Аудио Е30 цветове
Модератор: Icco
1 мнение
- Кара: конете да бягат
Аудио Е30 цветове
На някой може и да му е полезно, аз си изгубих 1 ден докато разбера кое какво е...
Yellow/Red - Left front + (found on fader in dash)
Yellow/Black - Left rear + (found on fader in dash)
Blue/Red - Right front + (found on fader in dash)
Blue/Black - Right rear + (found on fader in dash)
Yellow/Brown - Left channel ground (found on connector at radio)
Blue/Brown - Right channel ground (found on connector at radio)
Brown - Head unit ground (found on connector at radio)
Grey/Violet - Switched 12Volts (found on connector at radio)
Grey/Red - 12Volts switched on with lights (found on connector at radio)
Green/Red - Constant 12Volts (found on connector at radio)
White - Power antenna feed (found on connector at radio)
1 мнение
