Кодове за грешки в Модулите
45 мнения
• Страница 2 от 3 • 1, 2, 3
DDE 2.2
$F0
00 Undefined error
$H0
00 Undefined error
$F1
01 Delivery-controller control deviation
$H1
$F3
03 Electric cut-off valve
$H3
$F4
04 Glow indication (DDE error lamp)
$H4
$F5
05 Needle-motion sensor
$H5
$F6
06 Exhaust gas recirculation, control deviation
$H6
$F7
07 Exhaust-gas-recirculation map
$H7
$F8
08 Glow-duration control
$H8
$F9
09 DDE control unit Error number 09
$H9
$F10
10 Start-of-injection control deviation
$H10
$F11
11 DDE control unit Error number 11
$H11
$F15
15 DDE main relay
$H15
15 DDE main relay
$F16
16 Supply voltage (batt. +)
$H16
$F20
20 Cruise control operation panel
$H20
$F21
21 DDE control unit Error number 21
$H21
$F23
23 Port connection to the air-conditioning
$H23
$F25
25 Pedal value transmitter
$H25
$F26
26 Brake-light switch/brake-light test switch
$H26
$F28
28 Gear box switch (P/N or gear box switch)
$F28
$F29
29 Road-speed signal
$F29
$F30
30 FGR main switch
$H30
30 FGR main switch
$F31
31 Brake-light test switch
$H31
$F32
32 Control panel, cruise control, on multifunction steering wheel
$H32
$F35
35 Fuel temperature sensor
$H35
$F36
36 Engine-oil temperature sensor (Water level sensor)
$H36
$F37
37 Pedal-travel sensor
$H37
$F38
38 Hot-film air-mass flow sensor
$H38
$F42
42 Diagnose socket
$H42
42 Diagnose socket
$F44
44 Air conditionings switch
$H44
$F45
45 Port connection to the immobilize system
$H45
$F46
46 DDE control unit Error number 46
$H46
$F47
47 Engine-speed sensor
$H47
$F49
49 Port connection to the instrument cluster
$H49
$F52
52 Intake air temperature sensor
$H52
$F53
53 Engine-coolant temperature sensor
$H53
$F54
54 Charge-air-pressure sensor
$H54
$F56
56 Fuel begin
$H56
56 Fuel begin
$F58
58 Injection Quantity
$H58
$F59
59 Charge pressure control
$H59
$F60
60 Power supply
$H60
60 Power supply
$F63
63 Cruise control adjustment1
$H63
$F64
64 DDE control unit Error number 64
$H64
$F66
66 Fuel supply
$H66
66 Fuel supply
$F67
67 Air supply
$H67
67 Air supply
$F100
100 No cruise control adjustment
$H100
$F101
101
$H101
101
$F102
102 Control unit error
$H102
$F106
106 Power stage
$F106
106 Power stage
$F108
108 Variant coding
$H108
108 Variant coding
$F109
109 Variant coding
$H109
109 Variant coding
$F110
110 Air-conditioning is not at all or bad operating
$H110
$F111
111 EEPROM checksum, injection-pump adjustment
$H111
$F112
112 CAN bus to EGS control unit
$H112
$F113
113 CAN bus to ASC control unit
$H113
$F0
00 Undefined error
$H0
00 Undefined error
$F1
$H1
$F3
$H3
$F4
$H4
$F5
$H5
$F6
$H6
$F7
$H7
$F8
$H8
$F9
$H9
$F10
$H10
$F11
$H11
$F15
15 DDE main relay
$H15
15 DDE main relay
$F16
$H16
$F20
$H20
$F21
$H21
$F23
$H23
$F25
$H25
$F26
$H26
$F28
$F28
$F29
$F29
$F30
30 FGR main switch
$H30
30 FGR main switch
$F31
$H31
$F32
$H32
$F35
$H35
$F36
$H36
$F37
$H37
$F38
$H38
$F42
42 Diagnose socket
$H42
42 Diagnose socket
$F44
$H44
$F45
$H45
$F46
$H46
$F47
$H47
$F49
$H49
$F52
$H52
$F53
$H53
$F54
$H54
$F56
56 Fuel begin
$H56
56 Fuel begin
$F58
$H58
$F59
$H59
$F60
60 Power supply
$H60
60 Power supply
$F63
$H63
$F64
$H64
$F66
66 Fuel supply
$H66
66 Fuel supply
$F67
67 Air supply
$H67
67 Air supply
$F100
$H100
$F101
101
$H101
101
$F102
$H102
$F106
106 Power stage
$F106
106 Power stage
$F108
108 Variant coding
$H108
108 Variant coding
$F109
109 Variant coding
$H109
109 Variant coding
$F110
$H110
$F111
$H111
$F112
$H112
$F113
$H113
DDE 3.0
$F1
01 Quantity regulator
$H1
$F3
03 Electric cut-off valve : ELAB
$H3
$F5
05 Needle motion sensor
$H5
$F6
$H6
$F8
08 Glow system
$H8
08 Glow system
$FA
0A Delivery-controller control deviation
$HA
$F10
10 Power Supply
$H10
10 Power Supply
$F11
11 DDE Control Unit (2,5 V)
$H11
$F12
12 Tension : PIN 15
$H12
12 Tension : PIN 15
$F13
13 DDE Main Relay
$H13
13 DDE Main Relay
$F1A
1A Break light switch / Break switch
$H1A
$F1C
1C Clutch Switch
$H1C
1C Clutch Switch
$F1D
1D Vehicle speed signal
$H1D
$F20
20 Vehicle speed regulation : Control panel
$H20
$F23
23 Fuel temperature sensor
$H23
$F24
24 Engine oil temperature sensor
$H24
$F25
25 Pedal value sensor : PWG
$H25
$F26
26 Air-mass flow sensor
$H26
$F2D
2D Electronic Immobilise System : EWS
$H2D
$F2E
2E Injection pump RPM sensor
$H2E
$F2F
2F Crankshaft RPM sensor
$H2F
$F34
34 Temperature sensor
$H34
$F35
35 Coolant temperature sensor
$H35
$F36
36 Charge pressure sensor
$H36
$F40
40 DDE Control Unit (Microprocessor)
$H40
$F41
41 Magnetic cut-off valve
$H41
$F42
42 DDE Control Unit (EEPROM und Configuration)
$H42
$F43
43 Injection pump control unit
$H43
$F44
44 Magnetic valve
$H44
44 Magnetic valve
$F45
45 DDE Control Unit (CAN-Controller)
$H45
$F46
46 Injection pump (Communication)
$H46
$F47
47 Synchronicity from Impulse RPM sensor
$H47
$F48
48 Fuel injection Regulation
$H48
$F49
49 Rotational speed sensor injection pump
$H49
$F50
50 Engine lager actuation
$H50
$F52
52 Engine ventilator actuation
$H52
$F56
56 Coolant van actuation
$H56
$F64
64 DDE Control Unit (Micro controller)
$H64
$F65
65 Charge pressure regulation
$H65
$F6B
6B Atmosphere pressure sensor
$H6B
$F72
72 CAN-BUS
$H72
72 CAN-BUS
$F74
74 Air flow sensor geometrie
$H74
$F73
73 RPM sensor injection pump
$H73
$F78
78 Air flow sensor geometrie
$H78
$F85
85 Coolant van actuation actuation
$H85
$F1
$H1
$F3
$H3
$F5
$H5
$F6
$H6
$F8
08 Glow system
$H8
08 Glow system
$FA
$HA
$F10
10 Power Supply
$H10
10 Power Supply
$F11
$H11
$F12
12 Tension : PIN 15
$H12
12 Tension : PIN 15
$F13
13 DDE Main Relay
$H13
13 DDE Main Relay
$F1A
$H1A
$F1C
1C Clutch Switch
$H1C
1C Clutch Switch
$F1D
$H1D
$F20
$H20
$F23
$H23
$F24
$H24
$F25
$H25
$F26
$H26
$F2D
$H2D
$F2E
$H2E
$F2F
$H2F
$F34
$H34
$F35
$H35
$F36
$H36
$F40
$H40
$F41
$H41
$F42
$H42
$F43
$H43
$F44
44 Magnetic valve
$H44
44 Magnetic valve
$F45
$H45
$F46
$H46
$F47
$H47
$F48
$H48
$F49
$H49
$F50
$H50
$F52
$H52
$F56
$H56
$F64
$H64
$F65
$H65
$F6B
$H6B
$F72
72 CAN-BUS
$H72
72 CAN-BUS
$F74
$H74
$F73
$H73
$F78
$H78
$F85
$H85
DDE 4.0
$F0100
0100 Air-mass flow sensor
$H0100
$F0105
0105 Atmosphere pressure sensor - (Integrated in the control unit)
$H0105
$F0110
0110 Intake air temperature sensor - Signal
$H0110
$F0115
0115 Coolant temperature sensor
$H0115
$F0120
0120 Pedal value sensor 1
$H0120
$F0190
0190 Rail pressure sensor
$H0190
$F0200
0200 Injector Cylinder 1
$H0200
$F0201
0201 Injector Cylinder 5
$H0201
$F0202
0202 Injector Cylinder 3
$H0202
$F0203
0203 Injector Cylinder 6
$H0203
$F0204
0204 Injector Cylinder 2
$H0204
$F0205
0205 Injector Cylinder 4
$H0205
$F0220
0220 Pedal value sensor 2
$H0220
$F0235
0235 Charge pressure sensor
$H0235
$F0335
0335 Crankshaft RPM
$H0335
0335 Crankshaft RPM
$F03E6
03E6 Exhaust gas feedback activation regulation
$H03E6
$F0400
0400 Exhaust gas feedback
$H0400
$F0404
0404 Exhaust gas feedback 2
$H0404
$F0480
0480 Elektro ventialtor
$H0480
$F0500
0500 Vehicle speed sensor signal faulty
$H0500
$F0560
0560 Internal reference tension
$H0560
$F0600
0600 DDE control unit (CAN Controller)
$H0600
$F0605
0605 DDE control unit (Micro controller)
$H0605
$F1190
1190 Rail pressure regulation
$H1190
$F1195
1195 Rail pressure sensor
$H1195
$F1250
1250 Relay delivery pump
$H1250
$F1255
1255 Delivery pump pressure sensor
$H1255
$F1260
1260 Delivery pump control system
$H1260
$F1470
1470 Charge Pressure Regulation
$H1470
$F1612
1612 Easre correction regulation
$H1613
$F1613
1613 Coolant heating
$H1613
$F1640
1640 DDE Control Unit (EEPROM und Configuration)
$H1640
$F1A04
1A04 Extra electrical heater
$H1A04
$F1DF0
1DF0 Redundant Emergency Stop
$H1DF0
$F1DF5
1DF5 Electronic immobilize system - Timeout
$H1DF5
$F1E00
1E00 CAN - Bus reception from ASC disturbed
$H1E00
$F1E05
1E05 Vehicle speed sensor : control panel
$H1E05
$F1E25
1E25 RPM Control
$H1E25
1E25 RPM Control
$F1E30
1E30 Charge pressure regulation or charge pressure actuator
$H1E30
$F1E31
1E31 Charge pressure regulation
$H1E31
$F1E35
1E35 Error in delay during switch off over 0 or zero mass
$H1E35
$F1E40
1E40 Analogue / Digital converter - test tension
$H1E40
$F1E45
1E45 Codensator tension 1 for Cylinder 1, 2, 3
$H1E45
$F1E50
1E50 Codensator tension 2 for Cylinder 4, 5, 6
$H1E50
$F1E55
1E55 RPM Control
$H1E55
1E55 RPM Control
$F1E60
1E60 Power supply pedal way sensor 1
$H1E60
$F1430
1430 Charge pressure or chare pressure actuator
$H1430
$F2800
2800 Power Supply
$H2800
2800 Power Supply
$F3000
3000 Brake Light - /Brake test switch
$H3000
$F3005
3005 Terminal 15
$H3005
3005 Terminal 15
$F3505
3505 Glow system
$H3505
3505 Glow system
$F3506
3506 Glow system 2
$H3506
3506 Glow system 2
$F3510
3510 DDE Main Relay
$H3510
3510 DDE Main Relay
$F3515
3515 Airco Power Output
$H3515
$F3520
3520 Engine lager actuation
$H3520
$F3565
3565 Current switch off valve at high pressure pump
$H3565
$F3580
3580 Switch off valve at high pressure pump
$H3580
$F3596
3596 Brake light switch
$H3596
$F3600
3600 Atmosperic pressure sensor
$H3600
$F3605
3605 HFM Air Flow Sensor 1 or 2
$H3605
$F3610
3610 Exhaust gas feedback system (AGR)
$H3610
$F3615
3615 Exhaust gas feedback system - regulation (AGR)
$H3615
$F3620
3620 Air flow system error
$H3620
$F0100
$H0100
$F0105
$H0105
$F0110
$H0110
$F0115
$H0115
$F0120
$H0120
$F0190
$H0190
$F0200
$H0200
$F0201
$H0201
$F0202
$H0202
$F0203
$H0203
$F0204
$H0204
$F0205
$H0205
$F0220
$H0220
$F0235
$H0235
$F0335
0335 Crankshaft RPM
$H0335
0335 Crankshaft RPM
$F03E6
$H03E6
$F0400
$H0400
$F0404
$H0404
$F0480
$H0480
$F0500
$H0500
$F0560
$H0560
$F0600
$H0600
$F0605
$H0605
$F1190
$H1190
$F1195
$H1195
$F1250
$H1250
$F1255
$H1255
$F1260
$H1260
$F1470
$H1470
$F1612
$H1613
$F1613
$H1613
$F1640
$H1640
$F1A04
$H1A04
$F1DF0
$H1DF0
$F1DF5
$H1DF5
$F1E00
$H1E00
$F1E05
$H1E05
$F1E25
1E25 RPM Control
$H1E25
1E25 RPM Control
$F1E30
$H1E30
$F1E31
$H1E31
$F1E35
$H1E35
$F1E40
$H1E40
$F1E45
$H1E45
$F1E50
$H1E50
$F1E55
1E55 RPM Control
$H1E55
1E55 RPM Control
$F1E60
$H1E60
$F1430
$H1430
$F2800
2800 Power Supply
$H2800
2800 Power Supply
$F3000
$H3000
$F3005
3005 Terminal 15
$H3005
3005 Terminal 15
$F3505
3505 Glow system
$H3505
3505 Glow system
$F3506
3506 Glow system 2
$H3506
3506 Glow system 2
$F3510
3510 DDE Main Relay
$H3510
3510 DDE Main Relay
$F3515
$H3515
$F3520
$H3520
$F3565
$H3565
$F3580
$H3580
$F3596
$H3596
$F3600
$H3600
$F3605
$H3605
$F3610
$H3610
$F3615
$H3615
$F3620
$H3620
DDE 5.0
$F3E90
3E90 Crankshaft RPM sensor: No Signal
$H3E90
3E90 Crankshaft RPM : No Signal
$F3E91
3E91 Crankshaft RPM : Wrong Signal
$H3E91
$F3EC0
3EC0 Camshaft sensor : No Signal
$H3EC0
$F3EC1
3EC1 Camshaft sensor : Wrong Signal
$H3EC1
$F3ED0
3ED0 Camshaft sensor : No Signal
$H3ED0
$F3ED1
3ED1 Camshaft sensor: Wrong Signal
$H3ED1
3ED1 Camshaft sensor : Wrong Signal
$F3EE0
3EE0 Coolant temperature sensor
$H3EE0
$F3EE1
3EE1 Coolant temperature sensor
$H3EE1
$F3F00
3F00 Charge pressure sensor
$H3F00
$F3F01
3F01 Charge pressure sensor
$H3F01
$F3F03
3F03 Charge pressure sensor
$H3F03
$F3F10
3F10 Pedal value sensor
$H3H10
$F3F11
3F11 Pedal value sensor 1 : Short circuit to B-
$H3F11
$F3F13
3F13 Pedal value sensor 1 : Pot.1/Pot2. Not plausible
$H3F13
$F3F20
3F20 Pedal value sensor
$H3F20
$F3F21
3F21 Pedal value sensor 1 : Short circuit to B-
$H3F21
$F3F23
3F23 Pedal value sensor 1 : Pot.1/Pot2. Not plausible
$H3F23
$F3F30
3F30 Rail pressure sensor : Short circuit to B+ or Open circuit
$H3F30
$F3F31
3F31 Rail pressure sensor : Short circuit to B- or Open circuit
$H3F31
$F3F50
3F50 Vehicle speed signal : to high
$HF350
$F3F60
3F60 Pedal value sensor : Vehicle speed signal
$H3F60
$F3FB0
3FB0 Air flow sensor : Signal to high or Short circuit to B+
$H3FB0
$F3FB1
3FB1 Air flow sensor : Signal to low or Short circuit to B-
$H3FB1
$F3FC0
3FC0 Air flow sensor : deviation to high at idle speed
$H3FC0
$F3FD0
3FD0 Air flow sensor : deviation to high
$H3FD0
$F4060
4060 Atmospheric pressure sensor
$H4060
$F4061
4061 Atmospheric pressure sensor
$H4061
$F4072
4072 Signal gear box switch
$H4072
$F4080
4080 Signal Break Light / Break Light Switch
$H4080
$F4083
4083 Signal Break Light / Break Light Switch
$H4083
$F40A1
40A1 Generator signal
$H40A1
$F4120
4120 DDE Main relay is switching to late or to early
$H4120
$F4121
4121 DDE Mai relay is switching to late or to early
$H4121
$F4140
4140 Drallklappen
$H4140
4140 Drallklappen
$F4160
4160 Raise Pressure Pump : Short circuit to B+
$H4160
$F4161
4161 Raise Pressure Pump : Short circuit to B-
$H4161
$F4162
4162 Raise Pressure Pump : Activation interrupted
$H4162
$F4163
4163 Raise Pressure Pump : Final Stage (Temperature)
$H4163
$F4180
4180 Charge pressure positioner - Adjustment
$H4180
$F4190
4190 Charge pressure positioner
$H4190
$F41A0
41A0 Charge pressure positioner
$H41A0
$F41A1
41A1 Charge pressure positioner - Adjustment
$H41A1
$F41A2
41A2 Charge pressure positioner - Adjustment
$H41A2
$F41A3
41A3 Charge pressure positioner - Adjustment : Final Stage (Temperature)
$H41A3
$F41B0
41B0 Exhaust gas feedback regulation
$H41B0
$F41C1
41C1 Activation Cooler: Short circuit to B-
$H41C1
$F41C2
41C2 Activation Cooler: Activation interrupted
$H41C2
$F41C3
41C3 Activation Cooler: Final Stage (Temperature)
$H41C3
$F41D0
41D0 Exhaust gas feedback regulation
$H41D0
$F41D0
41D0 Charge pressure positioner - Adjustment : Exhaust gas feedback regulation
$H41D0
$F41E0
41E0 Exhaust gas feedback regulation
$H41E0
$F41E0
41E0 Charge pressure positioner - Adjustment : Exhaust gas feedback regulation
$H41E0
$F41F0
41F0 Electro ventilator : Short circuit to B+
$H41F0
$F41F1
41F1 Electro ventilator : Short circuit to B-
$H41F1
$F41F2
41F2 Electro ventilator : Activation interrupted
$H41F2
$F41F3
41F3 Electro ventilator : Final Stage (Temperature)
$H41F3
$F4203
4203 No Communication with data connection
$H4203
$F4211
4211 Cylinder 1 : Short circuit to B+
$H4211
$F4212
4212 Cylinder 1 : Activation interrupted
$H4212
$F4213
4213 Cylinder 1 : Final Stage (Temperature)
$H4213
$F4221
4221 Cylinder 2 : Short circuit to B+
$H4221
$F4222
4222 Cylinder 2 : Activation interrupted
$H4222
$F4223
4223 Cylinder 2 : Final Stage (Temperature)
$H4223
$F4231
4231 Cylinder 3 : Short circuit to B+
$H4231
$F4232
4232 Cylinder 3 : Activation interrupted
$H4232
$F4233
4233 Cylinder 3 : Final Stage (Temperature)
$H4233
$F4241
4241 Cylinder 4 : Short circuit to B+
$H4241
$F4242
4242 Cylinder 4 : Activation interrupted
$H4242
$F4243
4243 Cylinder 4 : Final Stage (Temperature)
$H4243
$F42C0
42C0 Oil pressure indication lamp : Short circuit to B+
$H42C0
$F42C1
42C1 Oil pressure indication lamp : Short circuit to B-
$H42C1
$F42C2
42C2 Oil pressure indication lamp : Activation interrupted
$H42C2
$F42C3
42C3 Oil pressure indication lamp : Final Stage (Temperature)
$H42C3
$F4302
4302 Quantity regulation valve : Activation interrupted
$H4302
$F4303
4303 Quantity regulation valve : Final Stage (Temperature)
$H4303
$F4310
4310 Quantity regulation valve : Short circuit to B+
$H4310
$F4321
4321 Quantity regulation valve : Short circuit to B-
$H4321
$F4332
4332 Rail pressure regulation valve : Activation interrupted
$H4332
$F4333
4333 Rail pressure regulation valve : Final Stage (Temperature)
$H4333
$F4340
4340 Rail pressure regulation valve : Short circuit to B+
$H4340
$F4351
4351 Rail pressure regulation valve : Short circuit to B-
$H4351
$F4362
4362 Rail pressure regulation valve : Current regulation
$H4362
$F4378
4378 Rail pressure regulation valve : Defect
$H4378
$F4390
4390 Charge air temperature sensor
$H4390
$F4391
4391 Charge air temperature sensor
$H4391
$F43F0
43F0 Electrical extra heater : Short circuit to B+
$H43F0
$F43F1
43F1 Electrical extra heater : Short circuit to B-
$H43F1
$F43F2
43F2 Electrical extra heater : Activation interrupted
$H43F2
$F43F3
43F3 Electrical extra heater : Final Stage (Temperature)
$H43F3
$F4500
4500 Exhaust gas recirculation : deviation
$H4500
4500 Exhaust gas recirculation: deviation
$F4506
4506 Exhaust gas recirculation: deviation
$H4506
$F4521
4521 Charge pressure positioner - Regulation: negative deviation, pressure to high
$H4521
$F4530
4530 Charge pressure positioner - Regulation: positive deviation, pressure to low
$H4530
4530 Charge pressure positioner - Regulation: deviation, pressure to low
$F4660
4660 Power Supply
$H4660
4660 Power Supply
$F4661
4661 Power Supply
$H4661
4661 Power Supply
$F4670
4670 Power Supply
$H4670
4670 Power Supply
$F4680
4680 Charge pressure positioner - Regulation : Power Supply
$H4680
4680 Charge pressure positioner - Regulation: Power Supply
$F4690
4690 Power Supply
$H4690
4690 Power Supply
$F48A2
48A2 CAN Communication with ASC
$H48A2
$F48A3
48A3 CAN Communication with ASC
$H48A3
$F48B2
48B2 CAN Communication with ASC
$H48B2
$F48B3
48B3 CAN Communication with ASC
$H48B3
$F48C2
48C2 CAN Communication with EGS
$H48C2
$F48C3
48C3 CAN Communication with EGS
$H48C3
$F48D2
48D2 CAN Communication with INSTRUMENT CLUSTER
$H48D2
$F48D3
48D3 CAN Communication with INSTRUMENT CLUSTER
$H48D3
$F48F2
48F2 CAN BUS HARDWARE
$H48F2
$F48F3
48F3 CAN BUS HARDWARE
$H48F3
$F4A30
4A30 Signal Multifunction steering wheel (MFL) : Toggle Bit
$H4A30
4A30 Signal Multifunction steering wheel (MFL): Toggle Bit
$F4A31
4A31 Signal Multifunction steering wheel (MFL): Frequency counter
$H4A31
$F4A32
4A32 Signal Multifunction steering wheel (MFL): No Signal
$H4A32
$F4A33
4A33 Signal Multifunction steering wheel (MFL): Signal not plausible
$H4A33
$F4AA2
4AA2 CAN Communication with EGS
$H4AA2
$F4AA3
4AA3 CAN Communication with EGS
$H4AA3
$F4AB0
4AB0 Electrical extra heater
$H4AB0
$F4AE0
4AE0 E-Box Ventilator : Short circuit to B+
$H4AE0
$F4AE1
4AE1 E-Box Ventilator : Short circuit to B-
$H4AE1
4AE1 E-Box Ventilator: Short circuit to B-
$F4AE2
4AE2 E-Box Ventilator: Activation interrupted
$H4AE2
$F4AE3
4AE3 E-Box Ventilator: Final Stage (Temperature)
$H4AE3
$F4B10
4B10 Smooth run regulation : correction quantity to high
$H4B10
$F4B11
4B11 Smooth run regulation : correction quantity to low
$H4B11
$F4B20
4B20 Electro ventilator : Blocked
$H4B20
$F7073
7073 Signal gear box switch
$H7073
$FCD87
CD87 CAN BUS
$HCD87
CD87 CAN BUS
$F3E90
$H3E90
$F3E91
$H3E91
$F3EC0
$H3EC0
$F3EC1
$H3EC1
$F3ED0
$H3ED0
$F3ED1
$H3ED1
$F3EE0
$H3EE0
$F3EE1
$H3EE1
$F3F00
$H3F00
$F3F01
$H3F01
$F3F03
$H3F03
$F3F10
$H3H10
$F3F11
$H3F11
$F3F13
$H3F13
$F3F20
$H3F20
$F3F21
$H3F21
$F3F23
$H3F23
$F3F30
$H3F30
$F3F31
$H3F31
$F3F50
$HF350
$F3F60
$H3F60
$F3FB0
$H3FB0
$F3FB1
$H3FB1
$F3FC0
$H3FC0
$F3FD0
$H3FD0
$F4060
$H4060
$F4061
$H4061
$F4072
$H4072
$F4080
$H4080
$F4083
$H4083
$F40A1
$H40A1
$F4120
$H4120
$F4121
$H4121
$F4140
4140 Drallklappen
$H4140
4140 Drallklappen
$F4160
$H4160
$F4161
$H4161
$F4162
$H4162
$F4163
$H4163
$F4180
$H4180
$F4190
$H4190
$F41A0
$H41A0
$F41A1
$H41A1
$F41A2
$H41A2
$F41A3
$H41A3
$F41B0
$H41B0
$F41C1
$H41C1
$F41C2
$H41C2
$F41C3
$H41C3
$F41D0
$H41D0
$F41D0
$H41D0
$F41E0
$H41E0
$F41E0
$H41E0
$F41F0
$H41F0
$F41F1
$H41F1
$F41F2
$H41F2
$F41F3
$H41F3
$F4203
$H4203
$F4211
$H4211
$F4212
$H4212
$F4213
$H4213
$F4221
$H4221
$F4222
$H4222
$F4223
$H4223
$F4231
$H4231
$F4232
$H4232
$F4233
$H4233
$F4241
$H4241
$F4242
$H4242
$F4243
$H4243
$F42C0
$H42C0
$F42C1
$H42C1
$F42C2
$H42C2
$F42C3
$H42C3
$F4302
$H4302
$F4303
$H4303
$F4310
$H4310
$F4321
$H4321
$F4332
$H4332
$F4333
$H4333
$F4340
$H4340
$F4351
$H4351
$F4362
$H4362
$F4378
$H4378
$F4390
$H4390
$F4391
$H4391
$F43F0
$H43F0
$F43F1
$H43F1
$F43F2
$H43F2
$F43F3
$H43F3
$F4500
$H4500
$F4506
$H4506
$F4521
$H4521
$F4530
$H4530
$F4660
4660 Power Supply
$H4660
4660 Power Supply
$F4661
4661 Power Supply
$H4661
4661 Power Supply
$F4670
4670 Power Supply
$H4670
4670 Power Supply
$F4680
$H4680
$F4690
4690 Power Supply
$H4690
4690 Power Supply
$F48A2
$H48A2
$F48A3
$H48A3
$F48B2
$H48B2
$F48B3
$H48B3
$F48C2
$H48C2
$F48C3
$H48C3
$F48D2
$H48D2
$F48D3
$H48D3
$F48F2
$H48F2
$F48F3
$H48F3
$F4A30
$H4A30
$F4A31
$H4A31
$F4A32
$H4A32
$F4A33
$H4A33
$F4AA2
$H4AA2
$F4AA3
$H4AA3
$F4AB0
$H4AB0
$F4AE0
$H4AE0
$F4AE1
$H4AE1
$F4AE2
$H4AE2
$F4AE3
$H4AE3
$F4B10
$H4B10
$F4B11
$H4B11
$F4B20
$H4B20
$F7073
$H7073
$FCD87
CD87 CAN BUS
$HCD87
CD87 CAN BUS
DDE 6.0
$F3E90
3E90 Crankshaft position sensor
$H3E90
$F3E91
3E91 Crankshaft position sensor
$H3E91
$F3E95
3E95 Intake air temperature sensor
$H3E95
$F3EA0
3EA0 Crankshaft position sensor
$H3EA0
$F3EA1
3EA1 Crankshaft position sensor
$H3EA1
$F3EA5
3EA5 Intake air temperature sensor
$H3EA5
$F3EA6
3EA6 Intake air temperature sensor
$H3EA6
$F3EB0
3EB0 RPM calculation
$H3EB0
$F3EB5
3EB5 Air flow sensor 2
$H3EB5
$F3EB6
3EB6 Air flow sensor 2
$H3EB6
$F3EC0
$H3EC0
$F3EC1
$H3EC1
$F3EC7
3EC7 Camshaft sensor
$H3EC7
$F3ED0
$H3ED0
$F3ED1
$H3ED1
$F3ED5
3ED5 Air flow sensor 2
$H3ED5
$F3ED6
3ED6 Air flow sensor 2
$H3ED6
$F3EE0
$H3EE0
$F3EE1
$H3EE1
$F3EE2
3EE2 Coolant temperature sensor
$H3EE2
$F3EE3
3EE3 Coolant temperature sensor
$H3EE3
$F3EF3
3EF3 Coolant temperature sensor not plausible
$H3EF3
$F3EF5
3EF5 Intake air temperature sensor 2 (HFM referenz signal)
$H3EF5
$F3EF6
3EF6 Intake air temperature sensor 2 (HFM referenz signal)
$H3EF6
$F3EF7
3EF7 Intake air temperature sensor 2 (HFM referenz signal)
$H3EF7
$F3F00
3F00 Fill pressure sensor
$F3F00
3H00 Fill pressure sensor
$F3F01
3F01 Fill pressure sensor
$H3F01
$F3F02
3F02 Fill pressure sensor
$H3F02
$F3F03
3F03 Fill pressure sensor
$H3F03
$F3F05
3F05 MIL OFF
$H3F05
3F05 MIL OFF
$F3F10
3F10 Throttle pedal potentiometer 1
$H3F10
$F3F11
3F11 Throttle pedal potentiometer 1
$H3F11
$F3F13
3F13 Throttle pedal potentiometer 1
$H3F13
$F3F15
3F15 MIL ON
$H3F15
3F15 MIL ON
$F3F20
3F20 Throttle pedal potentiometer 2
$H3F20
$F3F21
3F21 Throttle pedal potentiometer 2
$H3F21
$F3F23
3F23 Throttle pedal potentiometer 2
$H3F23
$F3F25
3F25 Input air flow control
$H3F25
$F3F30
$H3F30
$F3F31
$H3F31
$F3F35
3F35 Input air flow control at idle speed
$H3F35
$F3F40
3F40 Rail pressure sensor offset-test
$H3F40
$F3F41
3F41 Rail pressure sensor offset-test
$H3F41
$F3F47
3F47 Brake light- / Brake light test switch
$H3F47
$F3F48
3F48 Brake light- / Brake light test switch
$H3F48
$F3F50
$H3F50
$F3F51
3F51 Vehicle speed signal
$H3F51
$F3F52
3F52 Vehicle speed signal
$H3F52
$F3F53
3F53 Vehicle speed signal
$H3F53
$F3F62
3F62 Vehicle speed signal from CAN
$H3F62
$F3F67
3F67 Vuldrukmodulator 2
$H3F67
$F3F70
3F70 Intake air temperature sensor
$H3F770
$F3F71
3F71 Intake air temperature sensor
$H3F71
$F3F72
3F72 Intake air temperature sensor
$H3F72
$F3F77
3F77 Fill pressure modulator 1
$H3F77
$F3F87
3F87 Fill pressure modulator 2
$H3F87
$F3F97
3F97 Fill pressure modulator 1
$H3F97
$F3FB0
$H3FB0
$F3FB5
3FB5 Controle master/salve
$H3FB5
$F3FB6
3FB6 Controle master/salve
$H3FB6
$F3FB7
3FB7 Control Unit : internal master
$H3FB7
$F3FC0
3FC0 Air flow meter
$H3FC0
3FC0 Air flow meter
$F3FD0
3FD0 Air flow meter
$H3FD0
3FD0 Air flow meter
$F3FE0
3FE0 Air flow meter
$H3FE0
3FE0 Air flow meter
$F3FE1
3FE1 Air flow meter
$H3FE1
3FE1 Air flow meter
$F3FF0
3FF0 Air flow meter
$H3FF0
3FF0 Air flow meter
$F3FF1
3FF1 Air flow meter
$H3FF1
3FF1 Air flow meter
$F4000
4000 Fuel temperature sensor
$H4000
$F4001
4001 Fuel temperature sensor
$H4001
$F4060
4060 Ambient pressure sensor (in DDE control unit)
$H4060
$F4061
4061 Ambient pressure sensor (in DDE control unit)
$H4061
$F4063
4063 Ambient pressure sensor (in DDE control unit)
$H4063
$F4082
4082 Brake light- / Brake light test switch
$H4082
$F4083
4083 Brake light- / Brake light test switch
$H4083
$F40E0
40E0 Dynamo
$H40E0
40E0 Dynamo
$F4100
4100 Airco power output
$H4100
$F4101
4101 Airco power output
$H4101
$F4102
4102 Airco power output
$H4102
$F4103
4103 Airco power output
$H4103
$F4108
4108 Controle master/salve
$H4108
$F4117
4117 Controle master/salve
$H4117
$F4118
4118 Controle master/salve
$H4118
$F4120
4120 DDE-Main Relay
$H4120
4120 DDE-Main Relay
$F4121
4121 DDE-Main Relay
$H4121
4121 DDE-Main Relay
$F4125
4125 Power supply
$H4125
4125 Power supply
$F4126
4126 Power supply
$H4126
4126 Power supply
$F4130
4130 Whirl valve
$H4130
4130 Whirl valve
$F4135
4135 Power supply
$H4135
4135 Power supply
$F4136
4136 Power supply
$H4136
4136 Power supply
$F4141
4141 Whirl valve
$H4141
4141 Whirl valve
$F4145
4145 Power supply
$H4145
4145 Power supply
$F4146
4146 Power supply
$H4146
4146 Power supply
$F4152
4152 Whirl valve
$H4152
4152 Whirl valve
$F4153
4153 Whirl valve
$H4153
4153 Whirl valve
$F4141
4160 Relay feed pumps
$H4141
$F4161
4161 Relay feed pumps
$H4161
$F4162
4162 Relay feed pumps
$H4162
$F4163
4163 Relay feed pumps
$H4163
$F4180
4180 Fill pressure regulation
$H4180
$F4191
4191 Fill pressure regulation
$H4191
$F41A2
41A2 Fill pressure regulation
$H41A2
$F41A3
41A3 Fill pressure regulation
$H41A3
$F41A6
41A6 Message CBS Reset
$H41A6
$F41A7
41A7 Message CBS Reset
$H41A7
$F41B0
41B0 Exhaust gas regulation
$H41B0
$F41B5
41B5 Transmision fuied temperature sensor
$H41B5
$F41C0
41C0 Radiator blind
$H41C0
41C0 Radiator blind
$F41C1
41C1 Radiator blind
$H41C1
41C1 Radiator blind
$F41C2
41C2 Radiator blind
$H41C2
41C2 Radiator blind
$F41C3
41C3 Radiator blind
$H41C3
41C3 Radiator blind
$F41D1
41D1 Exhaust gas regulation
$H41D1
$F41E2
41E2 Exhaust gas regulation
$H41E2
$F41E3
41E3 Exhaust gas regulation
$H41E3
$F41F0
$H41F0
$F41F1
$H41F1
$F41F2
$H41F2
$F41F3
$H41F3
$F4203
4203 Glow module
$H4203
4203 Glow module
$F4211
4211 Glow spark cilinder 1
$H4211
$F4212
4212 Glow spark cilinder 1
$H4212
$F4213
4213 Glow spark cilinder 1
$H4213
$F4221
4221 Glow spark cilinder 2
$H4221
$F4222
4222 Glow spark cilinder 2
$H4222
$F4223
4223 Glow spark cilinder 2
$H4223
$F4231
4231 Glow spark cilinder 3
$H4231
$F4232
4232 Glow spark cilinder 3
$H4232
$F4233
4233 Glow spark cilinder 3
$H4233
$F4241
4241 Glow spark cilinder 4
$H4241
$F4242
4242 Glow spark cilinder 4
$H4242
$F4243
4243 Glow spark cilinder 4
$H4243
$F4251
4251 Glow spark cilinder 5
$H4251
$F4252
4252 Glow spark cilinder 5
$H422
$F4253
4253 Glow spark cilinder 5
$F4253
4H53 Glow spark cilinder 5
$F4261
4261 Glow spark cilinder 6
$H4261
$F4262
4262 Glow spark cilinder 6
$H4262
$F4263
4263 Glow spark cilinder 6
$H4263
$F4271
4271 Glow spark cilinder 7
$H4271
$F4272
4272 Glow spark cilinder 7
$H4272
$F4273
4273 Glow spark cilinder 7
$H4273
$F4281
4281 Glow spark cilinder 8
$H4281
$F4282
4282 Glow spark cilinder 8
$H4282
$F4283
4283 Glow spark cilinder 8
$H4283
$F4293
4293 Control Unit Internal Error 16
$H4293
$F42B5
42B5 RPM control
$H42B5
42B5 RPM control
$F42C0
42C0 Oil pressure indication light
$H42C0
$F42C1
42C1 Oil pressure indication light
$H42C1
$F42C2
42C2 Oil pressure indication light
$H42C2
$F42C3
42C3 Oil pressure indication light
$H42C3
$F42D5
42D5 Injector cilinder 7
$H42D5
$F42D6
42D6 Injector cilinder 7
$H42D6
$F42D7
42D7 Injector cilinder 7
$H42D7
$F42D8
42D8 Injector cilinder 7
$H42D8
$F42F5
42F5 Injector cilinder 8
$H42F5
$F42F6
42F6 Injector cilinder 8
$H42F6
$F42F7
42F7 Injector cilinder 8
$H42F7
$F42F8
42F8 Injector cilinder 8
$H42F8
$F4302
$H4302
$F4303
$H4303
$F4310
$H4310
$F4321
$H4321
$F4332
$H4332
$F4333
$H4333
$F4340
$H4340
$F4351
$H4351
$F4360
4360 Current regulation for Rail pressure regulation valve
$H4360
$F4361
4361 Current regulation for Rail pressure regulation valve
$H4361
$F4362
4362 Current regulation for Rail pressure regulation valve
$H4362
$F4373
4373 Air flow weight not plausible
$H4373
$F4378
4378 Rail pressure valve test
$H4378
$F4382
4382 Rail pressure valve position test
$H4382
$F4390
4390 Fill pressure temperature sensor
$H4390
$F4391
4391 Fill pressure temperature sensor
$H4391
$F4392
4392 Fill pressure temperature sensor
$H4392
$F4397
4397 Position test volume adjust valve
$H4397
$F43A0
43A0 Start-block relay
$H43A0
$F43A1
43A1 Start-block relay
$H43A1
$F43A2
43A2 Start-block relay
$H43A2
$F43A3
43A3 Start-block relay
$H4A3
$F43F0
43F0 Extra electrical heater
$H43F0
$F43F1
43F1 Extra electrical heater
$H43F1
$F43F2
43F2 Extra electrical heater
$H43F2
$F43F3
43F3 Extra electrical heater
$H43F3
$F4403
4403 Control unit inernal error 17
$H4403
$F4410
4410 Injector cilinder 1: activation
$H4410
$F4411
4411 Injector cilinder 1: activation
$H4411
$F4412
4412 Injector cilinder 1: activation
$H4412
$F4413
4413 Injector cilinder 1: activation
$H4413
$F4417
4417 Controle master/salve
$H4417
$F441C
441C Injector cilinder 1: activation
$H441C
$F4420
4420 Injector cilinder 2: activation
$H4420
$F4421
4421 Injector cilinder 2: activation
$H4421
$F4422
4422 Injector cilinder 2: activation
$H4422
$F4423
4423 Injector cilinder 2: activation
$H4423
$F4428
4428 Controle master/slave
$H4428
$F442C
442C Injector cilinder 2: activation
$H442C
$F4430
4430 Injector cilinder 3: activation
$H4430
$F4431
4431 Injector cilinder 3: activation
$H4431
$F4432
4432 Injector cilinder 3: activation
$H4432
$F4433
4433 Injector cilinder 3: activation
$H4433
$F4438
4438 Controle master/slave
$H4438
$F443C
443C Injector cilinder 3: activation
$H443C
$F4440
4440 Injector cilinder 4: activation
$H4440
$F4441
4441 Injector cilinder 4: activation
$H4441
$F4442
4442 Injector cilinder 4: activation
$H4442
$F4443
4443 Injector cilinder 4: activation
$H4443
$F444C
444C Injector cilinder 4: activation
$H444C
$F4450
4450 Injector cilinder 5: activation
$H4450
$F4451
4451 Injector cilinder 5: activation
$H4451
$F4452
4452 Injector cilinder 5: activation
$H4452
$F4453
4453 Injector cilinder 5: activation
$H4453
$F445C
445C Injector cilinder 5: activation
$H445C
$F4460
4460 Injector cilinder 6: activation
$H4460
$F4461
4461 Injector cilinder 6: activation
$H4461
$F4462
4462 Injector cilinder 6: activation
$H4462
$F4463
4463 Injector cilinder 6: activation
$H4463
$F446C
446C Injector cilinder 6: activation
$H446C
$F4473
4473 Control unit inernal error 18
$H4473
$F4480
4480 Control unit inernal error 19
$H4480
$F4491
4491 Control unit inernal error 20
$H4491
$F44A0
44A0 Injectors: activation cil. 1, 2, 3
$H44A0
$F44A1
44A1 Injectors: activation cil. 1, 2, 3
$H44A1
$F44A3
44A3 Injectors: activation cil. 1, 2, 3
$H44A3
$F44AC
44AC Injectors: activation cil. 1, 2, 3
$H44AC
$F44B0
44B0 Injectors: activation cil. 1, 2, 3
$H44B0
$F44B1
44B1 Injectors: activation cil. 4, 5, 6
$H44B1
$F44B3
44B3 Injectors: activation cil. 4, 5, 6
$H44B3
$F44BC
44BC Injectors: activation cil. 4, 5, 6
$H44BC
$F44C0
44C0 Number of wanted injections limited
$H44C0
$F44C1
44C1 Number of wanted injections limited
$H44C1
$F44C2
44C2 Number of wanted injections limited
$H44C2
$F44D0
44D0 Dynamo
$H44D0
44D0 Dynamo
$F44D2
44D2 Dynamo
$H44D2
44D2 Dynamo
$F44D3
44D3 Dynamo
$H44D3
44D3 Dynamo
$F44E2
44E2 Dynamo
$H44E2
44E2 Dynamo
$F44E3
44E3 Dynamo
$H44E3
44E3 Dynamo
$F44F0
44F0 Railpressure not plausible
$H44F0
$F4501
4501 Exhaust gas feeback regulation
$H4501
$F4507
4507 Exhaust gas feeback regulation
$H4507
$F4512
4512 Thermical oil level sensor
$H4512
$F4513
4513 Thermical oil level sensor
$H4513
$F4521
4521 Fill pressure regulation
$H4521
$F4530
4530 Fill pressure regulation
$H4530
$F4536
4536 Powermanagement accu
$H4536
$F4541
4541 Thermical oil level sensor
$H4541
$F4550
4550 Fill pressure modulation 2
$H4550
$F4560
4560 Railpressure not plausible
$H4560
$F4570
4570 Railpressure not plausible
$H4570
$F4580
4580 Railpressure not plausible
$H4580
$F4590
4590 Railpressure not plausible
$H4590
$F45A0
45A0 Railpressure not plausible
$H45A0
$F45C0
45C0 Railpressure not plausible
$H45C0
$F45E3
45E3 Controle master/slave
$H45E3
$F45F2
45F2 Controle master/slave
$H45F2
$F45F3
45F3 Controle master/slave
$H45F3
$F4600
4600 Railpressure not plausible
$H4600
$F4610
4610 Railpressure not plausible
$H4610
$F4620
4620 Railpressure not plausible
$H4620
$F4630
4630 Railpressure not plausible
$H4630
$F4640
4640 Railpressure not plausible
$H4640
$F4650
4650 Railpressure not plausible
$H4650
$F4660
4660 Power supply
$H4660
4660 Power supply
$F4661
4661 Power supply
$H4661
4661 Power supply
$F4670
4670 Power supply
$H4670
4670 Power supply
$F4671
4671 Power supply
$H4671
4671 Power supply
$F4680
4680 Power supply
$H4680
4680 Power supply
$F4681
4681 Power supply
$H4681
4681 Power supply
$F4690
4690 Power supply
$H4690
4690 Power supply
$F4691
4691 Power supply
$H4691
4691 Power supply
$F46A0
46A0 Control unit inernal error 1
$H46A0
$F46A1
46A1 Control unit inernal error 1
$H46A1
$F46A2
46A2 Control unit inernal error 1
$H46A2
$F46A3
46A3 Control unit inernal error 1..
$H46A3
$F46B0
46B0 Control unit inernal error 2
$H46B0
$F46B1
46B1 Control unit inernal error 2
$H46B1
$F46B2
46B2 Control unit inernal error 2
$H46B2
$F46B3
46B3 Control unit inernal error 2
$H46B3
$F46C0
46C0 Control unit inernal error 3
$H46C0
$F46C1
46C1 Control unit inernal error 3
$H46C1
$F46D0
46D0 Control unit inernal error 4
$H46D0
$F46D1
46D1 Control unit inernal error 4
$H46D1
$F46D2
46D2 Control unit inernal error 4
$H46D2
$F46D3
46D3 Control unit inernal error 4
$H46D3
$F4703
4703 Control unit inernal error 7
$H4703
$F4711
4711 Control unit inernal error 8
$H4711
$F4712
4712 Control unit inernal error 8
$H4712
$F4713
4713 Control unit inernal error 8
$H4713
$F4723
4723 Control unit inernal error 9
$H4723
$F4730
4730 Quantity regulation current regulation
$H430
$F4731
4731 Quantity regulation current regulation
$H4731
$F4732
4732 Quantity regulation current regulation
$H4732
$F4740
4740 Control unit inernal error 11
$H4740
$F4750
4750 Control unit inernal error 12
$H4750
$F4753
4753 Control unit inernal error 12
$H4753
$F4763
4763 Control unit inernal error 13
$H4763
$F4773
4773 Control unit inernal error 14
$H4773
$F4780
4780 Control unit inernal error 15
$H4780
$F4781
4781 Control unit inernal error 15
$H4781
$F4782
4782 Control unit inernal error 15
$H4782
$F4783
4783 Control unit inernal error 15
$H4783
$F4803
4803 Torque controle ACC
$H4803
$F4810
4810 Torque controle ACC
$H4810
$F4830
4830 Intake air temperature sensor
$H4830
$F4831
4831 Intake air temperature sensor
$H4831
$F4841
4841 Exhaust gas feeback regulation 2
$H4841
$F4850
4850 Exhaust gas feeback regulation 2
$H4850
$F4863
4863 Vehicle speed regulation
$H4863
$F48F2
48F2 PT-CAN-bus
$H48F2
48F2 PT-CAN-bus
$F48F3
48F3 PT-CAN-bus
$H48F3
48F3 PT-CAN-bus
$F4900
4900 DSC torque intervention
$H4900
$F4912
4912 PT-CAN-bus
$H4912
4912 PT-CAN-bus
$F4913
4913 PT-CAN-bus
$H4913
4913 PT-CAN-bus
$F4920
4920 Koppelingreep transmissie
$H4920
$F4991
4991 Message : Intrument Cluster
$H4991
$F4992
4992 Message : Intrument Cluster
$H4992
$F49A2
49A2 Message : Ambient temperature
$H49A2
$F49B0
49B0 Message : Torque request
$H49B0
$F49C0
49C0 Message : Torque request
$H49C0
$F49D2
49D2 Message : Torque request
$H49D2
$F49E0
49E0 Message : Torque request
$H49E0
$F49F2
49F2 Message : Vehicle speed
$H49F2
$F49F3
49F3 Message : Vehicle speed
$H49F3
$F4A02
4A02 Terminal 15
$H4A02
4A02 Terminal 15
$F4A03
4A03 Terminal 15
$H4A03
4A03 Terminal 15
$F4A10
4A10 BSD interface
$H4A10
4A10 BSD interface
$F4A13
4A13 BSD interface
$H4A13
4A13 BSD interface
$F4A30
4A30 MFC : multifunctional steeringwheel
$H4A30
$F4A31
4A31 MFC : multifunctional steeringwheel
$H4A31
$F4A32
4A32 MFC : multifunctional steeringwheel
$H4A32
$F4A33
4A33 MFC : multifunctional steeringwheel
$H4A33
$F4A41
4A41 EWS interface
$H4A41
4A41 EWS interface
$F4A42
4A42 EWS interface
$H4A42
4A42 EWS interface
$F4A43
4A43 EWS interface
$H4A43
4A43 EWS interface
$F4A51
4A51 EWS code storage
$H4A51
$F4A60
4A60 EWS manipulation
$H4A60
$F4A61
4A61 EWS manipulation
$H4A61
$F4A62
4A62 EWS manipulation
$H4A62
$F4A63
4A63 EWS manipulation
$H4A63
$F4A70
4A70 Reference values incorrect
$H4A70
$F4A80
4A80 Intake air slang
$H4A80
$F4AE0
4AE0 E-box-ventilator
$H4AE0
$F4AE1
4AE1 E-box-ventilator
$H4AE1
$F4AE2
4AE2 E-box-ventilator
$H4AE2
$F4AE3
4AE3 E-box-ventilator
$H4AE3
$F4AF0
4AF0 Control unit temperature sensor
$H4AF0
$F4AF1
4AF1 Control unit temperature sensor
$H4AF1
$F4B00
4B00 Control unit temperature
$H4B00
$F4B10
4B10 Stady RPM regulator
$H4B10
$F4B11
4B11 Stady RPM regulator
$H4B11
$F4B22
4B22 Electro ventilator
$H4B22
$F4B50
4B50 Quantity compensation
$H4B50
$F4B60
4B60 Quantity compensation
$H4B60
$F4B80
4B80 Rail pressure not plausible
$H4B80
$F4B90
4B90 Rail prssure controle at engine start
$H4B90
$F4BA0
4BA0 Intake air temperature sensor
$H4BA0
$F4BA1
4BA1 Intake air temperature sensor
$H4BA1
$F4BB0
4BB0 Air flow sensor power supply
$H4BB0
$F4BB1
4BB1 Air flow sensor power supply
$H4BB1
$F4BB5
4BB5 Air flow sensor
$H4BB5
$F4BB6
4BB6 Air flow sensor
$H4BB6
$F4BC0
4BC0 Air flow sensor
$H4BC0
$F4BC1
4BC1 Air flow sensor
$H4BC1
$F4BC2
4BC2 Air flow sensor
$H4BC2
$F4BC5
4BC5 Intake air temperature sensor
$H4BC5
$F4BC6
4BC6 Intake air temperature sensor
$H4BC6
$F4BC7
4BC7 Intake air temperature sensor
$H4BC7
$F4BD2
4BD2 ARS torque request
$H4BD2
$F4BD5
4BD5 Engine support
$H4BD5
4BD5 Engine support
$F4BD6
4BD6 Engine support
$H4BD6
4BD6 Engine support
$F4BD7
4BD7 Engine support
$H4BD7
4BD7 Engine support
$F4BD8
4BD8 Engine support
$H4BD8
4BD8 Engine support
$F4BE2
4BE2 Message : transmission data
$H4BE2
$F4BE7
4BE7 Message : transmission data 2
$H4BE7
4BE7 Message : transmission data2
$F4BF2
4BF2 Message : airconditioning
$H4BF2
$F4BF7
4BF7 Message : actieradius
$H4BF7
$F4C00
4C00 Message : Tempomat
$H4C00
$F4C01
4C01 Message : Tempomat
$H4C01
$F4C02
4C02 Message : Tempomat
$H4C02
$F4C06
4C06 Message : ARS status
$H4C06
$F4C07
4C07 Message : ARS status
$H4C07
$F4C12
4C12 Message : DSC status
$H4C12
$F4C15
4C15 Message : Terminal 15
$H4C15
$F4C16
4C16 Message : Terminal 15
$H4C16
$F4C17
4C17 Message : Terminal 15
$H4C17
$F4C20
4C20 Message : DSC torque
$H4C20
$F4C21
4C21 Message : DSC torque
$H4C21
$F4C22
4C22 Message : DSC torque
$H4C22
$F4C27
4C27 Message : Vehicle speed
$H4C27
$F4CA2
4CA2 Message : Power managment
$H4CA2
$F4CB2
4CB2 Message : Power managment
$H4CB2
$F4DF0
4DF0 Message : transmission torque
$H4DF0
$F4DF1
4DF1 Message : transmission torque
$H4DF1
$F4DF2
4DF2 Message : transmission torque
$H4DF2
$FCD87
CD87 Private-CAN-bus communication error
$HCD87
$F3E90
$H3E90
$F3E91
$H3E91
$F3E95
$H3E95
$F3EA0
$H3EA0
$F3EA1
$H3EA1
$F3EA5
$H3EA5
$F3EA6
$H3EA6
$F3EB0
$H3EB0
$F3EB5
$H3EB5
$F3EB6
$H3EB6
$F3EC0
$H3EC0
$F3EC1
$H3EC1
$F3EC7
$H3EC7
$F3ED0
$H3ED0
$F3ED1
$H3ED1
$F3ED5
$H3ED5
$F3ED6
$H3ED6
$F3EE0
$H3EE0
$F3EE1
$H3EE1
$F3EE2
$H3EE2
$F3EE3
$H3EE3
$F3EF3
$H3EF3
$F3EF5
$H3EF5
$F3EF6
$H3EF6
$F3EF7
$H3EF7
$F3F00
$F3F00
$F3F01
$H3F01
$F3F02
$H3F02
$F3F03
$H3F03
$F3F05
3F05 MIL OFF
$H3F05
3F05 MIL OFF
$F3F10
$H3F10
$F3F11
$H3F11
$F3F13
$H3F13
$F3F15
3F15 MIL ON
$H3F15
3F15 MIL ON
$F3F20
$H3F20
$F3F21
$H3F21
$F3F23
$H3F23
$F3F25
$H3F25
$F3F30
$H3F30
$F3F31
$H3F31
$F3F35
$H3F35
$F3F40
$H3F40
$F3F41
$H3F41
$F3F47
$H3F47
$F3F48
$H3F48
$F3F50
$H3F50
$F3F51
$H3F51
$F3F52
$H3F52
$F3F53
$H3F53
$F3F62
$H3F62
$F3F67
$H3F67
$F3F70
$H3F770
$F3F71
$H3F71
$F3F72
$H3F72
$F3F77
$H3F77
$F3F87
$H3F87
$F3F97
$H3F97
$F3FB0
$H3FB0
$F3FB5
$H3FB5
$F3FB6
$H3FB6
$F3FB7
$H3FB7
$F3FC0
3FC0 Air flow meter
$H3FC0
3FC0 Air flow meter
$F3FD0
3FD0 Air flow meter
$H3FD0
3FD0 Air flow meter
$F3FE0
3FE0 Air flow meter
$H3FE0
3FE0 Air flow meter
$F3FE1
3FE1 Air flow meter
$H3FE1
3FE1 Air flow meter
$F3FF0
3FF0 Air flow meter
$H3FF0
3FF0 Air flow meter
$F3FF1
3FF1 Air flow meter
$H3FF1
3FF1 Air flow meter
$F4000
$H4000
$F4001
$H4001
$F4060
$H4060
$F4061
$H4061
$F4063
$H4063
$F4082
$H4082
$F4083
$H4083
$F40E0
40E0 Dynamo
$H40E0
40E0 Dynamo
$F4100
$H4100
$F4101
$H4101
$F4102
$H4102
$F4103
$H4103
$F4108
$H4108
$F4117
$H4117
$F4118
$H4118
$F4120
4120 DDE-Main Relay
$H4120
4120 DDE-Main Relay
$F4121
4121 DDE-Main Relay
$H4121
4121 DDE-Main Relay
$F4125
4125 Power supply
$H4125
4125 Power supply
$F4126
4126 Power supply
$H4126
4126 Power supply
$F4130
4130 Whirl valve
$H4130
4130 Whirl valve
$F4135
4135 Power supply
$H4135
4135 Power supply
$F4136
4136 Power supply
$H4136
4136 Power supply
$F4141
4141 Whirl valve
$H4141
4141 Whirl valve
$F4145
4145 Power supply
$H4145
4145 Power supply
$F4146
4146 Power supply
$H4146
4146 Power supply
$F4152
4152 Whirl valve
$H4152
4152 Whirl valve
$F4153
4153 Whirl valve
$H4153
4153 Whirl valve
$F4141
$H4141
$F4161
$H4161
$F4162
$H4162
$F4163
$H4163
$F4180
$H4180
$F4191
$H4191
$F41A2
$H41A2
$F41A3
$H41A3
$F41A6
$H41A6
$F41A7
$H41A7
$F41B0
$H41B0
$F41B5
$H41B5
$F41C0
41C0 Radiator blind
$H41C0
41C0 Radiator blind
$F41C1
41C1 Radiator blind
$H41C1
41C1 Radiator blind
$F41C2
41C2 Radiator blind
$H41C2
41C2 Radiator blind
$F41C3
41C3 Radiator blind
$H41C3
41C3 Radiator blind
$F41D1
$H41D1
$F41E2
$H41E2
$F41E3
$H41E3
$F41F0
$H41F0
$F41F1
$H41F1
$F41F2
$H41F2
$F41F3
$H41F3
$F4203
4203 Glow module
$H4203
4203 Glow module
$F4211
$H4211
$F4212
$H4212
$F4213
$H4213
$F4221
$H4221
$F4222
$H4222
$F4223
$H4223
$F4231
$H4231
$F4232
$H4232
$F4233
$H4233
$F4241
$H4241
$F4242
$H4242
$F4243
$H4243
$F4251
$H4251
$F4252
$H422
$F4253
$F4253
$F4261
$H4261
$F4262
$H4262
$F4263
$H4263
$F4271
$H4271
$F4272
$H4272
$F4273
$H4273
$F4281
$H4281
$F4282
$H4282
$F4283
$H4283
$F4293
$H4293
$F42B5
42B5 RPM control
$H42B5
42B5 RPM control
$F42C0
$H42C0
$F42C1
$H42C1
$F42C2
$H42C2
$F42C3
$H42C3
$F42D5
$H42D5
$F42D6
$H42D6
$F42D7
$H42D7
$F42D8
$H42D8
$F42F5
$H42F5
$F42F6
$H42F6
$F42F7
$H42F7
$F42F8
$H42F8
$F4302
$H4302
$F4303
$H4303
$F4310
$H4310
$F4321
$H4321
$F4332
$H4332
$F4333
$H4333
$F4340
$H4340
$F4351
$H4351
$F4360
$H4360
$F4361
$H4361
$F4362
$H4362
$F4373
$H4373
$F4378
$H4378
$F4382
$H4382
$F4390
$H4390
$F4391
$H4391
$F4392
$H4392
$F4397
$H4397
$F43A0
$H43A0
$F43A1
$H43A1
$F43A2
$H43A2
$F43A3
$H4A3
$F43F0
$H43F0
$F43F1
$H43F1
$F43F2
$H43F2
$F43F3
$H43F3
$F4403
$H4403
$F4410
$H4410
$F4411
$H4411
$F4412
$H4412
$F4413
$H4413
$F4417
$H4417
$F441C
$H441C
$F4420
$H4420
$F4421
$H4421
$F4422
$H4422
$F4423
$H4423
$F4428
$H4428
$F442C
$H442C
$F4430
$H4430
$F4431
$H4431
$F4432
$H4432
$F4433
$H4433
$F4438
$H4438
$F443C
$H443C
$F4440
$H4440
$F4441
$H4441
$F4442
$H4442
$F4443
$H4443
$F444C
$H444C
$F4450
$H4450
$F4451
$H4451
$F4452
$H4452
$F4453
$H4453
$F445C
$H445C
$F4460
$H4460
$F4461
$H4461
$F4462
$H4462
$F4463
$H4463
$F446C
$H446C
$F4473
$H4473
$F4480
$H4480
$F4491
$H4491
$F44A0
$H44A0
$F44A1
$H44A1
$F44A3
$H44A3
$F44AC
$H44AC
$F44B0
$H44B0
$F44B1
$H44B1
$F44B3
$H44B3
$F44BC
$H44BC
$F44C0
$H44C0
$F44C1
$H44C1
$F44C2
$H44C2
$F44D0
44D0 Dynamo
$H44D0
44D0 Dynamo
$F44D2
44D2 Dynamo
$H44D2
44D2 Dynamo
$F44D3
44D3 Dynamo
$H44D3
44D3 Dynamo
$F44E2
44E2 Dynamo
$H44E2
44E2 Dynamo
$F44E3
44E3 Dynamo
$H44E3
44E3 Dynamo
$F44F0
$H44F0
$F4501
$H4501
$F4507
$H4507
$F4512
$H4512
$F4513
$H4513
$F4521
$H4521
$F4530
$H4530
$F4536
$H4536
$F4541
$H4541
$F4550
$H4550
$F4560
$H4560
$F4570
$H4570
$F4580
$H4580
$F4590
$H4590
$F45A0
$H45A0
$F45C0
$H45C0
$F45E3
$H45E3
$F45F2
$H45F2
$F45F3
$H45F3
$F4600
$H4600
$F4610
$H4610
$F4620
$H4620
$F4630
$H4630
$F4640
$H4640
$F4650
$H4650
$F4660
4660 Power supply
$H4660
4660 Power supply
$F4661
4661 Power supply
$H4661
4661 Power supply
$F4670
4670 Power supply
$H4670
4670 Power supply
$F4671
4671 Power supply
$H4671
4671 Power supply
$F4680
4680 Power supply
$H4680
4680 Power supply
$F4681
4681 Power supply
$H4681
4681 Power supply
$F4690
4690 Power supply
$H4690
4690 Power supply
$F4691
4691 Power supply
$H4691
4691 Power supply
$F46A0
$H46A0
$F46A1
$H46A1
$F46A2
$H46A2
$F46A3
$H46A3
$F46B0
$H46B0
$F46B1
$H46B1
$F46B2
$H46B2
$F46B3
$H46B3
$F46C0
$H46C0
$F46C1
$H46C1
$F46D0
$H46D0
$F46D1
$H46D1
$F46D2
$H46D2
$F46D3
$H46D3
$F4703
$H4703
$F4711
$H4711
$F4712
$H4712
$F4713
$H4713
$F4723
$H4723
$F4730
$H430
$F4731
$H4731
$F4732
$H4732
$F4740
$H4740
$F4750
$H4750
$F4753
$H4753
$F4763
$H4763
$F4773
$H4773
$F4780
$H4780
$F4781
$H4781
$F4782
$H4782
$F4783
$H4783
$F4803
$H4803
$F4810
$H4810
$F4830
$H4830
$F4831
$H4831
$F4841
$H4841
$F4850
$H4850
$F4863
$H4863
$F48F2
48F2 PT-CAN-bus
$H48F2
48F2 PT-CAN-bus
$F48F3
48F3 PT-CAN-bus
$H48F3
48F3 PT-CAN-bus
$F4900
$H4900
$F4912
4912 PT-CAN-bus
$H4912
4912 PT-CAN-bus
$F4913
4913 PT-CAN-bus
$H4913
4913 PT-CAN-bus
$F4920
$H4920
$F4991
$H4991
$F4992
$H4992
$F49A2
$H49A2
$F49B0
$H49B0
$F49C0
$H49C0
$F49D2
$H49D2
$F49E0
$H49E0
$F49F2
$H49F2
$F49F3
$H49F3
$F4A02
4A02 Terminal 15
$H4A02
4A02 Terminal 15
$F4A03
4A03 Terminal 15
$H4A03
4A03 Terminal 15
$F4A10
4A10 BSD interface
$H4A10
4A10 BSD interface
$F4A13
4A13 BSD interface
$H4A13
4A13 BSD interface
$F4A30
$H4A30
$F4A31
$H4A31
$F4A32
$H4A32
$F4A33
$H4A33
$F4A41
4A41 EWS interface
$H4A41
4A41 EWS interface
$F4A42
4A42 EWS interface
$H4A42
4A42 EWS interface
$F4A43
4A43 EWS interface
$H4A43
4A43 EWS interface
$F4A51
$H4A51
$F4A60
$H4A60
$F4A61
$H4A61
$F4A62
$H4A62
$F4A63
$H4A63
$F4A70
$H4A70
$F4A80
$H4A80
$F4AE0
$H4AE0
$F4AE1
$H4AE1
$F4AE2
$H4AE2
$F4AE3
$H4AE3
$F4AF0
$H4AF0
$F4AF1
$H4AF1
$F4B00
$H4B00
$F4B10
$H4B10
$F4B11
$H4B11
$F4B22
$H4B22
$F4B50
$H4B50
$F4B60
$H4B60
$F4B80
$H4B80
$F4B90
$H4B90
$F4BA0
$H4BA0
$F4BA1
$H4BA1
$F4BB0
$H4BB0
$F4BB1
$H4BB1
$F4BB5
$H4BB5
$F4BB6
$H4BB6
$F4BC0
$H4BC0
$F4BC1
$H4BC1
$F4BC2
$H4BC2
$F4BC5
$H4BC5
$F4BC6
$H4BC6
$F4BC7
$H4BC7
$F4BD2
$H4BD2
$F4BD5
4BD5 Engine support
$H4BD5
4BD5 Engine support
$F4BD6
4BD6 Engine support
$H4BD6
4BD6 Engine support
$F4BD7
4BD7 Engine support
$H4BD7
4BD7 Engine support
$F4BD8
4BD8 Engine support
$H4BD8
4BD8 Engine support
$F4BE2
$H4BE2
$F4BE7
$H4BE7
$F4BF2
$H4BF2
$F4BF7
$H4BF7
$F4C00
$H4C00
$F4C01
$H4C01
$F4C02
$H4C02
$F4C06
$H4C06
$F4C07
$H4C07
$F4C12
$H4C12
$F4C15
$H4C15
$F4C16
$H4C16
$F4C17
$H4C17
$F4C20
$H4C20
$F4C21
$H4C21
$F4C22
$H4C22
$F4C27
$H4C27
$F4CA2
$H4CA2
$F4CB2
$H4CB2
$F4DF0
$H4DF0
$F4DF1
$H4DF1
$F4DF2
$H4DF2
$FCD87
$HCD87
BC4
$F0
0 - Unidentified error
$H0
$F1
1 - Diagnostic-Unit is defective
$H1
$F2
2 - DAC
$H2
2 - DAC
$F3
3 - Diagnostic line RxD is faulty
$H3
$F4
4 - Binder 31 is faulty
$H4
$F5
5 - Temperature sensor is defective
$H5
$F6
6 - Binder 15 (12 Volt) is faulty
$H6
$F7
7 - Speed - A - signal
$H7
$F8
8 - Binder R (12 Volt) is faulty
$H8
$F10
10 - Binder 50 is faulty
$H10
$F11
11 - Drive away lock
$H11
$F12
12 - Stanchion-signal faulty
$H12
$F13
13 - Thermo-sensor
$H13
13 - Thermo-sensor
$F15
15 - Data line to the instrument panel is defective
$H15
$F16
16 - Diagnostic line TxD is faulty
$H16
$F17
17 - Binder 30 is faulty
$H17
$F18
18 - Temperature-warning gong is defective
$H18
$F19
19 - Time-warning gong is defective
$H19
$F20
20 - Parking heat system is defective
$H20
$F21
21 - Parking ventilation is defective
$H21
$F22
22 - Travel impulse is not in order
$F22
$F23
23 - Alarm horn is defective
$H23
$F24
24 - Drive-away exit is faulty
$H24
$F25
25 - Parking ventilation is defective
$H25
$F26
26 - Spare Contact Reservoir
$H26
$F0
$H0
$F1
$H1
$F2
2 - DAC
$H2
2 - DAC
$F3
$H3
$F4
$H4
$F5
$H5
$F6
$H6
$F7
$H7
$F8
$H8
$F10
$H10
$F11
$H11
$F12
$H12
$F13
13 - Thermo-sensor
$H13
13 - Thermo-sensor
$F15
$H15
$F16
$H16
$F17
$H17
$F18
$H18
$F19
$H19
$F20
$H20
$F21
$H21
$F22
$F22
$F23
$H23
$F24
$H24
$F25
$H25
$F26
$H26
Последна промяна ppl на 30 Ное 2006, 15:40, променена общо 1 път
BC5
$F0
$H0
$F1
1 - Central advice light is defective
$H1
$F2
2 - Gong T2 is defective
$H2
$F3
3 - Gong T1 is defective
$H3
$F4
4 - Code exit is faulty
$H4
$F5
5 - Alarm horn is defective
$H5
$F6
6 - Timer is defective
$H6
$F7
7 - Temperature entry is faulty
$H7
$F8
8 - Data line CLC is faulty
$H8
$F9
9 - Control line LAC is faulty
$H9
$F0
10 - Data line DATA is faulty
$H10
$F11
11 - Binder R (12Volt) is faulty
$H11
$F12
12 - Binder 15 (12 Volt) is faulty
$H12
$F13
13 - Bonnet-/Radio contact is faulty
$H13
$F14
14 - Speedometer A-signal is not plausible
$H14
$F15
15 - Injection signal DME is missing
$H15
$F16
16 - Stanchion-signal is faulty
$H16
$F17
17 - Diagnostic line TxD is faulty
$H17
$F18
18 - Diagnostic line RxD is faulty
$H18
$F19
19 - Steering-column switch not recognized
$H19
$F20
20 - Dimmer signal is faulty
$H20
$F21
21 - Brake light test switch faulty
$H21
$F0
$H0
$F1
$H1
$F2
$H2
$F3
$H3
$F4
$H4
$F5
$H5
$F6
$H6
$F7
$H7
$F8
$H8
$F9
$H9
$F0
$H10
$F11
$H11
$F12
$H12
$F13
$H13
$F14
$H14
$F15
$H15
$F16
$H16
$F17
$H17
$F18
$H18
$F19
$H19
$F20
$H20
$F21
$H21
BMS
$F0
0 Undefined System Defect
$H0
$F1
1 Fuel-pump relay (EKP relay) EKP
$H1
$F2
2 Idle-Speed Controller
$H2
$F3
3 Injection Valve 2
$H3
3 Injection Valve 2
$F4
4 Injection Valve 4
$H4
4 Injection Valve 4
$F12
12 Throttle-Potentiometer
$H12
$F14
14 Air Flow Sensor
$H14
14 Air Flow Sensor
$F15
15 Knock Sensor 1
$H15
15 Knock Sensor 1
$F16
16 Camshaft Sensor
$H16
16 Camshaft Sensor
$F18
18 System Failure without any meaning
$H18
$F24
24 Ignition Fault on cylinder 3
$H24
$F25
25 Ignition Fault on cylinder 1
$H25
$F29
29 Idle-Speed Controller
$H29
$F31
31 Injection Valve on Cylinder 3
$H31
$F32
32 Injection Valve on Cylinder 1
$H32
$F36
36 Tank ventilation
$H36
36 Tank ventilation
$F37
37 Relay Lambda-Probe Heater
$H37
$F41
41 Air-Flow-Sensor
$H41
41 Air-Flow-Sensor
$F42
42 Knock Sensor 1
$H42
42 Knock Sensor 1
$F44
44 Camshaft sensor
$H44
44 Camshaft sensor
$F46
46 Relay elktro van
$H46
46 Relay elktro van
$F48
48 Air-Conditioner Compressor Shut Off Relay
$H48
$F51
51 Ignition Fault on cylinder 4
$H51
$F52
52 Ignition Fault on cylinder 2
$H52
$F54
54 Power Supply of the Control Unit
$H54
$F59
59 Power Supply of the Control Unit
$H59
$F67
67 Pulse-Generator of the crank-shaft
$H67
$F68
68 Crank-shaft sensor
$H68
$F70
70 Lambda Probe
$H70
70 Lambda Probe
$F71
71 Lambda Probe
$H71
71 Lambda Probe
$F73
73 Speed-Signal Interrupted !
$H73
$F74
74 RPM Signal TD
$H74
74 RPM Signal TD
$F76
76 Idle Co-Potentiometer
$H76
$F77
77 Temperature Sensor Intake Air
$H77
$F78
78 Temperature Sensor-Engine
$H78
$F81
81 Theft Warning System Signal
$H81
$F83
83 Airco signal
$H83
83 Airco signal
$F85
85 Air-Conditioner Compressor Relay
$H85
$F86
86 Aircondotioning Switch
$H86
$F87
87 Diagnotic Lead
$H87
87 Diagnostic Lead
$F100
100 Injection Valve 1
$H100
$F101
101 Injection Valve 2
$H101
$F102
102 Injection Valve 3
$H102
$F103
103 Injection Valve 4
$H103
$F104
104 Injection Valve 1
$H104
$F105
105 Injection Valve 2
$H105
$F106
106 Injection Valve 3
$H106
$F107
107 Injection Valve 4
$H107
$F108
108 Electro ventilator
$H108
$F110
110 Airco compressor
$H110
$F111
111 Fuel pump
$H111
111 Fuel pump
$F112
112 Fuel recirculation valve
$H112
$F113
113 Fuel recirculation valve
$H113
$F114
114 Pyto tube pressure valve
$H114
$F115
115 Parametric cooling
$H115
$F117
117 Idle speed actuator activation
$H117
$F118
118 Lambda probe heating before kat
$H118
$F119
119 Throttle valve potentiometer
$H119
$F120
120 HFM Sensor
$H120
120 HFM Sensor
$F121
121 Intake Air Temperature Sensor
$H121
$F122
122 Coolant temperature sensor
$H122
$F123
123 Coolant water temperature sensor
$H123
$F124
124 Battery tension
$H124
124 Battery tension
$F125
125 Lambda probe before kat
$H125
$F126
126 ASC / CAN Signal
$H126
$F127
127 ASC / CAN Signal
$H127
$F128
128 EGS / CAN Signal
$H128
$F129
129 EGS / CAN Signal
$H129
$F130
130 CAN Signal Kombi Instrument
$H130
$F131
131 Vehicle speed signal
$H131
$F132
132 HFM reference tension
$H132
$F133
133 DTK reference tension
$H133
$F135
135 Camshaft Sensor
$H135
135 Camshaft Sensor
$F136
136 Crankshaft sensor
$H136
$F137
137 Knock Sensor 1
$H137
137 Knock Sensor 1
$F140
140 DME / EWS Port Faulty
$H140
$F141
141 Lambda regulation
$H141
$F142
142 Knock regulation
$H142
$F143
143 DME Control Unit
$H143
$F144
144 EWS Manipulation
$H144
$F145
145 Misfire cylinder 1
$H145
$F146
146 Misfire cylinder 2
$H146
$F147
147 Misfire cylinder 3
$H147
$F148
148 Misfire cylinder 4
$H148
$F149
149 Secondary air pump valve
$H149
$F150
150 Secondary air pump
$H150
$F153
153 Lambda probe heating
$H153
$F171
171 Fuel supply system
$H171
$F200
200 DME Control Unit
$H200
$F201
201 Lambda Regulation
$H201
$F202
202 Control unit
$H203
202 Control unit
$F203
203 Ignition system
$H203
203 Ignition system
$F204
204 Idle-Speed Revolutions Per Minute Lifting
$H204
$F206
206 Knock regulation
$H206
$F216
216 CAN : BUS -> No ASC signal
$H216
$F220
220 EWS : No Function
$H220
$F236
236 CAN : BUS -> No EGS signal
$H236
$F0
$H0
$F1
$H1
$F2
$H2
$F3
3 Injection Valve 2
$H3
3 Injection Valve 2
$F4
4 Injection Valve 4
$H4
4 Injection Valve 4
$F12
$H12
$F14
14 Air Flow Sensor
$H14
14 Air Flow Sensor
$F15
15 Knock Sensor 1
$H15
15 Knock Sensor 1
$F16
16 Camshaft Sensor
$H16
16 Camshaft Sensor
$F18
$H18
$F24
$H24
$F25
$H25
$F29
$H29
$F31
$H31
$F32
$H32
$F36
36 Tank ventilation
$H36
36 Tank ventilation
$F37
$H37
$F41
41 Air-Flow-Sensor
$H41
41 Air-Flow-Sensor
$F42
42 Knock Sensor 1
$H42
42 Knock Sensor 1
$F44
44 Camshaft sensor
$H44
44 Camshaft sensor
$F46
46 Relay elktro van
$H46
46 Relay elktro van
$F48
$H48
$F51
$H51
$F52
$H52
$F54
$H54
$F59
$H59
$F67
$H67
$F68
$H68
$F70
70 Lambda Probe
$H70
70 Lambda Probe
$F71
71 Lambda Probe
$H71
71 Lambda Probe
$F73
$H73
$F74
74 RPM Signal TD
$H74
74 RPM Signal TD
$F76
$H76
$F77
$H77
$F78
$H78
$F81
$H81
$F83
83 Airco signal
$H83
83 Airco signal
$F85
$H85
$F86
$H86
$F87
87 Diagnotic Lead
$H87
87 Diagnostic Lead
$F100
$H100
$F101
$H101
$F102
$H102
$F103
$H103
$F104
$H104
$F105
$H105
$F106
$H106
$F107
$H107
$F108
$H108
$F110
$H110
$F111
111 Fuel pump
$H111
111 Fuel pump
$F112
$H112
$F113
$H113
$F114
$H114
$F115
$H115
$F117
$H117
$F118
$H118
$F119
$H119
$F120
120 HFM Sensor
$H120
120 HFM Sensor
$F121
$H121
$F122
$H122
$F123
$H123
$F124
124 Battery tension
$H124
124 Battery tension
$F125
$H125
$F126
$H126
$F127
$H127
$F128
$H128
$F129
$H129
$F130
$H130
$F131
$H131
$F132
$H132
$F133
$H133
$F135
135 Camshaft Sensor
$H135
135 Camshaft Sensor
$F136
$H136
$F137
137 Knock Sensor 1
$H137
137 Knock Sensor 1
$F140
$H140
$F141
$H141
$F142
$H142
$F143
$H143
$F144
$H144
$F145
$H145
$F146
$H146
$F147
$H147
$F148
$H148
$F149
$H149
$F150
$H150
$F153
$H153
$F171
$H171
$F200
$H200
$F201
$H201
$F202
202 Control unit
$H203
202 Control unit
$F203
203 Ignition system
$H203
203 Ignition system
$F204
$H204
$F206
$H206
$F216
$H216
$F220
$H220
$F236
$H236
Последна промяна ppl на 30 Ное 2006, 15:41, променена общо 1 път
CAS
$F9305
9305 Under voltage error
$H9305
$FA0A8
A0A8 Control Unit Faulty
$HA0A8
$FA0AA
A0AA Control Unit Faulty
$HA0AA
$FA0AB
A0AB Program error
$HA0AB
A0AB Program error
$FA0AC
A0AC Control Unit Faulty
$HA0AC
$FA0AD
A0AD Control Unit Faulty
$HA0AD
$FA0B0
A0B0 Brake light not plausible
$HA0B0
$FA0B1
A0B1 Selector leaver / clutch switch : not plausible
$HA0B1
$FA0B2
A0B2 Power supply terminal 30E
$HA0B2
$FA0B3
A0B3 Power supply terminal 50
$HA0B3
$FA0B4
AHB4 Starting of the engine
$FA0B4
A0B4 Starting of the engine
$FA0B5
A0B5 Wheel rpm sensor
$HA0B5
$FA0B8
A0B8 Hall sensor key locked
$HA0B8
$FA0B9
A0B9 Hall sensor key eject
$HA0B9
$FA0BA
A0BA Hall sensor start-/stop button
$HA0BA
$FA0BB
A0BB Hall sensor start-/stop button
$HA0BB
$FA0BC
A0BC Contact lock magnet
$HA0BC
$FA0BD
A0BD Output Wakeup-wire PT-CAN
$HA0BD
$FA0BE
A0BE Terminal 15 output 1
$HA0BE
$FA0BF
A0BF Terminal 15 output 2
$HA0BF
$FA0C0
A0C0 Terminal 15 output 3
$HA0C0
$FA0C1
A0C1 output Terminal 50 short circuit
$HA0C1
$FA0C2
A0C2 output Terminal 50
$HA0C2
$FA0C3
A0C3 output Wakeup-wire ACC
$HA0C3
$FA0C4
A0C4 Terminal 15 output 4
$HA0C4
$FA0C8
A0C8 Lock cylinder drivers door
$HA0C8
$FA0CC
A0CC Permanent signal open window
$HA0CC
$FA0CF
A0CF Outside door, door grip
$HA0CF
$FA0E0
A0E0 Lock switch central locking
$HA0E0
$FA0E1
A0E1 Open switch central locking
$HA0E1
$FA0F0
A0F0 Transponder coil
$HA0F0
$FA0F1
A0F1 EWS key data
$HA0F1
A0F1 EWS key data
$FA0F2
A0F2 Wrong key copy
$HA0F2
A0F2 Wrong key copy
$FA0F3
A0F3 EWS key data
$HA0F3
A0F3 EWS key data
$FA100
A100 EWS code
$HA100
A100 EWS code
$FD904
D904 K-CAN wiring error
$HD904
$FD905
D905 Spare
$HD905
D905 Spare
$FD906
D906 Spare
$HD906
D906 Spare
$FD907
D907 K-CAN communication error
$HD907
$FD940
D940 Spare
$HD940
D940 Spare
$FD941
D941 Spare
$HD941
D941 Spare
$FD942
D942 Spare
$HD942
D942 Spare
$FE904
E904 K-CAN PERIPHERIE wiring error
$HE904
$FE905
E905 Spare
$HE905
E905 Spare
$FE907
E907 K-CAN PERIPHERIE communication error
$HE907
$F9305
$H9305
$FA0A8
$HA0A8
$FA0AA
$HA0AA
$FA0AB
A0AB Program error
$HA0AB
A0AB Program error
$FA0AC
$HA0AC
$FA0AD
$HA0AD
$FA0B0
$HA0B0
$FA0B1
$HA0B1
$FA0B2
$HA0B2
$FA0B3
$HA0B3
$FA0B4
$FA0B4
$FA0B5
$HA0B5
$FA0B8
$HA0B8
$FA0B9
$HA0B9
$FA0BA
$HA0BA
$FA0BB
$HA0BB
$FA0BC
$HA0BC
$FA0BD
$HA0BD
$FA0BE
$HA0BE
$FA0BF
$HA0BF
$FA0C0
$HA0C0
$FA0C1
$HA0C1
$FA0C2
$HA0C2
$FA0C3
$HA0C3
$FA0C4
$HA0C4
$FA0C8
$HA0C8
$FA0CC
$HA0CC
$FA0CF
$HA0CF
$FA0E0
$HA0E0
$FA0E1
$HA0E1
$FA0F0
$HA0F0
$FA0F1
A0F1 EWS key data
$HA0F1
A0F1 EWS key data
$FA0F2
A0F2 Wrong key copy
$HA0F2
A0F2 Wrong key copy
$FA0F3
A0F3 EWS key data
$HA0F3
A0F3 EWS key data
$FA100
A100 EWS code
$HA100
A100 EWS code
$FD904
$HD904
$FD905
D905 Spare
$HD905
D905 Spare
$FD906
D906 Spare
$HD906
D906 Spare
$FD907
$HD907
$FD940
D940 Spare
$HD940
D940 Spare
$FD941
D941 Spare
$HD941
D941 Spare
$FD942
D942 Spare
$HD942
D942 Spare
$FE904
$HE904
$FE905
E905 Spare
$HE905
E905 Spare
$FE907
$HE907
Последна промяна ppl на 30 Ное 2006, 15:42, променена общо 1 път
CVM
$F1
01 Control unit error : coding data, not coded
$H1
$F2
02 Control unit error : coding not plausible, CVM II or III
$H2
002 Control unit error : coding not plausible, CVM II or III
$F3
03 Control unit error : ROM EEPROM internal checksum error
$H3
$F5
05 Control unit error : checksum error in coding data
$H5
$F6
06 Control unit error : RAM internal error
$H6
$F7
07 Control unit error : Watchdog
$H7
$F8
08 Control unit error : Opcode
$H8
$F9
09 Control unit error : Clock-Monitor
$H9
$F10
10 Vehicle switches : power supply
$H10
$F11
11 Soft top switches : power supply
$H11
$F12
12 Soft Top Open Switch : continuously active
$H12
$F13
13 Soft Top Close Switch : continuously active
$H13
$F17
17 Potentiometer Main 'SAULE'
$H17
$F19
19 Potentiometer for Bow
$H19
$F1A
1A Soft Top Open Switch, Tension >5 Volt
$H1A
$F1B
1B Soft Top Open Switch, Tension not defined
$H1B
$F1C
1C Soft Top Open Switch, Tension at ground level
$H1C
$F1D
1D Airflow switch locked, Tension >5 Volt
$H1D
$F1E
1E Airflow switch locked, Tension not defined
$H1E
$F1F
1F Airflow switch locked, Tension at ground level
$H1F
$F20
20 Airflow switch unlocked, Tension >5 Volt
$H20
$F21
21 Airflow switch unlocked, Tension not defined
$H21
$F22
22 Airflow switch unlocked, Tension at ground level
$H22
$F23
23 Soft Top Closed Switch, Tension >5 Volt.
$H23
$F24
24 Soft Top Open Switch, Tension not defined
$H24
$F25
25 Soft Top Open Switch, Tension at ground level
$H25
$F26
26 VSW 7.2, Tension >5 Volt
$H26
$F27
27 VSW 7.2, Tension not defined
$H27
$F28
28 VSW 7.2, Tension at ground level
$H28
$F29
29 Soft Top closed switch, Tension >5 Volt
$H29
$F2A
2A Soft Top closed switch, Tension not defined
$H2A
$F2B
2B Soft Top closed switch, Tension at ground level
$H2B
$F2C
2C Front lower soft top switch, Tension >5 Volt
$H2C
$F2D
2D Front lower soft top switch, Tension not defined
$H2D
$F2E
2E Front lower soft top switch, Tension at ground level
$H2E
$F40
40 Traction Windlauf, Engine current to high, Locking short circuit
$H40
$F41
41 Traction Windlauf, Engine current to high, Locking short circuit
$H41
$F42
42 Short circuit Engine bridge or Engine to Ub+
$H42
$F43
43 Traction Windlauf, Error during unlocking
$H43
$F44
44 Traction Windlauf, Error during unlocking
$H44
$F60
60 Soft topcover does not open : timeout
$H60
$F53
53 Pump Relay : open circuit
$H53
$F54
54 Pump Relay : short circuit
$H54
$F58
58 Soft top cover valve : short circuit
$H58
$F67
67 Windlauf does not come out
$H67
$F68
68 Windlauf does not come out
$H68
$F69
69 Pump relays 1 not connected
(Pump relay opening : output -> open)
$H69
$F6A
6A Pump relays 1 short to ground
(Pump relay opening : output -> ground)
$H6A
$F6B
6B Pump relays 1 short to Plus
(Pump relay opening : output -> Ubatt)
$H6B
$F6C
6C Pump relays 2 not connected
(Pump relay closing : output -> open)
$H6C
$F6D
6D Pump relays 2 short to ground
(Pump relay closing : output -> Ground)
$H6D
$F6E
6E Pump relays 2 short to Plus.
(Pump relay closing : output -> Ubatt)
$H6E
$F1
$H1
$F2
$H2
$F3
$H3
$F5
$H5
$F6
$H6
$F7
$H7
$F8
$H8
$F9
$H9
$F10
$H10
$F11
$H11
$F12
$H12
$F13
$H13
$F17
$H17
$F19
$H19
$F1A
$H1A
$F1B
$H1B
$F1C
$H1C
$F1D
$H1D
$F1E
$H1E
$F1F
$H1F
$F20
$H20
$F21
$H21
$F22
$H22
$F23
$H23
$F24
$H24
$F25
$H25
$F26
$H26
$F27
$H27
$F28
$H28
$F29
$H29
$F2A
$H2A
$F2B
$H2B
$F2C
$H2C
$F2D
$H2D
$F2E
$H2E
$F40
$H40
$F41
$H41
$F42
$H42
$F43
$H43
$F44
$H44
$F60
$H60
$F53
$H53
$F54
$H54
$F58
$H58
$F67
$H67
$F68
$H68
$F69
$H69
$F6A
$H6A
$F6B
$H6B
$F6C
$H6C
$F6D
$H6D
$F6E
$H6E
Последна промяна ppl на 30 Ное 2006, 15:43, променена общо 1 път
DSC
$F5D90
5D90 Control Unit : Valve Relay
$H5D90
$F5D91
5D91 Control Unit : Valve Relay
$H5D91
$F5D92
5D92 Control Unit : Valve Relay
$H5D92
$F5D93
5D93 Control Unit : Valve Relay
$H5D93
$F5D94
5D94 Control Unit : Valve Relay
$H5D94
$F5D95
5D95 Control Unit : Valve Relay
$H5D95
$F5D96
5D96 Control Unit : Valve Relay
$H5D96
$F5D97
5D97 Control Unit : Valve Relay
$H5D97
$F5D98
5D98 Hydraulic unit valve : EVVL
$H5D98
$F5D99
5D99 Hydraulic unit valve : EVVL
$H5D99
$F5D9B
5D9B Hydraulic unit valve : EVVL
$H5D9B
$F5D9D
5D9D Hydraulic unit valve : AVVL
$H5D9D
$F5D9E
5D9E Hydraulic unit valve : AVVL
$H5D9E
$F5DA1
5DA1 Hydraulic unit valve : EVVR
$H5DA1
$F5DA2
5DA2 Hydraulic unit valve : EVVR
$H5DA2
$F5DA6
5DA6 Hydraulic unit valve : AVVR
$H5DA6
$F5DA7
5DA7 Hydraulic unit valve : AVVR
$H5DA7
$F5DAA
5DAA Hydraulic unit valve : EVHL
$H5DAA
$F5DAB
5DAB Hydraulic unit valve : EVHL
$H5DAB
$F5DAD
5DAD Hydraulic unit valve : EVHL
$H5DAD
$F5DAF
5DAF Hydro-aggregaat valve : AVHL
$H5DAF
$F5DB0
5DB0 Hydraulic unit valve : AVHL
$H5DB0
$F5DB3
5DB3 Hydraulic unit valve : EVHR
$H5DB3
$F5DB4
5DB4 Hydraulic unit valve : EVHR
$H5DB4
$F5DB8
5DB8 Hydraulic unit valve : AVHR
$H5DB8
$F5DB9
5DB9 Hydraulic unit valve : AVHR
$H5DB9
$F5DBC
5DBC Hydraulic unit valve : USV1
$H5DBC
$F5DBD
5DBD Hydraulic unit valve : USV1
$H5DBD
$F5DBF
5DBF Hydraulic unit valve : USV1
$H5DBF
$F5DC1
5DC1 Hydraulic unit valve : USV2
$H5DC1
$F5DC2
5DC2 Hydraulic unit valve : USV2
$H5DC2
$F5DC6
5DC6 Hydraulic unit valve : HSV1
$H5DC6
$F5DC7
5DC7 Hydraulic unit valve : HSV1
$H5DC7
$F5DCA
5DCA Hydraulic unit valve : HSV2
$H5DCA
$F5DCB
5DCB Hydraulic unit valve : HSV2
$H5DCB
$F5DCE
5DCE Control Unit Power Supply : voltage to low
$H5DCE
$F5DCF
5DCF Control Unit Power Supply : voltage to low
$H5DCF
$F5DD0
5DD0 Control Unit Power Supply : voltage to high
$H5DD0
$F5DD1
5DD1 Control Unit : Internal
$H5DD1
$F5DD2
5DD2 Control Unit Power Supply : voltage to high
$H5DD2
$F5DD3
5DD3 Control Unit : Internal
$H5DD3
$F5DD4
5DD4 Control Unit : Internal
$H5DD4
$F5DD5
5DD5 Control Unit : Internal
$H5DD5
$F5DD6
5DD6 Control Unit : Internal
$H5DD6
$F5DD8
5DD8 Control Unit : Internal
$H5DD8
$F5DD9
5DD9 Control Unit : Internal
$H5DD9
$F5DDC
5DDC Control Unit : Internal
$H5DDC
$F5DDD
5DDD Control Unit : Internal
$H5DDD
$F5DDE
5DDE Control Unit : Internal
$H5DDE
$F5DDF
5DDF Control Unit : Internal
$H5DDF
$F5DE0
5DE0 Control Unit : Internal
$H5DE0
$F5DE1
5DE1 Control Unit : Internal
$H5DE1
$F5DE2
5DE2 Control Unit : Internal
$H5DE2
$F5DE3
5DE3 Control Unit : Internal
$H5DE3
$F5DE4
5DE4 Control Unit : Internal
$H5DE4
$F5DEE
5DEE Control Unit : Internal
$H5DEE
$F5DEF
5DEF Control Unit : Internal
$H5DEF
5DFF Control Unit : Internal
$F5DF0
5DF0 Control Unit : Internal
$H5DF0
$F5DF1
5DF1 Control Unit : Internal
$H5DF1
$F5DF2
5DF2 Control Unit : Internal
$H5DF2
$F5DF3
5DF3 Control Unit : Internal
$H5DF3
$F5DF5
5DF5 Control Unit : Internal
$H5DF5
$F5DF6
5DF6 Control Unit : Internal
$H5DF6
$F5DF7
5DF7 Control Unit : Internal
$H5DF7
$F5DF8
5DF8 Control Unit : Internal
$H5DF8
$F5DF9
5DF9 Control Unit : Internal
$H5DF9
$F5DFA
5DFA Control Unit : Internal
$H5DFA
$F5DFB
5DFB Control Unit : Internal
$H5DFB
$F5DFC
5DFC Control Unit : Internal
$H5DFC
$F5DFD
5DFD Control Unit : Internal
$H5DFD
$F5DFE
5DFEControl Unit : Internal
$H5DFE
5DFE Control Unit : Internal
$F5DFF
$H5DFF
$F5E00
5E00 Control Unit : Internal
$H5E00
$F5E01
5E01 Control Unit : Internal
$H5E01
$F5E02
5E02 Control Unit : Internal
$H5E02
$F5E03
5E03 Control Unit : Internal
$H5E03
$F5E04
5E04 Control Unit : Internal
$H5E04
$F5E05
5E05 Control Unit : Internal
$H5E05
$F5E06
5E06 Control Unit : Internal
$H5E06
$F5E07
5E07 Control Unit : Internal
$H5E07
$F5E08
5E08 Control Unit : Internal
$H5E08
$F5E
5E09 Control Unit : Internal
$H5E
$F5E0A
5E0A Control Unit : Internal
$5E0A
$F5E0B
5E0B Control Unit : Internal
$H5E0B
$F5E0C
5E0C Control Unit : Internal
$H5E0C
$F5E0D
5E0D Control Unit : Internal
$H5E0D
$F5E0E
5E0E Control Unit : Internal
$H5E0E
$F5E0F
5E0F Control Unit : Internal
$H5E0F
$F5E10
5E10 Control Unit : Internal
$H5E10
$F5E11
5E11 Control Unit : Internal
$H5E11
$F5E12
5E12 Control Unit : Internal
$H5E12
$F5E13
5E13 Control Unit : Internal
$H5E13
$F5E14
5E14 Control Unit : Internal
$H5E14
$F5E15
5E15 Control Unit : Internal
$H5E15
$F5E16
5E16 Control Unit : Internal
$H5E16
$F5E17
5E17 Control Unit : Internal
$H5E17
$F5E18
5E18 Control Unit : Internal
$H5E18
$F5E19
5E19 Control Unit : Internal
$H5E19
$F5E1A
5E1A Control Unit : Internal
$H5E1A
$F5E1B
5E1B Control Unit : Internal
$H5E1B
$F5E1C
5E1C Control Unit : Internal
$H5E1C
$F5E1D
5E1D Control Unit : Internal
$H5E1D
$F5E1E
5E1E Control Unit : Flash programing
$H5E1E
$F5E1F
5E1F Control Unit : status indication
$H5E1F
$F5E20
5E20 Control Unit : Internal
$H5E20
$F5E21
5E21 Control Unit : Internal
$H5E21
$F5E22
5E22 Front left wheel sensor : power supply
$H5E22
$F5E24
5E24 Front left wheel sensor : power supply
$H5E24
$F5E25
5E25 Front left wheel sensor : not plausible
$H5E25
$F5E26
5E26 Front left wheel sensor : air chink
$H5E26
$F5E27
5E27 Front left wheel sensor : not plausible
$H5E27
$F5E28
5E28 Front left wheel sensor : magnetic valve
$H5E28
$F5E2D
5E2D Front left wheel sensor : wheel bearing
$H5E2D
$F5E2E
5E2E Front left wheel sensor : not plausible
$H5E2E
$F5E2F
5E2F Front left wheel sensor : not plausible
$H5E2F
$F5E30
5E30 Rear left wheel sensor : power supply
$H5E30
$F5E32
5E32 Rear left wheel sensor : power supply
$H5E32
$F5E33
5E33 Rear left wheel sensor : not plausible
$H5E33
$F5E34
5E34 Rear left wheel sensor : air chink
$H5E34
$F5E35
5E35 Rear left wheel sensor : not plausible
$H5E35
$F5E36
5E36 Rear left wheel sensor : magnetic valve
$H5E36
$F5E3B
5E3B Rear left wheel sensor : wheel bearing
$H5E3B
$F5E3C
5E3C Rear left wheel sensor : not plausible
$H5E3C
$F5E3D
5E3D Rear left wheel sensor : not plausible
$H5E3D
$F5E3E
5E3E Rear right wheel sensor : power supply
$H5E3E
$F5E40
5E40 Rear right wheel sensor : power supply
$H5E40
$F5E41
5E41 Rear right wheel sensor : not plausible
$H5E41
$F5E42
5E42 Rear right wheel sensor : air chink
$H5E42
$F5E43
5E43 Rear right wheel sensor : not plausible
$H5E43
$F5E44
5E44 Rear right wheel sensor : magnetic valve
$H5E44
$F5E49
5E49 Rear right wheel sensor : wheel bearing
$H5E49
$F5E4A
5E4A Rear right wheel sensor : not plausible
$H5E4A
$F5E4B
5E4B Rear right wheel sensor : not plausible
$H5E4B
$F5E4C
5E4C Front right wheel sensor : power supply
$H5E4C
$F5E4E
5E4E Front right wheel sensor : power supply
$H5E4E
$F5E4F
5E4F Front right wheel sensor : not plausible
$H5E4F
$F5E50
5E50 Front right wheel sensor : air chink
$H5E50
$F5E51
5E51 Front right wheel sensor : not plausible
$H5E51
$F5E52
5E52 Front right wheel sensor : magnetic valve
$H5E52
$F5E57
5E57 Front right wheel sensor : wheel bearing
$H5E57
$F5E58
5E58 Front right wheel sensor : not plausible
$H5E58
$F5E59
5E59 Front right wheel sensor : not plausible
$H5E59
$F5E5C
5E5C Wielsensor draairichtingherkenning
$H5E5C
$F5E5D
5E5D Wheel sensor : general
$H5E5D
$F5E5E
5E5E Wheel sensor : general
$H5E5E
$F5E60
5E60 Break light switch
$H5E60
$F5E62
5E62 Break light switch : continuiusly activated
$H5E62
$F5E6A
5E6A CAN-ERROR
$H5E6A
5E6A CAN-ERROR
$F5E6B
5E6B CAN-ERROR
$H5E6B
5E6B CAN-ERROR
$F5E72
5E72 CAN-ERROR
$H5E72
5E72 CAN-ERROR
$F5E74
5E74 CAN-ERROR
$F5E74
5E74 CAN-ERROR
$F5E75
5E75 CAN-ERROR
$H5E75
5E75 CAN-ERROR
$F5E76
5E76 CAN-ERROR
$H5E76
5E76 CAN-ERROR
$F5E77
5E77 CAN-ERROR
$H5E77
5E77 CAN-ERROR
$F5E7A
5E7A CAN-ERROR
$H5E7A
5E7A CAN-ERROR
$F5E7E
5E7E CAN-ERROR
$H5E7E
5E7E CAN-ERROR
$F5E83
5E83 CAN-ERROR
$H5E83
5E83 CAN-ERROR
$F5E84
5E84 CAN-ERROR
$H5E84
5E84 CAN-ERROR
$F5E85
5E85 CAN-ERROR
$H5E85
5E85 CAN-ERROR
$F5E89
5E89 CAN-ERROR
$H5E89
5E89 CAN-ERROR
$F5E8A
5E8A CAN-ERROR
$H5E8A
5E8A CAN-ERROR
$F5E8B
5E8B CAN-ERROR
$H5E8B
5E8B CAN-ERROR
$F5E8C
5E8C Message : trailer signal missing
$H5E8C
$F5E8E
5E8E DSC-sensor internal
$H5E8E
$F5E90
5E90 DSC-sensor lateral acceleration not plausible
$H5E90
$F5E91
5E91 DSC-sensor lateral acceleration not plausible
$H5E91
$F5E92
5E92 DSC-sensor lateral acceleration not plausible
$H5E92
$F5E93
5E93 DSC-sensor lateral acceleration not plausible
$H5E93
$F5E95
5E95 DSC-sensor lateral acceleration not plausible
$H5E95
$F5E96
5E96 DSC-sensor lateral acceleration not plausible
$H5E96
$F5E97
5E97 DSC-sensor internal
$H5E97
$F5E98
5E98 DSC-sensor lateral acceleration not plausible
$H5E98
$F5E99
5E99 DSC-sensor lateral acceleration not plausible
$H5E99
$F5E9A
5E9A DSC-sensor monunting
$H5E9A
$F5E9B
5E9B DSC-sensor twist angel level not plausible
$H5E9B
$F5E9C
5E9C DSC-sensor twist angel level not plausible
$H5E9C
$F5E9D
5E9D DSC-sensor internal
$H5E9D
$F5E9E
5E9E DSC-sensor mounting
$H5E9E
$F5E9F
5E9F DSC-sensor twist angel level not plausible
$H5E9F
$F5EA0
5EA0 DSC-sensor twist angel level not plausible
$H5EA0
$F5EA1
5EA1 DSC-sensor twist angel level not plausible
$H5EA1
$F5EA2
5EA2 DSC-sensor twist angel level not plausible
$H5EA2
$F5EA3
5EA3 DSC-sensor twist angel level not plausible
$H5EA3
$F5EA4
5EA4 DSC-sensor twist angel level not plausible
$H5EA4
$F5EA5
5EA5 DSC-sensor twist angel level not plausible
$H5EA5
$F5EA6
5EA6 DSC-sensor twist angel level not plausible
$H5EA6
$F5EA7
5EA7 DSC-sensor twist angel level not plausible
$H5EA7
$F5EA8
5EA8 DSC-sensor internal
$H5EA8
$F5EA9
5EA9 DSC-sensor twist angel level not plausible
$H5EA9
$F5EAA
5EAA DSC-sensor twist angel level not plausible
$H5EAA
$F5EAB
5EAB DSC-sensor twist angel level not plausible
$H5EAB
$F5EAC
5EAC DSC-sensor twist angel level not plausible
$H5EAC
$F5EAD
5EAD DSC-sensor internal
$H5EAD
$F5EAE
5EAE DSC-sensor internal
$H5EAE
$F5EAF
5EAF DSC-sensor internal
$H5EAF
$F5EBO
5EB0 DSC-sensor internal
$H5EBO
$F5EB1
5EB1 DSC-sensor internal
$H5EB1
$F5EB2
5EB2 DSC-sensor internal
$H5EB2
$F5EB3
5EB3 DSC-sensor power supply
$H5EB3
$F5EB4
5EB4 DSC-sensor power supply
$H5EB4
$F5EB5
5EB5 DSC-sensor power supply
$H5EB5
$F5EBA
5EBA Steering angle sensor not plausible
$H5EBA
$F5EBB
5EBB Steering angle sensor not plausible
$H5EBB
$F5EBC
5EBC Steering angle sensor not plausible
$H5EBC
$F5EBD
5EBD Steering angle sensor F-CAN
$H5EBD
$F5EBE
5EBE Steering angle sensor not plausible
$H5EBE
$F5EBF
5EBF Steering angle sensor internal
$H5EBF
$F5EC0
5EC0 Steering angle sensor compensation
$H5EC0
$F5EC1
5EC1 Steering angle sensor not plausible
$H5EC1
$F5EC5
5EC5 Steering angle sensor F-CAN
$H5EC5
$F5ED4
5ED4 Steering angle sensor not plausible
$H5ED4
$F5ED5
5ED5 Swing recognition : erase the error memory
$H5ED5
$5ED6
5ED6 Control Unit : Internal
$5ED6
$F5EDA
5EDA Variant coding Control Unit : Internal
$H5EDA
$F5EDB
5EDB Variant coding Control Unit : Internal
$H5EDB
$F5EDC
5EDC Variant coding Control Unit : Internal
$H5EDC
$F5EE2
5EE2 Hydraulic unit pressure sensor : internal
$H5EE2
$F5EE4
5EE4 Hydraulic unit pressure sensor : internal
$H5EE4
$F5EE5
5EE5 Hydraulic unit pressure sensor : internal
$H5EE5
$F5EE7
5EE7 Hydraulic unit pressure sensor : internal
$H5EE7
$F5EED
5EED Hydraulic unit pressure sensor : internal
$H5EED
$F5EEE
5EEE Hydro-aggregaat pressure sensor: internal
$H5EEE
$F5EEF
5EEF Hydro-aggregaat pressure sensor: not plausible
$H5EEF
$F5EF0
5EF0 Hydro-aggregaat pressure sensor: not plausible
$H5EF0
$F5EF2
5EF2 Pressure sensor front axelle : internal
$H5EF2
$F5EF3
5EF3 Pressure sensor rear axelle : internal
$H5EF3
$F5EF4
5EF4 Pressure sensor front axelle : internal
$H5EF4
$F5EF5
5EF5 Pressure sensor rear axelle : internal
$H5EF5
$F5EF6
5EF6 Pressure sensor front axelle : wiring
$H5EF6
$F5EF7
5EF7 Pressure sensor rear axelle : wiring
$H5EF7
$F5EF8
5EF8 Pressure sensor front- /rear axelle : power supply
$H5EF8
$F5EF9
5EF9 Control Unit : Internal
$H5EF9
$F5EFA
5EFA Control Unit : Internal
$H5EFA
$F5EFB
5EFB Variant coding Control Unit : Internal
$H5EFB
$F5EFC
5EFC Vehicle specification missing
$H5EFC
$F5EFD
5EFD Ignore error and erase the memory
$H5EFD
$F5EFE
5EFE Front left wheel speed sensor : not plausible
$H5EFE
$F5EFF
5EFF Rear left wheel speed sensor : not plausible
$H5EFF
$F5F00
5F00 Rear right wheel speed sensor : not plausible
$H5F00
$F5F01
5F01 Front right wheel speed sensor : not plausible
$H5F01
$F5F02
5F02 Wheel speed sensor: general
$H5F02
$F5F03
5F03 Control Unit : Internal
$H5F03
$F5F04
5F04 Control Unit : Internal
$H5F04
$F5F05
5F05 Control Unit : Internal
$H5F05
$F5F06
5F06 Control Unit : Internal
$H5F06
$F5F07
5F07 ACC-sensor internal
$H5F07
$F5F08
5F08 ACC-sensor internal
$H5F08
$F5F09
5F09 ACC-sensor internal
$H5F09
$F5F0A
5F0A Ignore error and erase the memory
$H5F0A
$F5F0C
5F0C Steering angle sensor wheelhouse
$H5F0C
$F5F0D
5F0D Steering angle sensor wheelhouse
$H5F0D
$F5F0E
5F0E Steering angle sensor wheelhouse
$H5F0E
$F5F0F
5F0F Steering angle sensor wheelhouse
$H5F0F
$F5F10
5F10 Brake block wear front axelle : sensor
$H5F10
$F5F11
5F11 Brake block wear rear axelle : sensor
$H5F11
$F5F12
5F12 Brake block wear front axelle : brake block
$H5F12
$F5F13
5F13 Brake block wear rear axelle : brake block
$H5F13
$F5F14
5F14 Brake block wear front axelle : not plausible
$H5F14
$F5F15
5F15 Brake block wear rear axelle : not plausible
$H5F15
$F5F16
5F16 Control Unit : Internal
$H5F16
$F5F17
5F17 Control Unit : Internal
$H5F17
$F5F18
5F18 Ignore this error anderase the error memory
$H5F18
$F5F1A
5F1A Reduced drive performace
$H5F1A
$F5F1B
5F1B Control Unit : Internal
$H5F1B
$F5F1E
5F1E Ignore this error anderase the error memory
$H5F1E
$F5F1F
5F1F Dynamic Drive: internal
$H5F1F
$F5F20
5F20 Control Unit : Internal
$H5F20
$F5F21
5F21 Control Unit : Internal
$H5F21
$F5F22
5F22 Control Unit : Internal
$H5F22
$F5F23
5F23 Control Unit : Internal
$H5F23
$F5F24
5F24 Ignore this error anderase the error memory
$H5F24
$F5F25
5F25 Dynamic Drive: internal
$H5F25
$F5F26
5F26 Dynamic Drive: internal
$H5F26
$F5F2C
5F2C Control Unit : Internal
$H5F2C
$F5F2D
5F2D ACC-sensor: internal
$H5F2D
$F5F2E
5F2E Transmission Control : internal
$H5F2E
$F5F2F
5F2F Transmission Control : internal
$H5F2F
$F5F30
5F30 Engine managment connection
$H5F30
$F5F31
5F31 Engine managment connection
$H5F31
$F5F32
5F32 Engine managment connection
$H5F32
$F5F33
5F33 Engine managment connection
$H5F33
$F5F34
5F34 Engine managment connection
$H5F34
$F5F35
5F35 Engine managment connection
$H5F35
$F5F36
5F36 Engine managment connection
$H5F36
$F5F40
5F40 Ignore this error anderase the error memory
$H5F40
$5F45
5F45 Brake fluid level to low
$5F45
$5F47
5F47 Instrument Cluster : internal
$5F47
$5F48
5F48 Instrument Cluster : internal
$5F48
$5F49
5F49 Instrument Cluster : internal
$5F49
$5F4A
5F4A Instrument Cluster : internal
$5F4A
$5F4B
5F4B Instrument Cluster : internal
$5F4B
$5F4C
5F4C Message : Instrument Cluster signal missing
$5F4C
$5F50
5F50 Ignore this error anderase the error memory
$5F50
$5F52
5F52 CCC-storing: internal
$5F52
$5F54
5F54 Car Access Systeem: internal
$5F54
$F5F55
5F55 Car Access Systeem: internal
$H5F55
$F5F56
5F56 Car Access Systeem: internal
$H5F56
$F5F57
5F57 Message : CAS signal missing
$H5F57
$F5F60
5F60 Control Unit not for car's with active steering
$H5F60
$F5F61
5F61 Actieve steering: internal
$H5F61
$F5F62
5F62 Actieve steering: signals
$H5F62
$F5F63
5F63 Steering angle sensor steer house
$H5F63
$F5F66
5F66 DSC-sensor 2 internal.
$H5F66
$F5F67
5F67 DSC-sensor 2 internal
$H5F67
$F5F68
5F68 DSC-sensor 2 internal
$H5F68
$F5F69
5F69 DSC-sensor 2 internal
$H5F69
$F5F6A
5F6A DSC-sensor 2 internal
$H5F6A
$F5F6B
5F6B DSC-sensor 2 internal
$H5F6B
$F5F6C
5F6C DSC-sensor 2 power supply
$H5F6C
$F5F6D
5F6D DSC-sensor 2 power supply
$H5F6D
$F5F6E
5F6E DSC-sensor 2 power supply
$H5F6E
$F5F6F
5F6F Engine managment connection
$H5F6F
$F5F70
5F70 Engine managment connection
$H5F70
$F5F71
5F71 Engine managment connection
$H5F71
$F5F72
5F72 Engine managment connection
$H5F72
$F5F73
5F73 Engine managment connection
$H5F73
$F5F74
5F74 Engine managment connection
$5F74
$F5F75
5F75 Engine managment connection
$H5F75
$F5F76
5F76 Engine managment connection
$H5F76
$F5F77
5F77 Engine managment connection
$H5F77
$F5F78
5F78 Engine managment connection
$H5F78
$F5F79
5F79 Trailer signal wrong
$H5F79
$F5F7A
5F7A DSC-sensor error
$H5F7A
$F60AC
60AC Tire problem message : coding data not plausible
$H60AC
$F60AD
60AD Tire problem message : Initialisation not plausible
$H60AD
$F60AE
60AE Control Unit not for car's with active steering
$H60AE
$FD347
D347 PT-CAN communication error
$HD743
$FD34B
D34B F-CAN
$HD34B
D34B F-CAN
$FD354
D354 Message Missing
$HD354
$FD355
D355 Message Missing
$HD355
$FD356
D356 Message Missing
$HD356
$FD357
D357 Message Missing
$HD357
$FD358
D358 Message Transmission Missing
$HD358
$FD359
D359 Message SZL Missing
$HD359
$FD35A
D35A Message Missing
$HD35A
$FD35C
D35C Message Instrument Cluster Missing
$HD35C
$FS35D
D35D Message AFS Missing
$HD35D
$FD35E
D35E Message Missing
$HD35E
$FD35F
D35F Message ARS Missing
$HD35F
$FD360
D360 Message Missing
$HD360
$FD361
D361 Message VIN Missing
$HD361
$FD362
D362 Message Missing
$HD362
$FD363
D363 Bericht (398) ontbreekt
$HD363
$FD364
D364 Message SGM-SZM Missing
$HD364
$FD365
D365 Message Missing
$HD365
$FD366
D366 Message DSC-sensor Missing
$HD366
$FD366
D367 Message Missing
$HD366
$FD368
D368 Message Missing.
$HD368
$FD369
D369 Message DSC-sensor 2 Missing
$HD369
$F5D90
$H5D90
$F5D91
$H5D91
$F5D92
$H5D92
$F5D93
$H5D93
$F5D94
$H5D94
$F5D95
$H5D95
$F5D96
$H5D96
$F5D97
$H5D97
$F5D98
$H5D98
$F5D99
$H5D99
$F5D9B
$H5D9B
$F5D9D
$H5D9D
$F5D9E
$H5D9E
$F5DA1
$H5DA1
$F5DA2
$H5DA2
$F5DA6
$H5DA6
$F5DA7
$H5DA7
$F5DAA
$H5DAA
$F5DAB
$H5DAB
$F5DAD
$H5DAD
$F5DAF
$H5DAF
$F5DB0
$H5DB0
$F5DB3
$H5DB3
$F5DB4
$H5DB4
$F5DB8
$H5DB8
$F5DB9
$H5DB9
$F5DBC
$H5DBC
$F5DBD
$H5DBD
$F5DBF
$H5DBF
$F5DC1
$H5DC1
$F5DC2
$H5DC2
$F5DC6
$H5DC6
$F5DC7
$H5DC7
$F5DCA
$H5DCA
$F5DCB
$H5DCB
$F5DCE
$H5DCE
$F5DCF
$H5DCF
$F5DD0
$H5DD0
$F5DD1
$H5DD1
$F5DD2
$H5DD2
$F5DD3
$H5DD3
$F5DD4
$H5DD4
$F5DD5
$H5DD5
$F5DD6
$H5DD6
$F5DD8
$H5DD8
$F5DD9
$H5DD9
$F5DDC
$H5DDC
$F5DDD
$H5DDD
$F5DDE
$H5DDE
$F5DDF
$H5DDF
$F5DE0
$H5DE0
$F5DE1
$H5DE1
$F5DE2
$H5DE2
$F5DE3
$H5DE3
$F5DE4
$H5DE4
$F5DEE
$H5DEE
$F5DEF
$H5DEF
$F5DF0
$H5DF0
$F5DF1
$H5DF1
$F5DF2
$H5DF2
$F5DF3
$H5DF3
$F5DF5
$H5DF5
$F5DF6
$H5DF6
$F5DF7
$H5DF7
$F5DF8
$H5DF8
$F5DF9
$H5DF9
$F5DFA
$H5DFA
$F5DFB
$H5DFB
$F5DFC
$H5DFC
$F5DFD
$H5DFD
$F5DFE
$H5DFE
$F5DFF
$H5DFF
$F5E00
$H5E00
$F5E01
$H5E01
$F5E02
$H5E02
$F5E03
$H5E03
$F5E04
$H5E04
$F5E05
$H5E05
$F5E06
$H5E06
$F5E07
$H5E07
$F5E08
$H5E08
$F5E
$H5E
$F5E0A
$5E0A
$F5E0B
$H5E0B
$F5E0C
$H5E0C
$F5E0D
$H5E0D
$F5E0E
$H5E0E
$F5E0F
$H5E0F
$F5E10
$H5E10
$F5E11
$H5E11
$F5E12
$H5E12
$F5E13
$H5E13
$F5E14
$H5E14
$F5E15
$H5E15
$F5E16
$H5E16
$F5E17
$H5E17
$F5E18
$H5E18
$F5E19
$H5E19
$F5E1A
$H5E1A
$F5E1B
$H5E1B
$F5E1C
$H5E1C
$F5E1D
$H5E1D
$F5E1E
$H5E1E
$F5E1F
$H5E1F
$F5E20
$H5E20
$F5E21
$H5E21
$F5E22
$H5E22
$F5E24
$H5E24
$F5E25
$H5E25
$F5E26
$H5E26
$F5E27
$H5E27
$F5E28
$H5E28
$F5E2D
$H5E2D
$F5E2E
$H5E2E
$F5E2F
$H5E2F
$F5E30
$H5E30
$F5E32
$H5E32
$F5E33
$H5E33
$F5E34
$H5E34
$F5E35
$H5E35
$F5E36
$H5E36
$F5E3B
$H5E3B
$F5E3C
$H5E3C
$F5E3D
$H5E3D
$F5E3E
$H5E3E
$F5E40
$H5E40
$F5E41
$H5E41
$F5E42
$H5E42
$F5E43
$H5E43
$F5E44
$H5E44
$F5E49
$H5E49
$F5E4A
$H5E4A
$F5E4B
$H5E4B
$F5E4C
$H5E4C
$F5E4E
$H5E4E
$F5E4F
$H5E4F
$F5E50
$H5E50
$F5E51
$H5E51
$F5E52
$H5E52
$F5E57
$H5E57
$F5E58
$H5E58
$F5E59
$H5E59
$F5E5C
$H5E5C
$F5E5D
$H5E5D
$F5E5E
$H5E5E
$F5E60
$H5E60
$F5E62
$H5E62
$F5E6A
5E6A CAN-ERROR
$H5E6A
5E6A CAN-ERROR
$F5E6B
5E6B CAN-ERROR
$H5E6B
5E6B CAN-ERROR
$F5E72
5E72 CAN-ERROR
$H5E72
5E72 CAN-ERROR
$F5E74
5E74 CAN-ERROR
$F5E74
5E74 CAN-ERROR
$F5E75
5E75 CAN-ERROR
$H5E75
5E75 CAN-ERROR
$F5E76
5E76 CAN-ERROR
$H5E76
5E76 CAN-ERROR
$F5E77
5E77 CAN-ERROR
$H5E77
5E77 CAN-ERROR
$F5E7A
5E7A CAN-ERROR
$H5E7A
5E7A CAN-ERROR
$F5E7E
5E7E CAN-ERROR
$H5E7E
5E7E CAN-ERROR
$F5E83
5E83 CAN-ERROR
$H5E83
5E83 CAN-ERROR
$F5E84
5E84 CAN-ERROR
$H5E84
5E84 CAN-ERROR
$F5E85
5E85 CAN-ERROR
$H5E85
5E85 CAN-ERROR
$F5E89
5E89 CAN-ERROR
$H5E89
5E89 CAN-ERROR
$F5E8A
5E8A CAN-ERROR
$H5E8A
5E8A CAN-ERROR
$F5E8B
5E8B CAN-ERROR
$H5E8B
5E8B CAN-ERROR
$F5E8C
$H5E8C
$F5E8E
$H5E8E
$F5E90
$H5E90
$F5E91
$H5E91
$F5E92
$H5E92
$F5E93
$H5E93
$F5E95
$H5E95
$F5E96
$H5E96
$F5E97
$H5E97
$F5E98
$H5E98
$F5E99
$H5E99
$F5E9A
$H5E9A
$F5E9B
$H5E9B
$F5E9C
$H5E9C
$F5E9D
$H5E9D
$F5E9E
$H5E9E
$F5E9F
$H5E9F
$F5EA0
$H5EA0
$F5EA1
$H5EA1
$F5EA2
$H5EA2
$F5EA3
$H5EA3
$F5EA4
$H5EA4
$F5EA5
$H5EA5
$F5EA6
$H5EA6
$F5EA7
$H5EA7
$F5EA8
$H5EA8
$F5EA9
$H5EA9
$F5EAA
$H5EAA
$F5EAB
$H5EAB
$F5EAC
$H5EAC
$F5EAD
$H5EAD
$F5EAE
$H5EAE
$F5EAF
$H5EAF
$F5EBO
$H5EBO
$F5EB1
$H5EB1
$F5EB2
$H5EB2
$F5EB3
$H5EB3
$F5EB4
$H5EB4
$F5EB5
$H5EB5
$F5EBA
$H5EBA
$F5EBB
$H5EBB
$F5EBC
$H5EBC
$F5EBD
$H5EBD
$F5EBE
$H5EBE
$F5EBF
$H5EBF
$F5EC0
$H5EC0
$F5EC1
$H5EC1
$F5EC5
$H5EC5
$F5ED4
$H5ED4
$F5ED5
$H5ED5
$5ED6
$5ED6
$F5EDA
$H5EDA
$F5EDB
$H5EDB
$F5EDC
$H5EDC
$F5EE2
$H5EE2
$F5EE4
$H5EE4
$F5EE5
$H5EE5
$F5EE7
$H5EE7
$F5EED
$H5EED
$F5EEE
$H5EEE
$F5EEF
$H5EEF
$F5EF0
$H5EF0
$F5EF2
$H5EF2
$F5EF3
$H5EF3
$F5EF4
$H5EF4
$F5EF5
$H5EF5
$F5EF6
$H5EF6
$F5EF7
$H5EF7
$F5EF8
$H5EF8
$F5EF9
$H5EF9
$F5EFA
$H5EFA
$F5EFB
$H5EFB
$F5EFC
$H5EFC
$F5EFD
$H5EFD
$F5EFE
$H5EFE
$F5EFF
$H5EFF
$F5F00
$H5F00
$F5F01
$H5F01
$F5F02
$H5F02
$F5F03
$H5F03
$F5F04
$H5F04
$F5F05
$H5F05
$F5F06
$H5F06
$F5F07
$H5F07
$F5F08
$H5F08
$F5F09
$H5F09
$F5F0A
$H5F0A
$F5F0C
$H5F0C
$F5F0D
$H5F0D
$F5F0E
$H5F0E
$F5F0F
$H5F0F
$F5F10
$H5F10
$F5F11
$H5F11
$F5F12
$H5F12
$F5F13
$H5F13
$F5F14
$H5F14
$F5F15
$H5F15
$F5F16
$H5F16
$F5F17
$H5F17
$F5F18
$H5F18
$F5F1A
$H5F1A
$F5F1B
$H5F1B
$F5F1E
$H5F1E
$F5F1F
$H5F1F
$F5F20
$H5F20
$F5F21
$H5F21
$F5F22
$H5F22
$F5F23
$H5F23
$F5F24
$H5F24
$F5F25
$H5F25
$F5F26
$H5F26
$F5F2C
$H5F2C
$F5F2D
$H5F2D
$F5F2E
$H5F2E
$F5F2F
$H5F2F
$F5F30
$H5F30
$F5F31
$H5F31
$F5F32
$H5F32
$F5F33
$H5F33
$F5F34
$H5F34
$F5F35
$H5F35
$F5F36
$H5F36
$F5F40
$H5F40
$5F45
$5F45
$5F47
$5F47
$5F48
$5F48
$5F49
$5F49
$5F4A
$5F4A
$5F4B
$5F4B
$5F4C
$5F4C
$5F50
$5F50
$5F52
$5F52
$5F54
$5F54
$F5F55
$H5F55
$F5F56
$H5F56
$F5F57
$H5F57
$F5F60
$H5F60
$F5F61
$H5F61
$F5F62
$H5F62
$F5F63
$H5F63
$F5F66
$H5F66
$F5F67
$H5F67
$F5F68
$H5F68
$F5F69
$H5F69
$F5F6A
$H5F6A
$F5F6B
$H5F6B
$F5F6C
$H5F6C
$F5F6D
$H5F6D
$F5F6E
$H5F6E
$F5F6F
$H5F6F
$F5F70
$H5F70
$F5F71
$H5F71
$F5F72
$H5F72
$F5F73
$H5F73
$F5F74
$5F74
$F5F75
$H5F75
$F5F76
$H5F76
$F5F77
$H5F77
$F5F78
$H5F78
$F5F79
$H5F79
$F5F7A
$H5F7A
$F60AC
$H60AC
$F60AD
$H60AD
$F60AE
$H60AE
$FD347
$HD743
$FD34B
D34B F-CAN
$HD34B
D34B F-CAN
$FD354
$HD354
$FD355
$HD355
$FD356
$HD356
$FD357
$HD357
$FD358
$HD358
$FD359
$HD359
$FD35A
$HD35A
$FD35C
$HD35C
$FS35D
$HD35D
$FD35E
$HD35E
$FD35F
$HD35F
$FD360
$HD360
$FD361
$HD361
$FD362
$HD362
$FD363
$HD363
$FD364
$HD364
$FD365
$HD365
$FD366
$HD366
$FD366
$HD366
$FD368
$HD368
$FD369
$HD369
HKL1
$F1
1 Temperature selector wheel, right
$H1
Please check the connections at the blue component plug
PIN 8 to the temperature selector wheel. Also check that there
is at least a 5 volt voltage at the selector wheel. If you
can't find any fault, the component must be replaced.
$F4
4 Heater sensor, right
$H4
Please check the connection of the blue component plug
PIN 22 to the heater sensor, right. Please measure the unplugged
temperature sensor which should have at least a voltage of 5 volt.
Replace the heater sensor if necessary.
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
Please check the connection of the blue component plug PIN 9
to the vaporizer sensor. On the disconnected temperature sensor,
the voltage should be at least 5 volt. If the connection is operative,
$F10
10 Outside sensor
$H0
10 Outside sensor
PIN 7 to the outside plug. On the disconnected temperature sensor
$F13
13 Inside sensor
$13
13 Inside sensor
Please check the connection of the blue component plug PIN 21
to the inside sensor. With a disconected sensor,the voltage on the cable
should be at least 5 volt. If the connection is operative, the component
must be replaced.
$F16
16 Inside sensor blower
$H16
Please check the connection of the blue component plug PIN 6 to the
inside sensor. If the connection is operative, the component must be
replaced.
$F22
22 Additional blower relay
$H22
Please check the connection of the white component plug PIN 6 to the
additional blower relay.
If the connection is operative, the component must be replaced.
$F25
25 Temperature selector wheel, left
$H25
Please check the connection of the blue component plug PIN 4
to the temperature select wheel, left. Also check that there is at least
5 volt voltage on the selector wheel. If the connection is operative,
$F28
28 Heater sensor, left
$H28
Please check the connection of the blue component plug PIN 18
to the heater sensor. Please measure the unplugged temperature sensor
which should have at least a voltage of 5 volt. If the connection is
$F31
31 Air quantity selector wheel
$H31
Please check the connection of the blue component plug PIN 5 to the
air quantity selector wheel. There should be a voltage of 5 volt
on the selector wheel. If the connection is operative, the component
must be replaced.
$F32
32 Selector lever foot room
$H32
Please check the connection of the white component plug PIN 24
to the temperature sensor, left. There should be a voltage of 5 volt on
the selector wheel. If the connection is operative, the selector lever
must be replaced.
$F34
34 Layering selector wheel
$H34
Please check the connection of the blue component plug PIN 17 to the
layering selector wheel. There should be a voltage of 5 volt on the
must be replaced.
$F38
38 Additional water pump relay
$H38
Please check the connection of the white component plug PIN 22 to the
additional water pump relay. If the connection is operative, the relay
must be replaced.
$F40
40 Water valve, left
$H40
Please check the connection of the white component plug PIN 21 to the
water valve. If the connection is operative, the water valve must
be replaced.
$F44
44 Climate relay/additional blower relay
$H44
Please check the connection of the white component plug PIN 8 to the
climate relay. If the connection is operative, the climate relay /
additional blower relay must be replaced.
$F46
46 Water valve, right
$H46
Please check the connection of the white component plug PIN 23 to the
water valve. If the connection is operative, the water valve must be
replaced.
$F47
47 Decoupling relay air conditioning
$H47
motronic relay.If the connection is operative,the relay must be replaced.
NOTE: Please check the additional blower relay.
$F48
48 Rear window heater relay
$H48
Please check the connection of the white component plug PIN 7 to the
rear window heater relay. If the connection is operative, the relay must
be replaced.
$F52
52 Fresh air flap motor
$H52
Please check the connection of the green component plug
PIN 6, 7, 8 and 9 to the fresh air flap motor. Also check for,
for a voltage of 12 volt on the motor. If the voltage and the
connection are operative, the fresh air flap motor must be
replaced.
$F55
55 Air flow flap motor
$H55
PIN 14, 15, 16 und 17 to the air flow flap motor. Please check as well
the voltage on the motor ( approx. 12 volt ). If the connection
and the voltage are operative, the air flow flap motor must be
replaced.
$F58
58 Ventilation flap motor, left
$H58
Please check the connection of the green component plug PIN 21,
22, 23 and 24 to the ventilation flap motor left. Please check as well
the voltage on the motor (approx. 12 volt). If the connection and the
the voltage are operative, the ventilation flap motor must be
replaced.
$F61
61 Layering flap motor
$H61
Please check the connection of the yellow component plug PIN 18,
19, 20 and 21 to the layering flap motor, right. Please check as well
the voltage are operative, the layering flap motor must be
replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
Please check the connection of the white component plug PIN 1,
2, 3 and 4 to the front flap motor. Please check as well the voltage
on the motor (approx. 12 volt). If the connection and the voltage are
operative, the front flap motor must be replaced.
$F70
70 Foot room flap motor, left
$H70
Please check the connection of the green component plug PIN 1,
14, 15 and 16 to the foot room flap motor, left.Please check as well the
voltage on the motor (approx. 12 volt). If the connection and the voltage
are operative, the motor must be replaced.
$F73
73 Foot room motor, right
$H73
Please check the connection of the yellow component plug PIN 1,
2,3, and 4 to the foot room motor, right.Please check as well the voltage
$F76
76 Defroster flap motor
$H76
Please check the connection of the green component plug PIN 17
18,19 and 20 to the defroster flap motor.Please check as well the voltage
$F79
79 Ventilation flap motor, right
$H79
Please check the connection of the yellow component plug PIN 14,
15,16 and 17 to the ventilation flap motor,right. Please check as well the
replaced.
$F80
80 Internal/External Air Switch
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
82 Airconditioning Switch
$H82
82 Airconditioning switch
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
85 MAX Switch Driver Side
$H85
$F86
86 DOUWN Switch Driver Side
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
91 MAX switch passenger side
$H91
$F92
92 DOUWN switch passenger side
$H92
$F94
94 Stationary heating
$H94
$F96
96 Stationary ventilation
$H96
$F96
96 Vehicle speed signal
$H96
$F98
98 Vehicle speed signal
$H98
$F96
96 Control Unit : internal error
$H96
$F1
$H1
$F4
$H4
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
$F10
10 Outside sensor
$H0
10 Outside sensor
$F13
13 Inside sensor
$13
13 Inside sensor
must be replaced.
$F16
$H16
replaced.
$F22
$H22
$F25
$H25
$F28
$H28
$F31
$H31
must be replaced.
$F32
$H32
must be replaced.
$F34
$H34
must be replaced.
$F38
$H38
must be replaced.
$F40
$H40
be replaced.
$F44
$H44
$F46
$H46
replaced.
$F47
$H47
$F48
$H48
be replaced.
$F52
$H52
replaced.
$F55
$H55
replaced.
$F58
$H58
replaced.
$F61
$H61
replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
$F70
$H70
$F73
$H73
$F76
$H76
$F79
$H79
replaced.
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
HKL2
$F1
$H1
Please check the connection of the black component plug
PIN 6 to the temperature selector wheel, right. Also check that there
is at least approx. 5 volt voltage on the selector wheel. If you
$F4
$H4
PIN 2 to the heater sensor, right. Please measure the unplugged
temperature sensor which should have approx. 5 volt voltage. You might
have to replace the heater sensor.
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
Please check the connection of the white component plug PIN 5
to the vaporizer sensor. Please measure the unplugged temperature sensor
which should have approx. 5 volt voltage. If the connection is operative,
$F10
10 Outside sensor
$H10
10 Outside sensor
Please check the connection of the white component plug PIN 4 to
the outside sensor. Please measure the unplugged temperature sensor
$F13
13 Inside sensor
$H13
13 Inside sensor
Please check the connection of the black component plug PIN 3 to the
inside sensor. With a disconected sensor, the voltage should be at least
approx. 5 volt. If the connection is operative, the component must
be replaced.
$F16
$H16
Please check the connection of the blue component plug PIN 18 to the
inside sensor blower. If the connection is operative, the component
must be replaced.
$F25
$H25
Please check the connection of the black component plug PIN 5 to the
temperature selector wheel. The voltage on the selector wheel should be
be replaced.
$F28
$H28
Please check the connection of the white component plug PIN 3 to the
heater sensor. Please measure the voltage on the unplugged temperature
sensor which should be approx. 5 volt. If the connection is operative,
$F31
$H31
Please check the connection of the black component plug PIN 4 to the
air quantity selector wheel. There should be a voltage of approx. 5 volt
on the selector wheels. If the connection is operative, the component
must be replaced.
$F34
$H34
layering selector wheel. There should be a voltage of approx. 5 volt
must be replaced.
$F38
$H38
Please check the connection of the blue component plug PIN 19 to the
must be replaced.
$F40
$H40
Please check the connection of the black component plug PIN 22 to the
replaced.
$F44
$H44
Please check the connection of the blue component plug PIN 22 to the
relay/additional blower relay must be replaced.
$F46
$H46
Please check the connection of the black component plug PIN 15 to the
replaced.
$F47
$H47
Pease check the connection of the black component plug PIN 9 to the
motronic relay. If the connection is operative, the relay must be
replaced. NOTE: Please check the additional blower relay.
$F48
$H48
Please check the connection of the blue component plug PIN 20 to the
must be replaced.
$F52
$H52
Please check the connection of the blue component plug PIN 10, 11,
12 and 13 to the fresh air flap motor. Also check for a
voltage of 12 Volt.If the voltage and the cable connection are operative
replaced.
$F55
$H55
Please check the connection of the blue component plug PIN 6, 7,
8 and 9 to the air flow flap motor. Please check the voltage
(appox. 12 volt) on the motor. If the voltage and the cable
connection are opperative, the air flow flap motor must
be replaced.
$F56
56 Automatic air flow control
$H56
Please check the connection of the black component plug PIN 8,
to the AUC-conponent. It is also possible that the automatic air flow
control component is defective!
$F61
$H61
Please check the connection of the black component plug PIN 23,
24, 25 and 26 to the layering flap motor right. Please check the voltage
(approx. 12 volt) on the motor. If the voltage and the cable
connection are operative, the layering flap motor must
be replaced.
$F61
$H61
replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
$F70
$H70
$F73
$H73
$F76
$H76
$F79
$H79
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
$F1
$H1
$F4
$H4
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
$F10
10 Outside sensor
$H10
10 Outside sensor
$F13
13 Inside sensor
$H13
13 Inside sensor
be replaced.
$F16
$H16
must be replaced.
$F25
$H25
be replaced.
$F28
$H28
$F31
$H31
must be replaced.
$F34
$H34
must be replaced.
$F38
$H38
must be replaced.
$F40
$H40
replaced.
$F44
$H44
$F46
$H46
replaced.
$F47
$H47
$F48
$H48
must be replaced.
$F52
$H52
replaced.
$F55
$H55
be replaced.
$F56
$H56
$F61
$H61
be replaced.
$F61
$H61
replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
$F70
$H70
$F73
$H73
$F76
$H76
$F79
$H79
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
Последна промяна ppl на 01 Дек 2006, 12:05, променена общо 2 пъти
HKL3
$F1
1 Temperature selection wheel, right
$H1
PIN 8 to the tenperature selection wheel, right. Also check that there
is at least aprox. 5 volt on the selector wheel. If you can't
find any fault,the component must be replaced .
$F4
$H4
temperature sensor which should have at least approx. 5 volt voltage.
Replace if necessary the heater sensor.
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
sensor which should have at least approx. 5 volt voltage. If the
connection is operating, the component must be replaced.
$F10
10 Outside sensor
$H10
10 Outside sensor
Please check the connection of the blue component plug PIN 7
to the outside sensor. Please measure the unplugged temperature sensor
which should have at least approx. 5 volt voltage. If the connection
$F13
13 Inside sensor
$H13
13 Inside sensor
inside sensor. The voltage on the cable of the unplugged sensor must
be approx. 5 volt. If the connection is operating, the component
must be replaced.
$F16
$H16
be replaced.
$F25
25 Temperature selection wheel, left
$H25
temperature selection wheel, left. The voltage on the selection wheel
should be approx. 5 volt. If the connection is operative, the component
must be replaced.
$F28
$H28
heater sensor. Please measure the unplugged temperature sensor which
should have at least a voltage of approx. 5 volt. If the connection is
$F31
$H31
air quantity selection wheel. There should be a voltage of approx. 5 volt
must be replaced.
$F34
$H34
layering selector wheel. There should be a voltage of approx. 5 volt on
the selector wheels. If the connection is operative, the component must
be replaced.
$F38
$H38
additional water pump relays. If the connection is operative, the
$F40
$H40
replaced.
$F44
44 Climate relay / additional blower relay
$H44
climate relays. If the connection is operative, the climate
relay / additional blower relay must be replaced.
$F46
$H46
replaced.
$F47
47 Decoupling relay Air conditioning
$H47
motronic-relay. If the connection is operative, the relay must
be replaced. NOTE: Please check the additional blower relay.
$F48
$H48
Please check the connection of the white component plug 4 PIN 7 to the
must be replaced.
$F52
52 Air flow flap motor
$H52
Please check the connection of the green component plug PIN 6, 7,
8 and 9 to the air flow flap motor. Also check for
a voltage of 12 volt on the motor. If the voltage and the connection
replaced.
$F55
$H55
Please check the connection of the white component plug PIN 14, 15,
16 and 17 to the air flow flap motor. Please check as well the voltage
on the motor ( approx. 12 volt ). If the voltage and the connection
replaced.
$F58
$H58
Please check the connection of the green component plug PIN 21, 22,
23 and 24 to the ventilation motor,left. Please check as well the volt.
are operative, the ventilation flap motor must be replaced.
$F61
61 Layering flap motor, right
$H61
Please check the connection of the yellow component plug PIN 18, 19,
20 and 21 to the layering motor, right. Please check that there is a
are operative, the layering flap motor must be replaced.
$F64
64 Layering flap motor, left
$H64
Please check the connection of the green component plug PIN 2,
3, 4 and 5 to the layering flap motor, left. Please also check for
a voltage of approx. 12 Volt on the motor. If the voltage
and the connection are operating, the layer flap motor must
be replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
2, 3 and 4 to the front flap motor. Please also check for
a voltage of approx. 12 volt on the motor. If the voltage and the
connection are operating, the front flap motor must be replaced.
$F70
$H70
14, 15 and 16 to the foot room flap motor, left. Please also check for
connection are operating, the foot room flap motor must be replaced.
$F73
$H73
2,3, and 4 to the foot room motor right. Please check as well for
connection are operating, the foot room motor must be replaced.
$F76
$H76
18, 19 and 20 to the defroster flap motor. Please check as well for
connection are operating, the defroster flap motor must be replaced.
$F79
$H79
15, 16 and 17 to the ventilation flap motor, right. Please check
as well that there is a voltage of approx. 12 volt on the motor.
If the voltage and the connection are operating, the ventilation
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
$F1
$H1
$F4
$H4
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
$F10
10 Outside sensor
$H10
10 Outside sensor
$F13
13 Inside sensor
$H13
13 Inside sensor
must be replaced.
$F16
$H16
be replaced.
$F25
$H25
must be replaced.
$F28
$H28
$F31
$H31
must be replaced.
$F34
$H34
be replaced.
$F38
$H38
$F40
$H40
replaced.
$F44
$H44
$F46
$H46
replaced.
$F47
$H47
$F48
$H48
must be replaced.
$F52
$H52
replaced.
$F55
$H55
replaced.
$F58
$H58
$F61
$H61
$F64
$H64
be replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
$F70
$H70
$F73
$H73
$F76
$H76
$F79
$H79
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
Последна промяна ppl на 01 Дек 2006, 12:06, променена общо 1 път
HKL4
$F1
$H1
Please check the connection of the black component plug PIN 21
to the temperature selector wheel, right. Also check that there is at
least approx. 5 volt voltage on the temperature selector wheel. If you
$F4
$H4
Please check the connection of the white component plug PIN 25
to the heater sensor, right. Please measure the unplugged temperature
sensor, which should be at least a voltage of 5 volt. If necessary,
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
the voltage should be at least approx. 5 volt. If the connection is
$F10
10 Outside sensor
$H10
10 Outside sensor
PIN 23 to the outside sensor. On the disconnected temperature sensor
$F13
13 Inside sensor
$H13
13 Inside sensor
to the inside sensor. On the disconnected temperature sensorer the
$F16
$H16
be replaced.
$F25
$H25
to the temperature selector wheel, left. Also check that there is a
voltage of at least 5 Volt. If the connection is operative, the
$F28
$H28
to the heater sensor. Please measure the unplugged temperature sensor,
which should have at least a voltage of approx. 5 volt. If the
$F31
$H31
Please check the connection of the black component plug PIN 23 to the
air quantity selector wheel. There should be a voltage of appox. 5 volt
must be replaced.
$F34
$H34
on the layering selector wheel. If the connection is operative, the
$F40
$H40
water valve. If the connection is operative, the component must be
replaced."
$F44
$H44
Climate relay. If the connection is operative, the additional blower
$F46
$H46
Please check the connection of the black component plug PIN 12 to the
replaced.
$F47
$H47
Please check the connection of the black component plug PIN 18 to the
$F48
$H48
must be replaced.
$F52
$H52
11, 12 and 13 to the fresh air flap motor. Also check that
there is a voltage of 12 volt on the motor. If the voltage
and the connection are operative, the fresh air flap motor must
be replaced.
$F55
$H55
7, 8 and 9 to the air flow flap motor. Also check for
a voltage of approx. 12 volt at the motor. If the voltage and
the connections are operative, the air flow flap motor must be
replaced.
$F61
$H61
Please check the connection of the blue component plug PIN 23,
24,25 and 26 to the layering flap motor,right. Also check that there,
is a voltage of approx 12 volt at the motor. If the voltage and the
connections are operative, the layering flap motor must be
replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
$F70
$H70
$F73
$H73
$F76
$H76
$F79
$H79
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
$F1
$H1
$F4
$H4
$F7
7 Vaporizer sensor
$H7
7 Vaporizer sensor
$F10
10 Outside sensor
$H10
10 Outside sensor
$F13
13 Inside sensor
$H13
13 Inside sensor
$F16
$H16
be replaced.
$F25
$H25
$F28
$H28
$F31
$H31
must be replaced.
$F34
$H34
$F40
$H40
replaced."
$F44
$H44
$F46
$H46
replaced.
$F47
$H47
$F48
$H48
must be replaced.
$F52
$H52
be replaced.
$F55
$H55
replaced.
$F61
$H61
replaced.
$F67
67 Front flap motor
$H67
67 Front flap motor
$F70
$H70
$F73
$H73
$F76
$H76
$F79
$H79
$F80
$H80
$F81
81 Defrost Switch
$H81
81 Defrost switch
$F82
$H82
$F83
83 AUC Switch
$H83
83 AUC switch
$F84
84 AUC Switch
$H84
84 AUC switch
$F85
85 AUTO Switch
$H85
85 AUTO switch
$F85
$H85
$F86
$H86
$F87
87 DOUWN Switch
$H87
87 DOUWN Switch
$F88
88 MIDLLE Switch
$H88
88 MIDDEL Switch
$F89
89 UP Switch
$H89
89 UP Switch
$F90
90 Terminal 61
$H90
90 Terminal 61
$F91
$H91
$F92
$H92
$F94
$H94
$F96
$H96
$F96
$H96
$F98
$H98
$F96
$H96
45 мнения
• Страница 2 от 3 • 1, 2, 3
