Размери на говорителите в различните модели БМВ
Или всичките неща, които можем да натъпчем в един автомобил.
Модератор: Icco
Регистриран на: 3.04.2003
Кара: Каквото ми попадне .
Мнение от AGT » 15 Дек 2009, 18:17
Не са всички ,но се надявам ,че все на някой ще свършат работа.
1"= 2,54см
BMW E36 Coupe/Sedan w/ Standard:
5.25" Front Midbass
2.5" Front Midrange
~5/8 Front Tweeter
4" Rear Midbass - Inside Enclosure
~5/8 Rear Tweeter - Inside Enclosure
BMW E36 Coupe/Sedan w/ HK(Premium)
5.25" Front Midbass
2.5" Front Midrange
~5/8 Front Tweeter
6x9" Rear Midbass - Inside Enclosure
BMW E36 Cabrio w/ Standard
5.25" Front Midbass
2.5" Front Midrange
~5/8 Front Tweeter
4" Rear Midbass
~5/8 Rear Tweeter
BMW E36 Cabrio w/ HK(Premium)
5.25" Front Midbass
2.5" Front Midrange
~5/8 Front Tweeter
5.25" Rear Midbass
~5/8 Rear Tweeter
~8" Subwoofer in Ski Pass
BMW E46 Coupe w/ Standard
6.25" Front Midbass - 3 prong mount
2.5" Front Midrange - Shared Housing w/ Tweeter
3/4" Front Tweeter
2.5" Rear Midrange
6.25" Rear Midbass - 3 prong mount
BMW E46 Coupe w/ HK(Premium)
3/4" Front Tweeter
2.5" Rear Midrange
2x 6x9 Subwoofers - Rear Deck
BMW E46 Sedan w/ Standard
2.5" Front Midrange
3/4" Front Tweeter
2.5" Rear Midrange
BMW E46 Sedan w/ HK(Premium)
2.5" Front Midrange
3/4" Front Tweeter
2.5" Rear Midrange
BMW E46 Convertible w/ Standard
3/4" Front Tweeter
~4" Rear Midbass - 3 prong + Shared Housing w/ Tweeter
3/4" Rear Tweeter
BMW E46 Convertible w/ HK(Premium)
6.25" Front Midbass
2.5" Front Midrange - 3 prong mount
3/4" Front Tweeter
3/4" Rear Tweeter
~10" Subwoofer In Ski Pass
BMW E39 w/ Standard
5.25" Front Midbass
2" Front Midrange - Silk Dome
~5/8" Front Tweeter
5.25" Rear Midbass
~5/8 Rear Tweeter
BMW E39 w/ DSP(Premium)
5.25" Front Midbass
~5/8" Front Tweeter
5.25" Rear Midbass
~5/8 Rear Tweeter
2x ~5" High Efficiency/High Excursion OEM Subwoofers - Hung from Rear Deck
BMW E38 w/ DSP(Premium)
5.25" Front Midbass
~5/8" Front Tweeter
5.25" Rear Midbass
~5/8 Rear Tweeter
4x ~5" High Efficiency/High Excursion OEM Subwoofers - Located In Rear Deck
BMW X5 E53 w/ Standard
~6" Front Midbass - Inside Enclosure in Door
2.5" Front Midrange - Inside Front Dash
3/4" Front Tweeter
~6" Rear Midbass - Inside Enclosure in Door
2.5" Rear Midrange
2x ~5" High Efficiency/High Excursion OEM Subwoofers in enclosure - Passenger Side Rear Hatch Mounted - Not all Standard have OEM Subwoofer
BMW X5 E53 w/ DSP(premium)
3/4" Front Tweeter
2.5" Rear Midrange
BMW E34 - Early Model vehicles are Common Ground
5.25" Front Midbass
~5/8" Front Tweeter
5.25" Rear Midbass - Shared Housing in Rear Deck w/ Tweeter
~5/8 Rear Tweeter
BMW E32
5.25" Front Midbass
~5/8" Front Tweeter
~5/8 Rear Tweeter
BMW E30 w/ Standard - Common Ground System
5.25" Front 2-Way/Coaxial Driver - Front Kick Panel
5.25" Rear 2-Way/Coaxial Driver - Rear Deck *Warning* Have Seen 4" OEM Drivers in this location
BMW E30 w/ Premium - Common Ground - SMALL OEM Amp
5.25" Front Midbass - Front Kick Panel
~5/8" Front Tweeter - Mirror Sail Mounted
5.25" Rear Midbass - Rear Deck - Shared Enclosure w/ Tweeter
~5/8" Rear Tweeter
BMW E28 w/ Standard - Common Ground System
BMW E28 w/ Premium - Common Ground - SMALL OEM Amp
~5/8" Rear Tweeter
BMW E90 Sedan/Coupe w/ Standard
4x 4" Midrange Drivers - 3 prong mount
4x 25mm
2x 8" Subwoofers - One under each front seat - Have seen base/standard cars with no underseat subwoofers
BMW E90 Sedan/Coupe w/ Logic 7
6x 4" Midrange Drivers - 3 prong mount
4x 25mm
1x 4" Midrange Driver - Center Channel - Dash Mount - 3 prong mount
BMW E60 Sedan w/ Standard
4x 25mm
BMW E60 Sedan w/ Logic 7
4x 25mm
Съвет от КАТ !
Назад към Car аудио и видео
