Малко съкращения...
3 мнения
- simple_man
- 323i Killer
- Регистриран на: 24.07.2002
- Кара: E30 316i '91, G21 320d M-Sport
- Мечтае да кара: G81 M3
Малко съкращения...
Това са съкращенията или по-точно термините в света на автомобилизма.
4WD - Four Wheel Drive
4WS - Four Wheel Steering
ABC - Active Body Control
ABS - Anti Blokier System
AC - Air Condition
ACC - Active Cruise Control
AGS - Adaptive Gearbox Shift
ALB - Anti Lock Braking
ASC - Automatic Stability Control
ASC+T - Automatic Stability and Traction Control
ASMS- Automatic Stability Management System
ASR- Anti Schlupf Regelung
ATM -Adaptive Transmission Management
AUC -Automatische Umluft Control
AWD- All Wheel Drive
BAS -Brake Assyst
BST -Battery Safety Terminal
CAN- Controller Area Network
CDI - Common-rail Diesel Injection
CFI -Central Fuel Injection
CNG -Compressed Natural Gas
CVT- Continously Variable Transmission
DBC -Dynamic Brake Control
dCi -diesel Commonrail injection (Renault)
DDE -Digital Diesel Electronics
DISA -Differenzierte Sauganlage sistem
DOHC- Double Over Head Camshaft
DME- Digital Motor Electronics
DSA -Dynamic Stability Assistance
DSC -Dynamic Stability Control
DSTC- Dynamic Stability & Traction Control
dTi ..-dizel Turbo intercooler
DTI -Dizel Turbo Intercooler
EBD -Electronic Brakeforce Distribution
EBV- Elektronische Bremskraft Verteilung
ECU-Engine Control Unit
EDC -Electronic Damper Control
EDC -Electronic Diesel Control
EDS -Elektronische Differencialsperre
EFI- Electronic Fuel Injection
EG- European Gas
EGR- Exhaust Gas
EMC -ElectroMagnetic Compatibility
EPS -Electronic Power Steering
ESP -Electronic Stability Program
ETC -Electronic Traction Control
ETS- Electronic Tracion System
EV -Electric Vehicle
FDR- Fahr Dynamik Regelung
FFV- Flexible Fuel Vehicle
FIRE -Fully Integrated Robotized Engine
F.I.R.S.T.- Fully Integrated Road Safety Technology
FPS -Fire Protecting System
GDI- Gasoline Direct Injection (Mitsubishi)
GPS -Global Positioning System
HDC- Hill Descent Control
HDi .- High-pressure Direct Injection
HP -Horse Power
HPi -... ... injection
i, I- Injection
IC- Inflatable Curtain
ICIM -Individual Control Intake Mainfold
IMS- Instant Mobility System
IRD -Intermediate Reduction Drive
ISOFIX -International Standard Organization FIX
ITS -Inflatable Tubular Structure
JTD- uniJet Turbo Diesel
KW- Kilowatt
LSD -Limited Slip Differential
MPI- Multi Point Injection
NGV- Natural Gas Vehicle
OBD- o n Board Diagnostic
PDC- Park Distance Control
PES -Poli Elipsoid System
PPD- Passenger Presence Detection
PRS- Programmed Restraint System
SIPS -Side Impact Protection System
SDI- Standard Diesel Injection
SMH- Societe de Microelectronique et d'Horlogerie
SOHC- Single Over HeadCamshaft
SPI -Single Point Injection
SRS -Supplemental Restraint System
STC -Stability & Traction Control
TC -Traction Control
TCS- Traction Control System
TDI- Turbo Diesel
VANOS- Variable Nockenwelle Steuerung
VDC -Vehicle Dynamic Control
VIS -Variable Induction System
VTEC- Variable valve Timing and lift Electronic Control system
VVT-i Variable Valve Timing - intelligent
WHIPS -WHiplash Protection System
WET W- Engineered Tread
AC - Air Condition
BAS -Brake Assyst
EG- European Gas
EGR- Exhaust Gas
HP -Horse Power
i, I- Injection
KW- Kilowatt
TDI- Turbo Diesel
- BMWMHartge
- Регистриран на: 12.09.2003
- Местоположение: с.Градина/гр.Първомай
- Кара: 98' e36 318i
- Мечтае да кара: e36 ///M3
- Детайли за колата: M43B18
- DEFLEPPARD
- Регистриран на: 4.04.2003
- Кара: BMW F30 335I xDrive
- Мечтае да кара: M12 nasca, e31 850CSI, e30 M3
за модераторите...
не че е моя работа ама мисля че би било добре ако модераторите изтрият всички допълнително отговори и да заключат темата някъде най-отгоре.. или в тхе бест оф
3 мнения
