BMW Engine Specifications
Регистриран на: 24.06.2005
Мнение от tsb_bg » 10 Фев 2008, 23:00
Колеги тук е събрана техническата спецификация на различни двигатели на BMW и годините през които са влагани в различните модели на марката (подредени по азбучен ред)
M10
Straight 4 cylinder SOHC 8V. 1966-1987. 83kg 180lbs
Used in 1502, 1600-2, E21 316/318i/320-4, E30 316, 2002tii and 2002 turbo
1.5 (75bhp), 1.6 (85bhp), 1.8 (90-98bhp), 2.0 (100bhp), 2.0i (125bhp), 2.0tii (130bhp), 2.0turbo (170bhp)
M20
Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs
Used in E21 320, E21 320i/6, E28, E30, E34, E21/30 323i, E30 325e and E28 528e
2.0i (129bhp), 2.3i (143bhp), 2.5i (170bhp), 2.7e (125bhp)
M21
straight 6 SOHC 12V Diesel. 1983-1991 126kg 278lbs
Used in 324td, 524d/td
2.4 (112bhp), 2.4 Turbo (115bhp)
M30
Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs
Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535
2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp)
M40
Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs
Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i
1.6 (102bhp), 1.8 (122bhp)
M41
Straight 4 SOHC 8V Diesel. 1995-on. 108kg 238lbs
Used in E36 318tdS
1.7 Turbo (90bhp)
M42
Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs
Used in E30 and E36 318is, Z3
1.8 (138-142bhp)
M43
Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs
Used in post-93 E36 316i/318i, E34/39 518i.
1.6 (102bhp), 1.8 (115bhp)
M43TU
Straight 4 SOHC 8V. 1998 on. 83kg 183lbs
Used in E46 318i
1.9 (118bhp)
M44
Straight 4 DOHC 16V. 1996 on. 102kg 225lbs
Used in E36 318iS, Z3
1.9 (142-150bhp)
M47
Straight 4 DOHC 16V Diesel. 1998-on. 117kg 258lbs
Used in E46 320d
2.0 Turbo (136bhp)
M50/M50TU
Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs
Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3
2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine.
M51
Straight 6 SOHC 12V Diesel. 1995-on. 132kg 291lbs
Used in E36 325td/S, E34 and E39
2.5 Turbo (115bhp), 2.5 Intercooled Turbo (143bhp)
M52/M52TU
Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe . 118kg 260lbs (alloy) 140kg 308lbs
Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3.
2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S52, but is a motorsport engine.
M54
Straight 6 DOHC 24V with Dual VANOS. 2000-present. 126kg 277lbs
Used in late model Z3, all E39 and E46 six cylinder models
2.0 (150bhp), 2.2 (170bhp), 2.5 (184-192bhp), 2.8 (193bhp), 3.0 (231bhp)
M55
Straight 6 DOHC 24V Diesel. 2000-on. 132kg 291lbs
Used in E46 and E39s.
2.5 Turbo (170bhp), 3.0 Turbo (183bhp)
M56
Straight 6 DOHC 24V Dual VANOS with ULEV. 2002-present. 127kg 280lbs
Used in some E39 and E46 six cylinder models
2.5 (184bhp)
M60
V8 DOHC 32V. 1992-1996. 146kg 321lbs
Engine blocks were made of Nikasil (Silicone Injected Nickel) which were prone to failure over time. Many have been replaced with the newer Alusil (Silicone injected Aluminum) engines/
Used in E34 530i, E32 730i, 740i, 840i
3.0 (218bhp), 4.0 (286bhp)
M62/M62TU
V8 DOHC 32V/V8 DOHC 32V Single VANOS. 1996-present. Alusil Engine block. Pre 98 engines were non-VANOS. 140kg 308lbs
Used in E38 730i/740i, E39 540i, X5 and 840i
3.5 (235bhp), 4.4L (286bhp), 4.6 (340bhp)
M67
V8 DOHC 32V Diesel. 1999-on. 192kg 423lbs
Used in E38 740d
4.0 Turbo (245bhp)
M70
V12 SOHC 24V. 1988-1994. 155kg 341lbs
Used in E32 750il, 850i
5.0 (300bhp)
M73
V12 SOHC 24V Single VANOS. 1995-2001. Pre 98 engines were non-VANOS. 150kg 330lbs
5.4L (326bhp)
M102
Straight 6 cylinder SOHC 12V Turbo. Big Six Turbo. 1984-1986. 145kg 320lbs.
Used only in the E23 745i
3.2L or 3.4L Turbo (252bhp)
N44TU
Straight 4 DOHC 16V Dual VANOS with Valvetronic
Used in E46 318i
1.6 (115bhp), 1.8 (143bhp)
N62
V8 DOHC 32V Dual VANOS with Valvetronic
Used in E65 745i
4.4 (325bhp)
N73
V12 DOHC 48V Dual VANOS with Valvetronic
Used in E65 760i
6.0 (438bhp)
S14
Straight 4 DOHC 16V Solid Lifter Valvetrain and Individual Throttle Bodies. 1987-1991. 106kg 234lbs
Used in the E30 M3 and Italian only E30 320is
2.0L (195bhp) 2.3L (192-200bhp), 2.5L (215-238bhp)
S38 - Original (Also known as M88 and M88/3)
Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1979-1980, 1986-1990. 146kg 321lbs
Used in M1, E28 M5, M6, SA E23 745i
3.5L (277-286bhp)
S38 - Updated
Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1988-1996. 151kg 332lbs
Used in E34 M5
3.6 (315bhp), 3.8 (340bhp)
S50
Straight 6 DOHC 24V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies. (Dual Vanos on 3.2Ls) 1992-2000. 152kg 333lbs
Used in non-US E36 M3
3.0 (286bhp), 3.2L (321bhp)
S54
Straight 6 DOHC 24V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 2001-present. 148kg 326lbs
Used in the E46 M3 and the last of the Z3 M-Coupe and M-Roadster.
3.2 (321-343bhp)
S62
V8 DOHC 32V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 1999-present. 158kg 348lbs
Used in E39 M5 and Z8
4.9L (400bhp)
S70
V12 SOHC 24V. 1995-1997. 165kg 363lbs
Used in 850CSi
5.6L (380bhp)
S70/2 Used in McLaren F1 (Was originally developed for M8)
Type 6.1 liter, 48 valve V-12 with aluminum block and heads, 627 bhp
Bore and stroke 3.38 x 3.41 in (86 x 87 mm)
Weight 266Kg
Displacement 370 cubic in, 6064 cc
Compression ratio 10.5:1
Engine control system Bosch Motronic with port fuel injection
Emissions controls 3-way catalytic converter feedback fuel-air-ratio control auxiliary air pump
Valve gear Chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake timing Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies
Power (SAE net) 618 bhp @ 7400 rpm
Torque (SAE net) 479 ft-lb @ 4000 rpm
Redline 7500 rpm
W10
Straight 4 SOHC 16V
Used in Mini One, Mini Cooper
1.6 (90-115bhp)
W11
Straight 4 SOHC 16V with Eaton Supercharger
Used in Mini Cooper S
1.6 Supercharged (163bhp)
Информацията е от тук:
http://www.bimmerforums.com/engine_faq/
Регистриран на: 9.02.2007
Местоположение: Sofiq
Мнение от acho.rs » 11 Фев 2008, 0:34
Браво !!! Сега има да си пълня глвата с цифри докато ум ми зайде :)
Сватбаря
Регистриран на: 25.04.2002
Кара: Opel Zafira А OPC
Мнение от Penchev » 11 Фев 2008, 0:52
Защо не е писан М106 отделно а са го сложили при 3,2 литровото желязо :?: :roll:
Георги Пенчев
Регистриран на: 30.08.2007
Re: BMW Engine Specifications
Мнение от slav4o1 » 11 Фев 2008, 1:50
на този саит има повече инфо: http://www.vrchlabi.cz/e30/ruzne/enginenumber/
Регистриран на: 5.12.2007
Местоположение: тухла в южните райони
Кара: Diamantschwarz coupe
Мнение от gotcha » 11 Фев 2008, 22:59
Това ако не е американщина те па на :mhihi:
Mens sana in corpore sano
Регистриран на: 19.01.2006
Мнение от jailbreaker » 14 Фев 2008, 0:11
Това май и за важна тема минава, а ?
Winners never quit. Quitters never win. But those who never quit AND never win are IDIOTS.
главен сектант :)
Регистриран на: 3.01.2004
Местоположение: Лондон
Кара: E36 325i
Детайли за колата: Септември 1991
M50B25 - Без VANOS
GAZ Gold Coilover Kit
Eibach 28мм Предна Стабилизираща Щанга
М3 Ево 20мм Задна Стабилизираща Щанга
325мм предни спирачки от Е46 330i
294мм задни спирачки от Е46 328i
Zimmermann Дискове, Carbone Lorraine накладки, Goodridge маркучета
Мнение от WeiSTD » 14 Фев 2008, 0:19
gotcha написа:Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs
На всякъде му викат така. Това име просто го различава от М30 ;) Ако беше Американщина и на S70 щяха да му викат Бейби, а на М20 Микро или нещо от сорта. :mhihi:
БИАД Авто-Пазар Тийм
You can take the people out of Bulgaria, but you can never take the Bulgarian out of people.
Мнение от gotcha » 14 Фев 2008, 0:29
Mерси много за инфото, но просто звучи ужасно :mhihi:
Защо просто не си им казват М20 и М30, а трябва да се ползват "псевдоними" :roll:
главен сектант :)
Кара: E36 325i
M50B25 - Без VANOS
Мнение от WeiSTD » 14 Фев 2008, 11:01
gotcha написа:Mерси много за инфото, но просто звучи ужасно :mhihi:
Ми то по тая логика, най добре да се представям като 841207**** :mhihi:
Бургаското явление
Регистриран на: 21.07.2007
Местоположение: Бургас/София
Мнение от Illusion » 14 Фев 2008, 11:13
Penchev написа:Защо не е писан М106 отделно а са го сложили при 3,2 литровото желязо :?: :roll:
Георги Пенчев
И на мен това ми направи впечатление. :roll:
А и за М06, но инфото не е пълно просто ;)
Mishel_Vaian написа:Качвайте се на бързи ИС-ки. И отзад возете яки Миски. Жените от мотори не разбират.Те колите по цвят избират
Само Илюжън не може се прекара да опита ИС-ка тя да кара
Регистриран на: 19.12.2007
Местоположение: Стара Загора
Кара: е34
Мечтае да кара: е32
с
Мнение от BeXTMaN » 14 Фев 2008, 11:30
темата е супер яка и полезна евала на автора :have one:
Мафиозо!
Регистриран на: 1.04.2003
Мнение от rado_rf » 25 Фев 2008, 21:17
М60/В20 нещо не го видях никъде. :evil:
Не знам откъде я копи-пействате тая информация напоследък, ма всеки пълни с глупости. Колкото верни, толкова и неверни данни :confused: И в крайна сметка изпадаме в смешни ситуации и се чудим на кой да вярваме и на кой не.
"Няма нищо по-хубаво от това да се изсереш на метеното и няма нищо по-лошо от това да метеш изсраното" - древна мъдрост
Мечтае за Z3 M Coupe
Регистриран на: 9.02.2003
Местоположение: Сoфия
Кара: '99 530dА Touring
Мнение от err0r » 25 Фев 2008, 21:21
rado_rf написа:М60/В20 нещо не го видях никъде...
Някъде бях чел и за М60Б23, ма може да е туник...
Мафиозо!
Мнение от rado_rf » 25 Фев 2008, 21:31
err0r написа:
М60/В20 са преди М20/В20. Искам да кажа, че в началото преди да сложат индекса М20 е бил сложен индекса М60.
Понял?
Мнение от tsb_bg » 28 Фев 2008, 17:20
Аз никъде не съм срещал М60/В20
Това което намерих за М60 е:
От 1992 година:
В30 The 3-liter develops 160 kW at 5800 rpm and 288 Nm at 4500 rpm.
В40 The 4-liter develops 210 kW at 5800 rpm and 400 Nm at 3900 rpm.
От 1997 година:
В30 The 3.5-liter develops 180 kW at 5800 rpm and 345 Nm at 3800 rpm.
В40 The 4.4-liter develops 210 kW at 5400 rpm and 440 Nm at 3600 rpm.
http://www.usautoparts.net/bmw/engines/m60.htm
Назад към Основен Форум
