front mated to the ABS system. Putting the power on the tarmac are Hartge's 17" racing alloys, 7.5 at the front and 8.5 at the rear. These are shod with 235/45 Pirelli P700s forward and 265/40 P700s aft. Equipment included with this car includes front and rear aluminium strut braces, front spoke leather steering and a monoarm windscreen wiper.
- madpetio
Новият ПИКАСО
- Регистриран на: 29.04.2002
- Местоположение: гр.София
- Кара: The Dark Side of the Force
- Мечтае да кара: S
- Детайли за колата: E30 325i - RIP
E30 320is - RIP,sold
E24 635csi - sold
E36 316i coupe - sold
E46 320d sedan- sold
E36 325i coupe - sold
E36 318tds SW - sold
E36 316i sedan - sold
E39 525d sedan - sold
E46 320d SW - sold
E61 530xd LCI - sold
E30 318is coupe - sold
E46 320dA SW - sold
MB CLK270-sold
Е46 320Ci
E87
E30 320 cabrio
отг::малиииииии.... какъв хулуган
Тези HARTGE са бесни:):) E30 330hp луда работа!
BMW-DIESELPOWER
BMW-DIESELPOWER
- ati
- Акулчо Костенурков Нинджов
- Регистриран на: 7.08.2002
- Местоположение: The city of Angels;)
towa go ostawqme bes komentar,krasotata taka ili ina4e trudno se opiswa:)
Sashtoto takova BMW Hartge H35 se prodava ot dosta vreme v mobile, kato parvonachalno mai e bilo 6900DM (predi da smeniat parite) sega mu tarsiat 5K Euro.... mnogo zapazeno izglejda obache (30000kn samo)..... ...eeeeeh tia akcizi........
http://www.mobile.de/cgi-bin/search.pl? ... &x=44&y=16
DaWolf
'91 E30 318is '83 E28 520iA
DaWolf
Mdaa daa
Eto neshto podobno koeto e ispulneno s E46.. predpolagam nqma da vi haresa chak tolkova no vse pak...
RACING DYNAMICS R 50 Tornado V8 S
The 315 km/h high performance car based on the new M3.V8 engine from the M5 performance tuning to 500 hp / 368 kW at 7,400 rpmand a maximum torque of 605 Nm at 4,000 rpm.
Acceleration from 0 - 100 km/h takes just 4.2 seconds.
On the front axle the new tyres are driven in 245/30 ZR 20 dimension on three-piece RACING DYNAMICS RS2 8.5Jx20 wheels. On the rear 285/25 ZR 20 tyres on 10Jx20 wheels take care of maximum traction.
price: 299,000 DM huhuhu
BURN!
BURN!
9 мнения
